Question about Lands Phones
How do i wire a jack plug to a phone cable to record calls
  • sallsman Nov 02, 2008
    or source a premaid cable
  • 89 Answers
First open your reciever.
2)you will see a mic and a speaker
3)solder your recording wire to the wires
and start recording.
Posted on Nov 02, 2008
  • 19,396 Answers
You cannot just wire any jack plug and connect microphone recorder cable to phone cable because the audio out signal will be too low.
  • Ginko
    Ginko Nov 02, 2008
    As said, the speaker and the mic of a phone headset and mic are both low level signals.
    If you connect a regualar mic you won't hear anything.
    You need a phone recorder box to record from the phone.
    Master:
  • 505 Answers
Teletool 2000 Phone Conversation Recording Device Record telephone conversations from your phone to your PC! - TeleTool 2000 lets you record telephone conversations or voice messages directly to your PC even if you don't have a voice mail system! Recordings can be saved, filed and/or E-Mailed. Voice messages are saved as standard ".wav" files playable on any Windows PC with a sound card. All the receiver needs to do is double-click the document and listen. TeleTool 2000 works with any telephone that uses a modular handset jack. Just plug in the phone net module that connects the telephone to the computer and a cable that connects to the sound card. It's that simple!
  • Record phone conversations
  • Record and e-mail voice messages
  • Record dictation
  • No voice mail system required
  • Works on any telephone or system
  • Recording software included
  • Sound Blaster Compatible
  • Installs in seconds
Click this link for more info
http://www.twacomm.com/info/Teletool_2000.htm
Thanks
  • Indrajit Roy
    Indrajit Roy Nov 02, 2008
    Go to www.ebay.com or bestbuy and you can purchase the cable online. You can also click on the link I provided and can order it from there.
    Thanks
Which wires on the Cat5 are connected to the WAN Port
Cat 5 is a cable configuration standard that uses a plug and jack that is similar to a modular phone jack called rj45. Those cables plug into multiple points on the router. If you have a separate cable modem, the cat 5 cable from the modem connects to the WAN port on the router.
Mar 08, 2016 | Computers & Internet
Why does my phone say no line?
That means that it is not connected to the wiring that has voice data on it. IT cannot detect the voltage that should be there. Check the wires to the plug in to the phone jack.
Apr 09, 2014 | Lands Phones
Every thing works except can,t get incoming calls and out going calls
First check if the phone jack and cable are good. (I like to plug in an old corded phone for this.) If you have a dial tone with the other phone and can make calls, try the new cable on the base of the cordless phone. If the problem persists, then the phone needs service. (Cordless phones are not meant to be user serviced.)
If neither phone has a dial tone at that jack, try another jack. If only the one jack is bad, open it up and check for loose or broken wires. (Most jacks terminate either at screw terminals with stripped wires or keystone jacks that require a special tool to push the wire down. A cheap version of the tool is sold with many keystone jacks and others are available separately at many home improvement stores. Check the aisle for wiring a house.) A RJ-11 wiring diagram is available here: http://www.lanshack.com/wire_phone_jack.aspx .
Find where your phone connection comes in, open that box and check what type of connection is there. If it is a RJ-11 connection, try your phone at that point. (If it isn't RJ-11, you will need the phone company to check the line.) If there is no dial tone at the service connection, the phone company will repair it at their expense. If the problem is inside, check all exposed wires for damage. If the problem is inside a wall, you may need a professional. Your phone company will fix it for a fee.
I hope this helps.
(I've lost telephone service due to mice chewing on underground wiring, lightning damage to a DSL filter and digging crews failing to avoid the wires.)
Feb 21, 2011 | Uniden EXAI 918 Cordless Phone
Not able to ring out or recieve calls on landline 01772465172
Is there a dial tone? Have you tried plugging in outside in the NID(phone box) on the side if the house. Take a corded telephone out to the box if it has a test port to plug into. If it does, plug in. If you have a dialtone, then the problems inside with either the station wires or jacks, or other equipment that is plugged into the jacks. Remove all devises from the jacks if trouble is inside and take a known working phone and plug it into a jack. if it works, plug in another device, so on and so on. Be sure to check dial tone, break dial tone by pressing a button. Hang phone up and see if dial tone has returned. If not, then that piece of equipment is bad.
If no dial tone at the NID, then call in a trouble report of NO DIAL TONE to the telephone company of cable provider. To save money if trouble is inside, purchase the inside wiring maintenance plan and then have them come work on the phone lines. After the service is restored, call and cancel the maintenance. $5 and you're back in service, provided that's all the teleco charges for wiring maintenance.
Nov 30, 2010 | Lands Phones
The panasonic kx-t7633 has a flashing light but not dial tone
What color is the flashing light? Green is an intercom call and red is a call from an outside line. First try a new phone line cord and check if you have a bad cord. Do you have dial tone at other phones/jacks in the building? Unplug the extension line and plug in a known working phone. The phone needs repair if the your alternate phone works. If the second phone doesn't work at the jack, then the problem is in the wiring (at the jack or in the rest of the wire run) or in the Phone system. Depending on the jack, you can open it up and determine if there are any loose/broken wires. A cable tester that can do telephone lines (RJ-11) will help (some of these will handle power on the cable so check the specs for your phone system). If the jack uses a keystone, you will need to open it up and press the wires back down with the appropriate punch-down tool. You may want to pull the wires up and press them down at a different point (closer to the outlet box).
If none of the phones work then it is the phone system or the wiring coming into the building. I do not know if you can get to the service box and plug in a phone there. If there is no dial tone at the service box, get the phone company to fix it. If the problem is the phone system, you will have to consult a service person who knows more about the system.
I hope you find the problem to be simple, like a bad cable.
Aug 17, 2010 | Panasonic KX-T7633 Corded Phone
Need to determine wiring connections from camera to dvr for Samsung SSC DVR
Hi
Thanks for using FixYa. Please see the link to hook up DVR with camera---
Hookup Camera with DVR
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 16, 2010 | Samsung SSC DVR Digital Video Recorder...
Cable to record telephone interviews with Sony ICRecorder
Use an Olympus TP7 plug it into the mic jack and you should be good
Mar 26, 2010 | Sony ICD-B200 Digital Voice Recorder
Comcast Digital Voice/ADT alam system
The 2 jacks on the back of the Arris modem are labeled "1/2" & "2". The first jack labeled "1/2" means that the jack is capable supporting 2 different phone numbers, a line 1 and a line 2. The second jack labeled "2" means that it is capable of supporting only a second phone number. Therefore your 1 phone number is working correctly from the port labeled "1/2".
There are different types of phone splitters. It is possible that the one you used may have been to split lines 1 & 2 on a single jack into two seperate jacks. Take a closer look at the splitter and see if the 2 ports are labeled differently.
Hope that helps.
Nov 03, 2009 | Arris Touchstone 450a (CM450) Modem
Home telephone wiring
Your wiring could be a mess of splicing, jumpers, additions over the years. It's impossible to know (or to really be able to help you) without being there in person.
Typically, you just have to worry about the red and green wires. The black and yellow are for a second line. This is of course only if you have standard 2 pair wiring.
If any work has been done recently I would concentrate on that area. If just one jack is removed or a wire cut by mistake that could easily take out your entire house. Also, if the red and green wires are touching anywhere that would also cause a problem.
Feb 24, 2008 | Lands Phones
Inexpensive S-video cable is OK?
If you dont have a hi tech theater setup you could almost use jumper wires, BUT yes, the cheap on would work just fine and you would'nt notice the differance from the cheapo one to the expensive type.
Jul 23, 2006 | Panasonic DMR-ES25S Diga DVD Player and...
Lands Phones Logo
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
