Question about Logitech AudioStation High-PerDocking Station formance Stereo System for Apple iPod - 970217-0403 (097855040244)
Setting clock Lost my manual and I am not electronic savvy at all, and this should be simple, but I cannot figure out how to set the clock!
Try the following:
1. Turn the AudioStation OFF
2. Press and hold both ‘source’ and ‘select’ until the F/W rev appears. The F/W info will display for about 2 seconds
3. Select Menu language
4. Use Up/Down buttons display the language, then press ‘select’ to accept.
5. Press the Up/Down arrows to select 12 or 24 hours format, press 'Select' to accept.
6. Press the Up/Down arrows to change the Hour, press 'Select' to accept.
7. Press the Up/Down arrows to change the Minute, press 'Select' to accept.
Posted on Nov 04, 2008
Setting the clock seemed to solve all the other issues, thanks
Posted on Sep 16, 2012
Lost manual and can't figure out how to set time on GE alarm clock model 7-4894A
You can download copy of the user manual for this device from this link , just click HERE and you can follow the steps there on how to set the time on it and make sure to save a copy of the manual for future use.
Jun 18, 2011 | GE 7-4894 Clock Radio
I have the jwin jl cd 809 model and i lost my manual and im having a hard time figuring out how to set the present time and how to set the alarms time
Mantain pressed the CLOCK-ADJ button and turn de big silver knob to the left for setting the hour or the right for setting minutes. Then release the CLOCK-ADJ button.
Sep 22, 2010 | Jwin JL-CD809 Clock Radio
I have lost the service manual for my Timex clock
I had the same problem with a another sound chamber unit but figured it out. there should be a radio buttton somewhere to turn on the radio, make sure AM/FM is set, the volumn is up and the tuner is on a station, make sure there is an antenna wire if there was a place for one.
next, try to figure out setting the time, and then the alarms one at a time. the calender thing, that's a bit harder! they are great clocks, but tough to program.
Aug 03, 2009 | Timex (T307S) Clock Radio
Daylight savings problem
I just figured out how to change mine. remove the battery from the bottom of the clock, keep plugged in, hold down the time zone button and press the set button either up or down which ever time zone you need, it is very simple hope this helps
Mar 08, 2009 | Emerson Smartset Clock Radio
Clock?
there is a menu button to the right of the radio volume knob. with the radio on push and hold that button then push it until it says set clock or the clock starts flashing. then adjust clock
Aug 15, 2008 | 2006 Jaguar S-Type
Setting the clock on my boss 634UA
Hi Tru Infini,
Gopt it for you. The manual is at this URL. http://www.bossaudio.com/support/index.php?_m=downloads&_a=downloadfile&downloaditemid=285
Picture below tell you how to set your clock its Easy.
Nov 20, 2007 | Boss 634UA CD Player
Centrios Atomic Desk Clock/Temperature
Here is how you adjust the time zone:
1.) push MODE till "AL" appears after the minute.
2.) tap "SET" (tap means push but do not hold) and time zone will advance.
3.) THE TRICK: The Time Zone can only be set in the Alarm Mode. Make sure you so not push and hold "SET" until the hour flashes as you would to set the alarm time. You just go into Alarm Mode and tap "SET" to advance the Time Zone by one zone per tap. When the Time Zone is where you want it, tap MODE to return to the clock and set the correct time.
Nov 08, 2007 | Audio Players & Recorders
Alarm Clock
The manual can be downloaded from the RCA site:
http://support.rcaaudiovideo.com/manual.aspx?product=217
Oct 13, 2007 | RCA Mini CD/Radio Alarm Clock System -...
Setting the Clock
Mdaly, Automotive radio is not really my fortay but this problem is fairly simple so here goes: 1. Press and hold the BND button and then press the DISP button to display the clock. 2. Press and hold the BND button and then press the DISP button for a couple seconds or longer to put it in set mode. 3. Press the search up button to set the current minute 4. Press the search down button to set the current hour 5. when finished press the BND button again and the clock is set... If you would like the manual you can email me privately and I'll be glad to send it... premtech@willapabay.org Bill
Jun 06, 2007 | Clarion DB-125 CD Player
Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Mar 17, 2007 | JVC KD-G420 CD Player
Logitech AudioStation High-PerDocking Station formance Stereo System for Apple iPod - 970217-0403 (097855040244) Logo
672 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
