Question about Solis Master 5000 Espresso Machine
Solis 5000- Leaking and the machine keeps spitting out the screen.
I think the plastic tube that holds the bearing is stripped. Any ideas on where to get this part or a temporary fix until we can find one?
  • julieken66 Mar 24, 2009
    Where can I find the parts for replacement in Singapore
    Problem Solver:
  • 11 Answers
These guys may have it, but look under the Vienna model at this website. Here's a link to the boiler I found for my machine, it's a perfect fit and listed as a Vienna compatible.
Best Wishes,
Lane
http://www.shop.partsguru.com/product.sc?categoryId=-1&productId=937
Posted on Jan 04, 2009
  • Lane Pono
    Lane Pono Jan 18, 2009
    If the plastic tubing you are concerned with is the intake and output tubing to the boiler, they have the brass bearings and small round gaskets that ensure a good seal. You may be missing the those gaskets. Here's the link for a complete gasket kit for your system.
    Best Wishes,
    Lane
    http://www.shop.partsguru.com/product.sc...
Hi my Solis master 5000 digital, grinds a little, then water sounds to be coming out and it does, but not in the cup place, it goes everywhere else and even outside of tray and where coffee grinds go and...
Hi
That is a stripped thumbscrew. You need a new one. When it starts to brew, the stripped thumbscrew pushes up and allows the coffee to fill the head and dredge drawer. The plastic rod that has 2 small hooks on the end and has ribs around the opposite end is your thumbscrew. It holds the filter screen in place. There is suppose to be a small round nut that is molded into the position between the legs with the hooks. If you use the key to tighten the thumbscrew you will pull the nut out and then the thumbscrew will pop out of the brew head. Check the stem of the filter screen. If you have an item that is about 3/8 of an inch long and has a grove in the middle and small bumps on it, that's the nut. You need a new thumbscrew. Remove the old nut on the stem before putting it in the new thumbscrew. Remember it's a thumbscrew, so it only needs to be finger tight. The key is for removing only.
Apr 29, 2011 | Solis Master 5000 Espresso Machine
If we plug in the Solis Coffeemaker, the electrical circuit trips. What happened? It is a 5000 Espressep Machine. We always treated it with care.
Hi
I would suspect the boiler is leaking and shorting. Common problem when you don't descale on a regular basis or descale incorrectly. Any high temperatures during descaling will turn the gasket hard and brittle causing the leak. If not done enough the scale builds up and expands the boiler causing the leak.
Oct 26, 2010 | Solis Master 5000 Espresso Machine
Needs repair
Hi
Where do you live?
Apr 01, 2010 | Solis Palazzo Espresso Machine
Solis Master 5000 is leaking water from underneath machine when not in use.
HI
The most common problem for leaking underneath the machine is the boiler, but there can be other problems. If the water is dirty, there is a drain behind the brew unit that gets clogged with coffee residue, If its clear, its probably the boiler. If its the boiler it needs replacing. Check ebay.
Dec 23, 2009 | Solis Master 5000 Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
Hi
You boiler is leaking and needs to be replaced. Check partsguru.com or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
My solis master 5000 is leaking water into the bin for the pucks
HI
If you remove the brew unit and find water in the top left side of it, where the thumb screw is, you have a stripped thumb screw. This is caused by using the key to install the filter screen and pulls the nut out of the thumb screw. This is why they call it a thumb screw. Finger tight.
Jul 14, 2009 | Solis Master 5000 Espresso Machine
Water is leaking underneath my Solis Master 5000
The only thing that comes to mind is the drain behind the brew unit under the white plastic valve.
Jul 09, 2009 | Coffee Makers & Espresso Machines
Grinder not working on my solis master 5000
Order the replacement boiler, (be sure to empty all of the hot water from the boiler first using the hot water function on the right side of your Solis) take your time and open the machine up, the top comes off. There are 3 mounting screws that hold the boiler in place, remove them, be sure to take hold of the boiler before removing the last mounting screw. Remove and replace the wires and 2 water hoses (w/clips). The orange wires the connect to a unique plastic harness are clipped into the harness. Look closely and you'll see a little window in the plastic harness at the end of each orange wire. Use a tooth pick or a pointed device and push the metal clips thru these windows, this unlocks the wires for removal from the boiler.
Good luck and Best wishes
Lane
Dec 19, 2008 | Solis Master 5000 Espresso Machine
Solis Master 5000 Espresso Machine Logo
111 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
