Question about Epson Stylus C64 InkJet Printer
Wont print any text
The printer is set up correctly but does not print the text, it goes thru the printing process but the text does not print.
  • 189 Answers
Good day!
That problem happens when the connection of cable is loss from the printer to the unit. Please try to check the cable. If it is on network check if the printer was shared.
Thanks.
Posted on Nov 02, 2008
It won't print.. it goes thru the whole process and makes you think its printing but when its done the page is blank.. I have the Dell AIO 964 printer and all of a sudden it will not print.. it has...
if the unit has been working properly for sometime and then suddenly stopped printing anything... you might try to perform a maintenance cleaning on your unit... this is caused by clogged nozzles which stops the printer to withdraw ink from its tank.... best way is to perform a headcleaning process for sometime.... if it still persist, reseat the ink cartridges... if it still does not work... try spraying the nozzle with wd40.... let it dry for 1 hr or 2.. if it still persist and the process is the same... im a afraid that we may need to have your printer serviced.... hope this helps you out...
have a grand day...At least we tried...:-)
Aug 07, 2011 | Dell 922 All-In-One InkJet Printer
What is a printer spooler
A software program responsible for managing all print jobs currently being sent to the computer printer or print server. The print spooler program may allow a user to delete a print job being processed or otherwise manage the print jobs currently waiting to be printed.
May 22, 2010 | HP LaserJet 2840 Printer
Paper goes thru printer without printing
Look if you do the paper correctly in the printer and if you have enough colour to print then it should go^^
Sep 09, 2009 | Epson Stylus C120 Color Printer InkJet
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Printer wont print text
it is a rare problem ,faced by some users.it happens because some settings get missing and corrupted.so to resolve it.unplug the printer from power and pc both.delete the printer drivers.and install it again with full settings.this will help. thanks.
Jul 13, 2009 | HP Deskjet 5940 Photo InkJet Printer
Canon 3300i prints / process very slow
These machines can print slowly for a varity of reasons. First and foremost is using the incorrect driver. The correct driver can be downloaded here:
http://www.usa.canon.com/opd/controller?act=OPDSoftwareAct&fcategoryid=2275&modelid=6349
Also slow printing can be a symtom of a hard drive about to fail (e602 codes).
Fastest printing speeds can be achieved using the following basic assumptions:
1) The copier is printing thru a standard cat5 cable; not thru the parallel port.
2) The network the copier is on is healthy and operating normally.
3) The network settings on the copier are configured correctly.
I am a Canon trained authorized tech on these machines and have been working in the field on the ImageRunner 3300 series since their release. I'm not sure if a ram upgrade is available but I haven't installed one in the six plus years of servicing this machine to fix a slow print problem.
Nov 09, 2008 | Canon imageRUNNER 3300i Printer
My black ink in my PIXMA MP760 printer will not print. I have gone throuh the maintenance process for cleaning and deep cleaning the heads and it still will not print any black whether it is text or...
The print Head has gone bad. Not using a printer that often will dry out the print head. The print head is where the ink goes. Try to get a cue tip and put some Alcohol in the place where the ink goes through. These should be small sponge like things underneath the ink cartridges.
Jun 06, 2008 | Office Equipment & Supplies
Does not print pictures
hi suvi please tell us more about your computer and printer setting.. However, i have some question.. 1) Does your printer print another logo or any other picture correctly like before? & 2) Which software did you used to print your logo? Thanks, waiting for your response
Aug 29, 2007 | Epson Stylus C46 InkJet Printer
Epson Stylus C64 InkJet Printer Logo
115 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
