Question about Harman Kardon AVR 235 Receiver
Receiver shuts down and will not turn back on untill you unplug and plug back in
My receiver has a two part power switch top turns power on and bottom turnd standby on and off. Receiver works for a few hours and goes into standby all by itself and will not switch back on untill you unplug the unit and wait 30 minutes or so then works for a while, so on. Is this a defective power switch?
  • Anonymous Dec 19, 2008
    let me tell you this sucks!!!! problem is the quality is superb when it works, but you have to wait 30 minutes
    President:
  • 3,130 Answers
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
Posted on Sep 24, 2006
Before my Onkyo receiver ht-r591 keeps clicking on/off rightnow is dead , won't power on at all ...Please Help!!!
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com.
Oct 29, 2015 | Onkyo Audio Players & Recorders
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
My Receiver very rarely comes on but shuts off in few minutes even the standby doesn't lit up. but when on works perfectly.
Hi Joseph,
Jun 28, 2015 | Onkyo TX-DS989 Receiver
How to repair a onkyo A-812XG if a volume is higher the unit is shutdown
Hi Ryan, It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com, Thanks, JT
Apr 26, 2015 | Onkyo Audio Players & Recorders
The protect mode is active what are the causes
Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Apr 12, 2015 | Onkyo TX-DS787 Receiver
The protect mode is active - what are the fixes
Denon AVR-1803 keeps shutting down
check your speaker wires make sure none are touching each other this will cause a short and shut the reciever down
Mar 17, 2009 | Denon AVR-1803 Receiver
Protect mode shuts down the receiver
If this happens only when connecting the receiver, chech the receiver cable. If the cable is fine, receiver connector at the back of receiver is faulty.
Protect mode will kick in whenever a fault is detected.
You get the unit not powering up, and sometimes you hear a clicking noise, that is the protection switch that keeps shutting down the unit.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Dec 23, 2008 | Samsung HTZ-510 Theater System
Kenwood 1080VR - shuts down
try unpluging it all plug in sumware else see if it just turns on
Nov 16, 2006 | Kenwood 1080VR Receiver
Harman Kardon AVR 235 Receiver Logo
426 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
