Question about HP Office Equipment & Supplies
HP Potosmart C4200 All in One series New cartridges fitted.Printer will not print.Window on printer says "Print cartridge(s) missing or not detected"
  • piccolopete Nov 02, 2008
    Have tried new cartridges before with same problem.Could it be the printer?
  • 94 Answers
Check the expiration dates on the new ink cartridge. If it is already expired, your printer will no longer detect it.
Posted on Nov 02, 2008
  • 899 Answers
Leave the the printer unplugged for a long time(half hour)( disconnect from computer also) , hope fully it will come out of that state , also check to make sure the wirestrip did not get pulled on and is fitted in good , then say the results you get from doing that
    Genius:
  • HP Master
  • 1,250 Answers
Its better take it for the servicing its happen when the cartridge carrying case of the printer not senses the cartridge, or you can do one thing clean it by some soft cotton clothe gently, then install the cartridge and check if the problem persists its better take it to the service centre
    Genius:
  • 2,035 Answers
Please whip the copper contacts on the side of cartridge and then inside cartridge carrier with a dry paper towel and then insert the cartridge if still their is error then its the printer cartridge carrier contacts is defective you need to change the copper contacts on the printer ....
Good luck....
  • HP Master
  • 19,396 Answers
Check that cello strip on cartridge has been removed.
Do the following:
Remove cartridges.
Unplug power
Unplug printe USB
Unplug computer
Restart computer
Plug back printer power and printer USB to computer.
Install back cartridges.
If it still does not work, get replacement cartridges, one of them is faulty.
    Genius:
  • 3,422 Answers
Step one: Reset the All-in-One:
Do NOT perform any other type of reset on the All-in-One before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the All-in-One and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the All-in-One and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the All-in-One for the error message. If the error message still displays, clean the contacts of the print cartridges.
  • 1 more comment
  • Priya darshan Nov 02, 2008
    Step two: Check the print cartridge for the protective tape
    Check each print cartridge. The tape might have been removed from the
    copper-colored contacts, but still might cover the ink nozzles. If the tape is still
    covering the ink nozzles, carefully remove the tape from the print cartridges.
    Do not
    touch the ink nozzles or the copper-colored contacts.
    Step three: Reinstall the problem cartridge
    One or both of the print cartridges are missing or are installed
    incorrectly. Remove and reinsert the print cartridges and verify that they are fully
    inserted and locked in place. If the problem persists, clean the copper-colored
    Step four: Replace the problem cartridge
    The print cartridge is defective or not intended for use in this device. Replace the problem cartridge with a new cartridge.
    Brigadier General:
  • HP Master
  • 3,614 Answers
Try testing it on another cartridge. could be possible that the one you installed was defective or has the problem. just re check it with some another tank.
    Genius:
  • 1,847 Answers
Did you try reinstall the cartridge and try? that should be the first step of troubleshooting.
  • Legin Varghese
    Legin Varghese Nov 02, 2008
    let me know are you getting the same error again?
New refilled cartridges do not work
I am with Inkjet411 (i.e. technical support for Costco's ink refill machines). It would be helpful to know which cartridges we are talking about. For any of the severe HP 60 / 61 / 901 / 74-75 / 93-97 ink cartridge error messages which result in 'no printing' (i.e. Incompatible Print Cartridges / Cartridges Error', etc.), in most cases the cartridge is electrically damaged (they don't make them the way they used to). Our test lab has run numerous studies across 100+ printer models. I suggest you run the Tap 41 diagnostic 'print-mech tap test' to check the cartridges electrical health first (see www.inkjet411.com for specific printer models instructions or ping youtube for our videos on this). Here is just one example for the HP 74-75 ink cartridges in the HP Photosmart C4200-C5500 series printer models:
https://www.youtube.com/watch?v=8fE-IM4AVMc
>> I also suggest you watch this informational video which explains the issue in more detail:
https://www.youtube.com/watch?v=BskAfa6NJSg
>> Now, it is possible to force the printer spit out a print job during these error conditions (however, usually just one print job at a time) with a marginally performing ink cartridge by clearing the checksum code, but this is only a temporary solution (i.e. on the HP Officejet J4xxx and 4500 series for example, press * + # keys together, then press 123. Go to Information Menu, then go to Checksum for Relock data, a 4/5 digit code will be displayed...then go ahead and press Cancel to exit out. Send your print job thru. We have many of the 'access' procedures for hundreds of HP printer models on Inkjet411.com. Good luck!
Inkjet411help@gmail.com
Feb 24, 2013 | Office Equipment & Supplies
My Hp photo printer C420 takes the command but prints out blank pages
check transfer belt a cartridge some contact bias plate laser unit some posssibilities isolation
Feb 19, 2013 | PrintCountry HP Photosmart C4200 Series...
My printer lights ( all three) are blinking with error message of "cartridge problem" I have tried to replace the cartridge with no success and cleaning the cartridge but no luck. Please help.
In this case you will need two new cartridges to identify the problem.
Take one new color cartridge and one black. Now, remove both the old cartridges and install the new ones and restart the printer.
Most probably your issue should be resolved.
Please ensure that you are using the following cartridges only.
Print cartridge information Part name Part description Product number Print cartridge Black HP No. 15 (equivalent to HP C6615 series) Print cartridge Tri-color HP No. 78 (equivalent to C6578 series)
Apr 08, 2011 | HP DeskJet 920c InkJet Printer
How do I change ink cartridge on my HP inkjet 6500 wireless printer.
Hi, When using refilled print cartridges, the Estimated Ink level and the Printer Status Window may indicate that the print cartridge is out of ink. Either continue to use the print cartridge until print quality degrades, or replace the print cartridge with a new HP print cartridge.
The methods of replacing the ink cartridge of the printer follows here:
Open the printer cover
The printer ink carriage will automatically goes to center
Once the carriage is in the center, the printer was ready to replace the ink.
Pull the down slowly the ink tank off the carriage..
Remember the place where the color/black position.
Remove each tank one at a time, and replace the ink with a new one.
Close the printer cover and it now ready to printer.
HP Deskjet 6500 Series Printer - Setting Definitions
Hope the instructions provided helps.
Dec 03, 2009 | HP Officejet 6500 Wireless All-in-One...
Wont detect
1. Make sure that you removed the tape covering the metal contacts on the print cartridges.
2. Clean those contacts with a cotton swab and distilled, filtered or bottled water. Tap water may damage. Do not touch with curious fingers. Allow to dry.
3. Reinsert, Reset printer.
Feb 04, 2009 | HP Photosmart C4280 Aio Printer
I have a HP Photosmart C4200 series printer. I want to use an alternative supplier colour cartridge, but it won't print! I feel it should. How do I make the printer print with this cartridge?
Contact the dealer for the alternate cartridge, you probably have a defective cartridge that should be replaced under warranty. The third party cartridges are generally remanufactured, cartridges that have been used once (or more) before, then refilled. The quality varies widely. See here for a study of third party cartridge quality.
Regards,
Bob Headrick, MS MVP Printing/Imaging
Aug 20, 2008 | HP Office Equipment & Supplies
23 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
