Question about Philips HTS3410D/37 700W DVD Home Theater System System
DVDs only play in shades of red
Sound is garbl;ed and dvds only play in shades of red. Am using the component video cables. Anyone have a fix? Had an RCA that did this and threw it away. Looks like this is a problematic machine looking at the posts. Am I better off going to walmart and buying something for 75.00?
  • Norm Malcosky
    Norm Malcosky Jan 17, 2009
    Too much reds on mine too. But it plays CDs OK ?? Must be something with the read-head that is not up to snuff.
    President:
  • 3,130 Answers
Buy one for 35.00 they all do the same thing, show and play a movie.
Posted on Sep 24, 2006
I have no sound on my ps3 and the colour is not right when i watchs dvds on it. When the dvd is playing there is a greenish shade to the picture also no sound anywhere.
check the cables
if your using a regular cable check if they are on the right port or if they are properly connected or possible the cable is has loose connection
if HDMi cable kindly check the connection and settings on your television
hope that this works
Feb 10, 2011 | Sony Playstation 3 (PS3) Console
No sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
No surround sound on normal tv just dvds
Do you have a cable box or satellite box? If you do, try hooking up your TV sound through the box. Look for audio out in the back of box (white/red RCA Jacks). Hook RCA cable from cable box to surround amp. Even if the audio out jacks are being used already, you can use Y connectors to hook up the surround amp to the box.
Hope this works for you!
Jul 23, 2009 | RCA Audio Players & Recorders
Coby DVD-937 playing DVDs in Black and White
you did not connect it to the right port in you tv with the right cables. if it came with a cable using red, blue, and green wire you need to connect all three to the appropriate place on the tv in this case the red is a video cable and not audio they are white and black in component video... if it is the other way around you have a red white and yellow cable the red and white are audio and yellow is the only video and needs to be connected to a yellow jack on the television
Jun 23, 2009 | Televison & Video
Will play dvds with sound fine...but no sound from tv
You have to connect extra red & white audio cable from your TV's (or cable box, if you have one) AUDIO OUT to the Home Theater's AUX IN 2 at the back (below Video In). Set the HTS unit to AUX 2 using the AUX button on the remote control and you should be able to get sound.
Jun 14, 2009 | Samsung HT-P38 System
Toshiba 40" 1080p plays dvds with a red tint and no sound??
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Dvd playing blue picture
if it is hooked up with componant, thats the red blue green cables for video, and red white for audio, then you probabily eather dont have the red pluged all the way in, or you have the red audio, and red video---reversed, make sure to check them on the dvd player, and on the tv, if there correct, try using the composit input, that is the yellow red and white
Jan 11, 2009 | Samsung Televison & Video
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
DVDs play in black and white
Try use connect your dvd player with just RCA(composite video) and see if you get regular color picture.If so,you need to go to the system menu to check the video output and see if it is under R Pr Pb-component video setting?If not,be sure to change it to component video setting AND use component video cable to connect to your TV unless your TV don't have this connection.
Joe
Feb 03, 2008 | Sony DAV-C990 System
Newer DVDs won't play properly
you need to buy a cheap av moulator (about 20.00 at most stores) this will solve the problem radio shack has them and so does wall=mart
Jan 13, 2008 | Panasonic Home Theater System System
43 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
