Question about Goodman Heating & Cooling
Goodman gas furnace
I have a Janitrol (Goodman) gas furnace. The blower would run all the time. I had the repairman come out a he said it was the control board. My research on-line told me it could be the limit switch. (big price difference). He replaced the board, but I also saw him replace a small wire rod behind the gas burners. It was about 3 inches long and the wire rod was about the diameter of a pencil lead. Was I scammed? Just curious, to late now but I would know not to use them again.
Greg
Sounds like it coud have been a flame sensor. the limit switch is usually near the top of the heat exchanger.
Posted on Nov 02, 2008
What's wrong with my furnace?
The relay for the motor is stuck or the points inside the relay are arced closed. Replace the relay.
Apr 26, 2016 | Goodman Janitrol Amana Goodman Janitrol...
My janitrol furnace started to make a lot of noise over the last few days. Could something be loose or does it need to be cleaned?
I hate to say it but it sounds like the bearing in the fan is going out. If your lucky there's a replacement...if not then a new furnace. You will have to have it looked at by a furnace tech.
Its too bad I can't hear the noise then I'd have a better answer for you, sorry.
Dec 30, 2014 | Goodman 66005 Furnace Draft Inducer Motor...
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
Goodman Dependable Janitrol Ninety-two furnace starts but shuts off before blower runs
it is reaching it's temperture limit berore fan cycles on. control issue
Oct 23, 2013 | Goodman Heating & Cooling
Both fans run all the time
which fans are you referring to. is it a gas furnace. If gas furnace and inducer fan and blower run all the time, that's usually from a limit switch tripped and needs to be reset.
Oct 22, 2013 | Goodman Heating & Cooling
Goodman Furnace GMS9/GCS9 Blower seems to not be made very well. The repairman put two different ones on before finding one that's somewhat balanced. I still feel it rumbling a little. Are there
It is possible it is a problem with the motor mounting bracket or the fan housing itself. Tough to believe you have gotten three bad blower wheels. Also could be the motor .
Dec 17, 2017 | Goodman Heating & Cooling
Janitrol GMP 100-4 replacing blower new blower has extra yellow wire. do I just not connect it
Look on the motor wiring diagram, being that it is yello would lead me to believe that this is
a muti-speed blower. If this is true, look for a place on the terminal board that says "Park"Otherwise make sure you tape it off and move it out of the way
May 26, 2011 | Goodman Furnace Draft Inducer Blower ...
I have outside Goodman-Janitrol furnace and air unit and
two things to try first to get you pointed in the right direction. First disconnect the R or RH wire from the T-Stat. If the furnace turns off (Stops firing w/ fan to turn offabout 90 sec. later) then you more than likely have a bad Thermistat. If it continues to run Pull the R wire from the Furnace circuit board. put door back on furnace if it stops you have a short in the wire. Still Running? Most likely a bad curcuit board. Hope this helps.
Oct 12, 2009 | Goodman GMS90703BXA Heater
Janitrol gup power vent ignition sequence
inducer motor should run for several seconds before furnace lights, this proves the pressure switch and ensures proper ventilation
Sep 30, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
239 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
