Question about Amana ALW480DA Top Load Washer
Diagram of installing belt on amana washer
I'm trying to take a belt off an amana washer model # LW2501L2 and would like a detail drawing of taking off
  • Anonymous Dec 31, 2008
    any help
Show diagram on how to install a belt for Amana washer model number ALW410DAW Serrial number 0006303339
Posted on Apr 01, 2010
    Problem Solver:
  • 7 Answers
No Diagram here. Just a short note from my previous installation.
- Unplug the washer from the electric outlet
- Remove two screws and open the front panel
- Disconnect electric wire socket from the motor
- Clear tension from existing belt by pulling it toward the back and unseat it
- remove two water hoses from a water pump, be prepare to catch water
- unscrew 4 screws that hold the motor
- Take the whole motor/water pump/pulley piece out, the belt will come with it
- put the piece on the floor up side down, so that the water pump is on top
- unscrew the water pump using trox 20 (3 screws)
- with the water pump out, the belt can be remove, remember how it go between legs of the water pump
- put the new belt in, make sure it go it the same way as the old one
- reinstall water pump
- loose the spring that tight up the pulley by unhooking it
- put the motor back to it place
- route the new belt, then tight it up by hooking the spring back
- reinstall hoses to the water pump
- reconnect electric socket to motor
- test run, cover the front panel
- done
Posted on Jan 06, 2009
2003 kia sedona drive belt tensioner diagram
Sounds like you removed the belt prior to drawing a diagram or taking a picture of how the belt runs. Can you add more detail information of your vehicle like does it have power steering, A/C, and if water pump runs off same belt ?
Jun 24, 2017 | Kia Cars & Trucks
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
Belt replacement
belt goes on the bottom of dryer. look up your model on internet on replacing belt . its pretty easy. if old belt is still on make a diagram of how belt goes on, also take a pic.
Jan 30, 2014 | Amana DLW330RA Top Load Washer
Install belt on Amana top load washing machine
Use the correct sized belt!!
Loosen the Motor mounting Bolts. ( Do not take it off ) Now the motor assembly can be moved towards the opposite large pulley.
Replace the belt in this position and slide the motor to it's original position. You adjust it in such away so that, the belt is not too tight or loose!
Apr 05, 2010 | Amana ALW895 Top Load Washer
Diagram with replacement belt doesn't seem to match old manual
I haven't worked on a belt drive but here is the Sears parts site for your washer with diagrams of the console, drive system etc. You may get a better idea of how to replace the belt from these.
Here also is the Whirlpool / Amana installation and maintenance document for Amana belt drive washers. It may look similar to yours.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/56310258b0952a4e8525729c0056d75b/$FILE/Amana_Searcy_TL_Washer.pdf
The other thing I'd check is Whirlpools list of documentation for their laundry products. Check some of the washers that they make for one that looks like yours and you should get a better idea.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6?OpenView&Start=1&Count=30&Expand=6#6
Oct 08, 2009 | Kenmore Washing Machines
Replace Broken Belt
Here is the link that will explain how to do it:
http://www.applianceaid.com/amana-wash.html#belt
check this link u ll get if u dint really sorry for in convinience
Jun 17, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
How to install drum belt in Amana Model LED20AW.
HIya,
Cabinet Removal- Maytag & Amana Top Load Washing Machine
Remove the two (2) screws (item #21 on the attachment below) from the bottom of the front panel. Once the screws are removed, pull out on the bottom of the front panel until the spring clips release for the cabinet top.
Diagrams:
http://www.pcappliancerepair.com/model-display.php
Apr 07, 2009 | Amana DLE330RAW Electric Dryer
Washer belt
To replace the belt on your Amana washer, pull the unit forward then tilt the top of it back to about a 45 degree angle. Once you get the right angle, the unit will rest against the wall behind it instead of falling forward. Take your new belt (availble through local appliance parts stores or on line from the manufactures web site) and first put it in the track around the large pulley, then the track on the smaller pulley on the right. Lastly, the pulley on your left should be moveable. Move the final pulley so that you can get the belt over it. It will then move back to a tensioning position.
May 14, 2008 | Amana NAV5800A Top Load Washer
Amana ALW480DA Top Load Washer Logo
2,859 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
