Question about Gateway CX200S Tablet PC
Battery fails to charge completely
My battery will only charge to 44%. I have tried the smart battery auto-learning command, it didn't work. So, I tried to run the batter completely down and re-charge it. Neither solution worked. So I tried the smart battery auto-learning command again and it has been running for 17 hours and the battery is still at 44% charged and the process says it is only 14% complete. Is this amount of time normal? How long should this process take?
  • 1 more comment
  • tom_hansen Jan 08, 2009
    Same problem. My replacement battery only goes to 39%. I let it run overnight.
  • Anonymous Mar 24, 2014
    have charged after saying low battery and now nothing after charging
  • Anonymous Mar 25, 2014
    Charge on battery keeps going down. I have shut it down/off completely and still the charge goes down. I'm using the charger it came with.
  • 417 Answers
It sounds to me as if your battery is faulty. No way should it take 17 hours to charge. The battery is abviously not absorbing the charge and this could be because one or more cells are defunct. You can just wait until it fails completely or look at getting a replacement before this happens.
Please remember to rate this solution.
Posted on Nov 02, 2008
I would like to get help with this IPAD that the battery will not charge I just got this IPAD today from the seller.
First you have to verify if the charger is working. You can't charge an iPad on an iPhone charger, not a lot of people know that. Do you see the charge symbol? The charger may be weak, check it by trying to charge the iPad on another charger perhaps belonging to a friend. If that checks out, the battery has failed. Apple charges about $130 plus tax, places in the mall charge $90. If it is a used one, they fail after about 3 or 4 years. If it is new, contact the seller. Their reviews are good
https://9to5toys.com/2016/05/31/apple-128gb-ipad-pro-wi-fi-cellular/
Guarantee Cellular eBay Stores
Mar 22, 2017 | Apple iPad Tablets & eReaders
Why did it shut off and doesn't restart?
Is it recharging properly, might not be charged and is auto shutting down to save data.
Check your charger is working and the connection to the tab is good.
Bad fitting USB can cause failed charge.
Apr 04, 2016 | Samsung Galaxy Tab Tablet PC
Nextbook8 on charger 8 hours. An only 60% charged this time?
Good evening
This happened to my iPad. When I discovered that there were many programs open, I closed them and it charged.
hope this works for you as it did for me. Some one told me that it was a good idea to plug the tablet to a computer and charge it that way.
kolbrun
Feb 08, 2015 | Nextbook Premium 8 Se Android
How can I get my Samsung Galaxy Tablet to turn on. The battery is fully charged.
There is usually a method such as holding the on button for a longer period of time. If it is easy to do the other thing that I've found with all sorts of "smart" devices which turn "not-so-smart" is to remove the battery for a minute or so, then put it back in. Many times the unit will turn on as soon as the battery is reinstalled and work correctly again after that. Last ditch effort, unless someone knows about the Galaxy, is a hard reset, there may be a reset button somewhere on the unit, I don't think the Galaxy has a reset button. If the unit still does not turn on it may need servicing.
1. Try the on button for 15 - 20 seconds if you know it is charged
2. Try charging for an hour or two then the 15-20 second hold on button, #1 above.
3. Removed battery (I'd measure the battery voltage while I have it out) wait ~1 - 2 minutes & reinstall the battery. If it doesn't turn on by itself try #1.
4. Nothing works start a service ticket with Samsung, URL:
http://support-us.samsung.com
You might try searching there as well for an answer to see if there's anything I missed.
Jan 31, 2015 | Samsung Galaxy Tab Tablet PC
If i took a break from my ipad to answer the phone and talked for 5 to 10 minutes, how do i get it to shut down in about 1.5 minutes. it did this before, and now it does not shut down. why?
Set the auto lock for 2 minutes. Keep in mind that the iPad will not auto sleep and lock during certain application evolutions, like video, game application etc.
if it's just sitting at the spring board, it will auto lock at the specified time interval. 993eeec1-2ff2-4698-acad-f9b1e7b2d782.jpg imthemobile guru
Aug 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
Frozen won't come on
change the battery and try to power it on again
Jan 22, 2014 | Samsung Galaxy Tab Tablet PC
Spilled water on tablet and now it won't charge
Pamela, let it completely dry so don't turn it on until dry.Do not use dryer etc. Had similar problem on smart phone.
Jan 12, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
The battery completely drained and now I have it plugged in to the computer via a usb cord but I am not sure it is charging at all. How can I tell?
Well the screen will Turn on but like mine it drained and I hadn't been on it for a while and then I plugged it in and it didn't turn on but I Just left it and then it fired to Life !! I hope this Helped x
Jun 07, 2011 | Archos 28 Internet Tablet
Gateway CX200S Tablet PC Logo
1,029 people viewed this question
Top Gateway Tablets & eReaders Experts
ashburton
Ricky Ostrom
Ricky Ostrom
vojvodabudva
Are you a Gateway Tablet and eReader Expert? Answer questions, earn points and help others
