Question about Pioneer DEH-1630R CD Player
Connecting a amp
Hi, does the DEH-1630R headunit have a "remote output" cable on it to hook up to an amp? if so what colour would it be, i have two wires that are not beening used {one is black, one is yellow} coming out of the connector that plugs in the back of the headunit.
    Scholar:
  • 148 Answers
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Posted on Oct 31, 2006
How to i attatch jensen amp to pioneer deh-2200ub
You have two options here you can use the rear outputs and make sure you use the LPF low pass filter on the amp. Or you can use the speaker outputs and purchase a line out converter to connect rca's to the amp. The blue/white wire from the headunit goes to the amp remote turn on. power goes directly to the battery and ground goes to the vehicles chassis.
May 22, 2012 | Jensen XA2150 Car Audio Amplifier
Wont turn on
try the following;
disconnect your remote lead, connect the remote terminal to the positive terminal with a piece of wire. If the amp powers up then the remote output from your headunit is at fault. You can connect the remote lead to a switchable live at the headunit end to work around this problem. The amp will switch off when you switch the ignition off and vice versa.
If that doesn't work then there may be a problem with your positive feed so check your fuse (there should be one near your battery where you see the amp cable connect)
If that doesn't work, check how secure your earth lead is, kicker amps use a lot of power so these connections need to made to a clean metal surface. Scrape the paint away if you need to, make sure you have bare metal to connect to.
Lastly, if you have only just installed the amp, check that you have thick enough power cable. As I said before, the amp will draw a lot of current, if the main power cable is too thin then you may not be getting enough current to power the amp.
Hope this is helpful.
May 07, 2011 | Kicker ZX-350.4 Car Audio Amplifier
I have a metra turbowire 70-1857 wiring harness, and i am lost at connecting it to my pioneer aftermarket DEH-1100MP. I have the harness hooked up to the amp in the trunk. and strung through car and in the...
well head units usually dont have just rca inputs....but the outputs can be changed to rca style with adapters. the speaker level outputs are what you need to change....good luck
Apr 25, 2010 | Metra Turbowire 70-1857
I have a Pioneer DEH-p4800mp and I connected to amplifier when i stop the cd player does not stop the amplificator
Question? have you also connected the Remote cable from the CD player to the Amp? or have you only got 12v & gnd hooked into the amp? if so then the amp will be on all the time. the remote goes from the CD player to the amp, usually a blue cable from the back of the head unit.
Jan 12, 2010 | Pioneer DEH-P4800MP CD Player
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Have system hooked up but no power to the amp
check the ground conection and the remote conection if this one is conected to the headunit be sure to have it. if you are using a pre-amp equalizer check the remote conection on it too!!! it maybe the remote from the headunit to the amp or try to conect the remote cable from the amp to the antena remote cable on your headunit.
Mar 29, 2009 | Jensen Car Audio & Video
Lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Jan 16, 2008 | Car Audio & Video
Wiring my tuner-DEH-1800 to Amp GM-5300-T into my 4 speaker system.
In most head units as in your case the Pioneer DEH-1800, there would be 2 RCA female jacks at the rear of the unit. These are your OUTPUTs.
While in most amps including your GM-5300-T, there would similar RCA jacks which would be your INPUTs.
You need to connect the output to the input using an audio cable terminated at both ends with RCA plugs. Further you need to connect the remote trigger on from the head unit to the remote/external amp to switch it on.
A more comprehensive connection diagram is available at page 6 of the GM-5300T Manual which may be downloaded from here.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Pioneer DEH-1800 CD Player
Pioneer DEH-1630R CD Player Logo
125 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
