Question about Hoover Vacuums
I have a u3450 1500w hoover, suction on hose works fine, but carpet suction has never worked, how can i fix this?
  • 417 Answers
There must be a restriction or blockage in the carpet suction pipe. Look at the port where the hose connects to the machine and check for any accumulation of debris or blockage. The same motor drives both suction inlets so it can only be that there is an obstruction.
Posted on Nov 02, 2008
Hose attachment doesn't work
If there is sufficient suction at the end of the hose, the brushes should turn. Temporarily cover the rectangular opening that contacts the carpet/upholstery. This increases the suction to the air turbine, and may start it. The only other thing the user can do is to try to turn one of the brushes to assure the components rotate internally. It will not rotate easily.
Sep 23, 2009 | Hoover SteamVac F5914-900 SpinScrub...
No suction in carpet cleaning mode with Empower
Check the nozzle . Turn it over on it's belly and remove the 4 screws that hold the base plate on. Take off the plate and remove the brushroll. I bet you will see a clog in the intake. If not take it to your local vac shop and let them fix it.
May 28, 2017 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Hoover savvy no suction on carpet setting
Check to make sure you hear the vac. motor is running when in that position. The switch in the handle could be bad if it is not.
Apr 29, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Hoover z400 clogged
There should be a bottom plate covering the brush roll that you can remove, if you can't dig out the what is in there, try using your hose and suck it out from the bottom, maybe you will be able to get it out.
Mar 05, 2008 | Hoover F5858-910 SteamVac Vacuum
No Suction in Hoover U6450-900
If there is no suction, check the filters, if they are clean then there has to be a clog either in the hose or in the inlet down by the brush roll. See if there is suction at the hose end. If there is, then it is clogged down lower. Are you sure that the brush roll is turning when it is on the carpet? For a manual, go to www.hoover.com, put on your model number, if one is available, you can down load it.
Jan 07, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Steam vac will not pick up dirty water
My Hoover Steamvac problem isn't with the bruches--it's with the suction. Dirty soapy water stays in the carpet instead of being returned to one of the holding tanks.
Oct 21, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
133 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
