Question about Microsoft Windows XP Home Edition
IF formula for letter grading in excell spreedsheet
Need IF logic formula for grading with letter grades a-f in spreedsheet (excel) using comparison operator, ie..
=IF(A2>89,"A",IF.......
  • SAMRAMOS1968 Nov 02, 2008
    ANY HELP WOULD BE GREATLY APPRECIATED
    Brigadier General:
  • 6,966 Answers
If you can email experts@fixya.com to forward me your email address (should this be agreeable), I can send you a copy of an excel sheet that automatically computes the grade and have the final grade in 1.0, 1.25, 1.50, 1.75 etc. You can then substitute the A, B, C.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 02, 2008
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
What is the formulas in computing grades in excel?
Deeply repair Excel file password and unlock Excel spreadsheet with use Microsoft Excel unlocker password software. You can simply use this software which completely crack Excel sheet password and excel users very easily read Excel worksheet without any trouble.More information-: http://www.msoffice.excelpasswordunlocker.com/
Aug 16, 2010 | Microsoft EXCEL 2004 for Mac
Add 20% uplift price to a pricelist in an excel spreedsheet
lets say you have the column B with the prices. Got to column C right beside the first price cell (I'll take B2 as first cell for example) which is C2 and type
=1.2*B2
Copy this formula in the column C all the way down to the last price Cell. That will give you all the updated prices.
Before you delete the column B where all your old prices are you need to do one more thing. Select the entire C column (new prices) go to edit and click on copy. Before you click anywhere else go back to edit and click on paste special and select value. This will change the formula cell you have created a minute ago to a value cell. Now you can delete the old prices. Good luck :)
Feb 25, 2009 | Computers & Internet
Import information from a spreedsheet
use the "print from a database" function that the software for the DYMO has. It will allow you to import a database (in this cae your excel spreadsheet) and "map" it to the fields on an address label, like first name, address etc.
Dec 02, 2008 | Dymo LabelWriter 400 Thermal Printer
Formulas in computing grades in excel
www.youtube.com/watch?v=xOU_hL2_zBo
i havent watched it, but i think it might help. hope it helps, enjoy
Nov 16, 2008 | Microsoft EXCEL 2004 for Mac
NEED IF FORMULA FOR LETTER GRADING A-F
Hi again,
it would seem that you posted twice. Pls click here for you other post with my response.
Nov 02, 2008 | Microsoft Windows XP Home Edition
I need Excel's Furmula's
I found some excellent links to excel formulas for you:
This link lists excel formulas by category:
http://www.techonthenet.com/excel/formulas/
This link has some custom formulas for excel that you can download:
http://www.ozgrid.com/VBA/Functions.htm
Sep 20, 2008 | Microsoft Computers & Internet
EXCEL VLOOK Function
Just noticed a small syntax problem, try this:
VLOOKUP(S9,$S$14:$T$18,2,0)
I always add the last parameter of "0" to insure that that an exact match is found.
Jul 27, 2008 | Computers & Internet
How many formulas we can use at a time in Excel
That depends on which version of Excel you are using.
Excel 2003 supports up to 65,335 formulas
Excel 2007 has no limit.
you can communicate between the worksheets which are contained by one workbook (one excel-file).
Communicating between files cannot be done with formula's.
Apr 04, 2008 | Microsoft Excel for PC
Microsoft Windows XP Home Edition Logo
179 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
