When i switch on the pc i am getting a blank screen im having to switch of the power supply 3 or 4 times to get the pc working im sure doing this will damage the pc i have tried restoreing it but its only going back as far as 3 days its driving me nuts the other night i left it on all night and when i tried to close it it wouldnt go off when its running it goes so well plese give me advice on what to do
  • 75 Answers
Pls. clean your pc first,try to use blower to clean your pc unit,then prepare to have a pencil ERASER.
after cleaning..remove the RAM memory of your pc...use the ERASER to clean its gold teeth/plate{dirty plate makes error connection of RAM into pc.}
return the RAM memory then restart your pc.
tnx 4 using fixya!
Posted on Nov 02, 2008
When i switch on there is power going to the
http://supportapj.dell.com/support/edocs/systems/ins1501/en/sm_en/index.htm
above is a service manual, this has everything you need to troubleshoot, & repair.
I suspect, the Inverter for the screen, is flakey, you most likely will need to attend to that. But work through the troubleshooting in the manual, and you will soon sort iy.
May 06, 2010 | Dell Inspiron 1501 Notebook
My acer aspire 4315 laptop screen goes blank every now n then. if i just adjust it or tap it ,it comes back again.this is there for quite some time.my dealer isnt halping me.says some loose connection with...
The dealer may be right, there are two possibilities. One is your lamps or the lamp power supply is faulty, to confirm it is tha lamps, when the screen goes blank shine a flash light on the screen at an angle and see if you can any images on the screen, if you do it is the lamps or the lamp power supply, you need to take the screen apart to get at them.
If no images it is the connection to the video inputs, to fix that you have to take the computer key board etc. Chech the connections.
From what you say, it sounds more likely the lamp power supply connection. you may need to get a new cable.
Mar 01, 2010 | Acer Aspire 4315 Notebook
It switches on for just a second and then the screen stays blank
yetimonsta, Are you sure that the monitor is BLANK?? Or is it just BLACK? Or is it both BLANK and BLACK? Connect a known good monitor to your pc to prove that your pc is working correctly. What does your L90D+ do when connected to good pc. Have you done the flashlight test to evaluate the state of the "switch-mode-power-supply" when lcd panel goes black /blank?? View more of my profile on fixya and you will discover all the options you have open to you. 12fixlouie
Jan 17, 2010 | Hyundai L90D+ 19" LCD Monitor
Hp cpus power supply green light constantly blinking
As always verify all cords are plugged in properly. After that it sounds like you power supply went out. It is not that hard to replace. Make sure you unplug power cord. After you remove the pc cover, Usually you just need to unscrew 4 screws for the power supply. Somewhere on the power supply it should say how much watts it is. Anywhere from 200 watts and up. Just replace with exact wattage.
Sep 16, 2009 | HP Media Center m7250n (ED842AA) PC...
DP45SG problem
Also make sure that you have a stick of RAM in to allow the motherboard to pull up information.
CPU is seated correctly.
If that fails, then reset the CMOS by pulling the jumper off (pins 1-2) and switching them around (pins 2-3).
Hopefully that will get you some video.
Apr 21, 2009 | Computers & Internet
Blank screen
If you see POST information, but no Windows... try looking for a symbol with two screens on it (usually a "F" function button across the top). Hold "Fn" and whatever "F"-key looks right, and you should be able to switch between laptop LCD, external monitor, or both simultaneously.
Feb 03, 2009 | Toshiba Satellite A105 Notebook
Moniter Screen Blank when my PC start....Giga byte 8S661FXME-RZ Mother board
try to remove the motherboard from the casing and see it if the have some capacitors or any circuit distroy. use other mother board for testing chek your hardware one by one maybe some of your hardware devices damages.
Jan 01, 2009 | Computers & Internet
Blank screen for demo's
I was have the same problem with F1 only and I did the reset .
That fix my problem
Hard Reset procedure for the PS3 (as instructed by Sony CS).
Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves!
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
May 11, 2008 | Sony Playstation 3 (PS3) Console
Xmb menu
when you switch the ps3 on if you hold down the power button for more than 4 seconds it runs the display setup. and sets the ps3 to run in the best possible option
Jan 08, 2008 | Sony Playstation 3 (PS3) Console
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
