Question about IBM ThinkPad T41 Notebook
I have problem with mt laptop that is thinkpad t41
After normal starting ....screein of my monitor display resolution turns off.but everything still work...we can access anything but resolution of screen becomes turns totally we can not see anything in the monitor i think no software problem ...i checked battery it's in 100 % position ...i always use my laptop on direct supply ...can anybody can give some fix this problem..when we press Fn and then F3 comes to full resolution ...after after 2 to 3 minutes it again goes off ...can anybody help???
  • EMaurer07 Nov 24, 2008
    My T41 boots up normally, then after a few minutes, the screen goes black, but the system is still on. If I close the monitor, and then re-open it, the picture comes back for a minute or so, then goes black again. Is this a motherboard issue?
  • IBM Master
  • 1,250 Answers
Boot your system in safe mode remove its display driver, then boot in normal mode install the driver, then check
Posted on Nov 02, 2008
Hanns g hg191a
right click your mouse when no programs are running..
the menu should give you a screen resolution option, start there
if that doesn't work, find your control panel, click in this order
Control Panel
Appearance and Personalization
Screen Resolution
Oct 18, 2013 | Computers & Internet
Acer p201w monitor
go to this link should help you out.... how to set display Acer p201w monitor Google Search ...There is no difference in changing the display on an Acer monitor and on a monitor from another company.
  1. Access the desktop of your computer and right click the screen. ...
  2. Click on the "Settings" tab that is on the top-right corner of the "Properties" window. ...
  3. Adjust the resolution and color to your preferences.
How Do I Change the Display on an Acer Monitor? ' It Still Works ...
Oct 24, 2017 | Computers & Internet
I have a Samsung SuncMaster 940BW 19'' LCD Monitor. It's a geat Monitor in my humble opinion in everything, except that since i got it i have one problem with it, and it wasnt possible for me...
This is a common problem with monitors when changing resolution. What probably happened is you may have tried to change the resolution, or an application changed the resolution, to an incompatible resolution.
For example, if you have a tiny little screen it can't display that huge resolution that a 32 inch monitor has. So, your monitor is stuck in that wrong resolution.
To fix this problem, you need to boot into Safe Mode. Restart your computer, and as it is booting up tap F8 a bunch of times, and then select Boot into Safe Mode.
When it boots up, right click on the desktop, click Properties (Windows XP) or Screen Resolution (Windows 7). When the window pops up, click Settings (if on Windows XP, if on Windows 7 skip to next step). From this window, change the resolution back to the basic 800 x 600 screen resolution.
Now, reboot your computer normally. You should be able to see the desktop. Now, you can do the same thing that you did in safe mode and turn up your resolution. BUT, when you change it, if the screen goes BLANK again, DO NOT press anything. After 15 seconds it should go back, and you can try a lower resolution.
Hope this helps! Thanks for using FixYa.
Aug 27, 2011 | Samsung Syncmaster 940BW LCD Monitor
Monitor only works at start up. then I must use optional monitor. occasionaly monitor will work for a short time
You may need to change the resolution on the screen, in windows, you may find the "Display Options" under "Control Panel", usually this problems is caused by the computer having a hight resolution than the supported by the monitor, for your specific monitor the available resolutions are:
Support of video modes up to 1280 x 1024 at a 75 Hz refresh rate from the manual at:
That means you have to chose a resolution lower than 1280 x 1024 and a frequency lower than 75 Hz. Anything higher than that on the resolution or frequency will cause the monitor to display a "Out of Sync" message and turn off shortly thereafter.
Thanks !!!
Mar 06, 2011 | HP Pavilion F1703 17" LCD Monitor
I have a new Acer 23" LCD monitor - the desktop icons, my email, my word documents - everything is HUGE - I cannot read anything without going back and forth, up and down and it is impossible to type...
You need to change the monitor resolution setting in your operating system. If you are using Windows then go to Control Panel and look for Display Settings (or something similar depending on the version of Windows). Adjust the Resolution setting (probably using a slidebar on screen) to match the optimum setting of your monitor. If you don't have the monitor instructions try the highest setting first and move down one step at a time until you get a correct resolution on the display.
Jan 04, 2011 | Acer Computers & Internet
I want to run a software which requires a screen resolution of 1280 x 768 but my Samsung SyncMaster 740nw supports up to 1280 x 700 screen resolution. Is there anything that I can do? Please guide.
Have you tried adjusting the screen resolution in Control Panel - Display - Settings and moving the slider on Screen resolution?
Normally a monitor such as Samsung LCD would be able to display a higher resolution.
If you cannot adjust the Screen resolution in Display - Settings then it may be that the correct video driver was not installed or is corrupted.
To check if the video diver is OK, go to Control Panel - System - Hardware - Device manager and click on Display adapter. Check that your display adapter is OK and working. If you see a yellow ? against the video adapter or a standard VGA adapter was installed then you need to re-install the video driver for your model graphics card.
Oct 30, 2010 | Samsung SyncMaster 740N 17" LCD Monitor
Monitor says "Out of Range"
This normally happens when display resolution is changed to higher resolution and cannot be compatible/displayed by monitor. Either plug in another monitor and lower down resolution or Press F8 and go to advanced boot option and start your computer in safe mode and try changing display resolution. If it still doesn't works and you have the drivers for you display adapter (video card) then uninstall display adapter from device manager by booting in safe mode. Once you get to normal boot mode reinstall drivers for display adapter.
Jun 05, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Will not display output from Computer
Probably the video resolution or the monitor Refresh Rate (eg: 50/60/75 Hertz) is set too high in the operating system, which over-drives the monitor electronics and it is unable to display anything.
If you restart the computer manually (hold in the power button for 5 seconds, the computer will shut off, turn it back on again) you will see the normal BIOS and Windows startup display on the monitor, but then as Windows completes it's startup it returns to the error message you see.
To fix this, restart the computer manually and start the computer in Safe Mode. To do this press F8 just before the computer starts to load Windows, and choose Safe Mode. Once in Safe Mode, you should see the monitor working correctly.
Now restart the computer in Normal Mode and everything should be fine.
Dec 23, 2008 | Westinghouse LCM-19v1 Monitor
My SVA monitor 5 blacks out after 5 seconds
use f 8 to go to safe mode then set the resolution at the very least liek 8 bits or whatever the lower=st is and save it then restart in normal mode and then play with the resolution in display settings to get to the ma your video card will support.
Jun 19, 2008 | Gateway FPD2275W LCD Monitor
IBM ThinkPad T41 Notebook Logo
175 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
