Question about Panasonic Televison & Video
Panasonic sky box TU-DSB20 After a short time, can be 5, 10 minutes it locks up either switches off or goes to the channel selector. seems to be heat related but not sure.
SOURCE: Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Posted on Jun 14, 2008
SOURCE: no sky sports or sky 1,2,3 on the box starview 2
did you do a factory reset before flashing? do it then flash the box with the firmware. you will need to scan for channels and turn the emu back on after.
Posted on Jan 28, 2009
jimlan
  • 159 Answers
SOURCE: Starview box missing channels, sky movies etc any ideas?
Got this from another site,
sometimes channels change frequency so they dont work,have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Posted on Apr 02, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SOURCE: Panasonic tu-ct20 digital converter box how to
I also have this problem. The helpline tell me that the latest software v1.19 should fix it. We have missed an update by 2 weeks, let us hope they repeat it soon.
Another tip worth a try they say is to power up box ans swtich on. the switch off and remove the aerial and the power plugs from the back of the box. Leave for 15 minutes and plug them back in, power up and then do a shipping condition programme search. Sometimes you get a better sort. If it is nearly right, do not try again as chance are next sear ch will be worse.
Hope this helps. Tim
Posted on Apr 21, 2009
How do I stop my channel changing.
hi i'd put your sky box to av1 and dvd player to either av2 or hdmi 1 hope it helps
regards
shaun
May 04, 2014 | Hitachi 32LD8700 32 in. LCD Television
I have a panasonic viera 42 in plasma. It has a built in freeview receiver. It is in the bedroom and receives a signal through a booster from the main sky box. I can get free view channels on it but can't...
switch tv to analogue tv and auto tune on tuning menu making sure sky is on. It should find it around channel 69. If quality poor then change output frequency to a lower channel. You do this with sky menu and instruction book. Info is changing RF output in book, or google it.
Apr 30, 2014 | Panasonic PV-M1349 Combo
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Dec 09, 2013 | Computers & Internet
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Oct 28, 2009 | Panasonic Televison & Video
I have re-tuned my TU-CT20 Panasonic set top box several times, successfully in that I have a new list of stations, but every time BBC1 and BBC2 are omitted. It starts with ITV1 at channel 1.
If you have all the cahnnels updated then you will have to manually edit the station list and change the order of the channels. refer to your manual for instructions.
Oct 01, 2009 | Panasonic Televison & Video
Cannot tune -in my panasonic vcr. it plays tapes but will not record. I have wired together the tv, sky box and vcr in what seems the obvious way (and every alternative) but no joy so far. can you help?
The main aerial goes into the vcr,a fly lead then comes out of the vcr into the tv,a scart lead from av1 on the vcr into the tv.If you want to record from sky and the vcr has two scart sockets then connect a scart lead from the sky into av2 on the vcr,when you record from sky you select av2 on the vcr as your record channel
Sep 24, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
TV locks up the SKYdigibox
unplug tv for 1 mins,re-plug it back in!
Feb 26, 2009 | Televison & Video
Samsung LE R88 BD LCD TV / digibox problem
Hi.
Its a long shot but try this,
It can cause problems when you switch set to & from stand bye.
Check that you are viewing a digital TV channel
Enter the menu and navigate to:
Setup > System > Software Upgrade > Standby Mode upgrade
Change the setting to Off.
I cant gteee that this will sort your problem out so post here if it doesnt & I will check samsung data base.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
