Question about Magnum 257 CB Radio
Lost buttons/1 and 2FOR 257
HI,ANY IDEA WHERE I CAN PURCHASE REPLACEMENT BUTTONS 1and 2 AND RUBBER COVER FOR MY CHANNEL CHANGE KNOB/ 257/CHEERS
  • 204 Answers
Yes, if this is the Magnum 257, then contact the company at 1-877-624-6869
or e-mail them from their site,, https://www.rflimited.com/Site.asp?CID=2
Hope this helps you, let me know,,, Mechanic
Posted on Nov 05, 2008
Remot control working but not properly
Option 1: Purchase replacement remote
Option 2: Purchase a universal remote
Option3: Like most remotes they can be disassembled and the board and rubber pads cleaned with de-natured alcohol and reassembled. This may work but is tedious. Unless batteries have leaked in the remote. Then replacement is your only recourse.
Mar 15, 2014 | Televison & Video
Internally change channel 3 to 4 on VCR
Hi, In most VCRs, as you have posted, there is a switch at the back where you can select the output to either Ch 3 or 4. In some cases, the switch is deep inside and you have to remove a small squarish rubber covering to expose the hole. It is normally close to the antenna input/output. More often than not it is a simple sliding 2 position switch. You would need any tool that can reach and sturdy enough to slide the switch. Internally program output channel selector is very possible, I would guess that its selectable via the menu set-up tabs. A question pls, How did you "I tried to manually change the channel to 4, but the VCR reverted back to channel 3..." Hope this be of some help to you. Pls post again how things turn up or further information. Good luck and kind regards.
Aug 01, 2007 | Quasar VHQ401 VHS VCR
Hi i have a behringer xenyx2442fx one channels of the main out is not working also the the cd/tape has one channel down can anyone shed some light on this problem cheers..gaz
It could be one switch at main section called "Stand By" and just got dirty or scratchy, this is the main cause for one channel goes out in this mixers, just take out the plastic cover of this button and insert the cleaner spray pipe in then just give it 2 or 3 shots, then put back the cover and press it several times and recheck functionality, let me know to help.
Oct 15, 2013 | Music
How do you change the channel on this model?
Hi Eric,
Does the unit have knobs on the top of the unit, or just buttons in the front panel beneath the screen?
If the former is the case, one of them will have numbers on it, this is the channel selector.
If the latter is the case, then you should see two buttons with up and down arrows on them, one is Volume, the other is Channel selector.
I hope this is useful to you.
Cheers,
Peter
Dec 19, 2012 | Motorola AXU4100 (10 Channels) 2-Way Radio
GMR1038 New radio will not hold a charge
It would seem that that that unit is eating your batteries, due to an internal fault.
As it is a new unit, you are covered by a warranty and as long as you've kept your invoice as proof of purchase, take it back from whence you purchased it, to get it replaced or repaired or money refunded, your choice.
I hope this is useful info for you.
Cheers,
Peter
Nov 25, 2012 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
Minolta Compact II Binoculars - the focusing adjustment is seized, how do I free it?
The adjusting knob has a rubber cover over it. Remove the rubber cover and take out the phillips head screw underneath. Then turn the adjusting knob all the way left with a pair of pliers and continue turning and it will unscrew and come off. Underneath you will find a metal lock nut, when you loosen this you will find the adjusting knob is suddenly not frozen anymore. It seems that this nut tightens over time to the point where the whole mechanism freezes. You can take the nut off and put some thread lock on the threads and tighten it just enough and it won't happen again. Cheers.
Sep 24, 2011 | Minolta Compact II Binocular
Service lights
Hi, if your 2006 Audi A6 service light is coming up, you have to reset it by following the instruction below..
If your instrument cluster has 2 knobs, one on each side (Older A4's, 1998-2004 A6's, TT's up to ~2006):
Press the right knob and hold it, turn the ignition on, release the right knob and press the left knob, the display should change to service in ----- miles. Or....
Press the right knob and hold it. Turn the ignition on and release the right knob and pull the left one. Then, push the right knob again and pull the left knob again. The display where the mileage is shown should change.
If your instrument cluster has a little wrench on a button on the right (2002-2008 A4's):
Press and hold the wrench button. Turn the ignition on, release the wrench button and press the 0,0 button next to it. The center display should change.
If you have a older body A8, you may be able to reset without a scan tool. Press the 0,00 button on the right of the cluster, turn the ignition on and release the 0,00 button and press the "M" or "Mode" button on the left and it should reset. If this does not work, or you have a 2004 or newer A8, it will probably require a scan tool.
If you have a much older or newer Audi, or certain A8's, you need a scan tool or a special made service light reset tool, available online. You can also purchase af, ter market software and a adapter lead for your laptop and use that. The reset tools will come with instructions. The After market software will go as follows:
On most older vehicles, enter vehicle self diagnosis. Go to #17: Instrument cluster. Go to adaptations, and change the following adaptation channel numbers to the number listed next to it, following the on screen prompts to save and accept.
Channel 5 --> 12
Channel 6 --> 24
Channel 7 --> 36
Channel 8 --> 72
If you have a A3, 2009+ A4, 2005+ A6 or 2004+ A8, or a Q7 and are using the after market software:
Go to guided functions, go to service work, go to reset service light, or something of that nature, and follow the on screen prompts.
Jan 10, 2011 | 2006 Audi A6
How do I reset my service indicator on my car its a 2006 A6 audi this was not done when the car was in and Audi are now looking to charge me for this service
Channel 5 --> 12
Channel 6 --> 24
Channel 7 --> 36
Channel 8 --> 72
Hope it helps
Describe your sanyo moddel number DS27590Problem, I am trying to get the T.V off Video to go into a T.V channel without a remote and i need assisstance into how to do it. How do u Change the channel off of...
Hi there
Check the set to see if it has a source or A/V button. If not, the only thing that you can try is to scroll with the channel buttons up down buttons to see if you can get to the TV channels.
It is likely that you have already tred that:) If that has failed you, then you WILL need to remote to do this. I am sorry to say that this is the only way to get there. You can purchase a remote online from here
Not the only solution you have, in light of the impending change from analogue to digital... you could put your money towards a digital set top box and solve the remote issue at the same time. Check out what you can get from here. They start at less than $50, and could plug into the set you have eliminating the need to change it out of AV mode. You also get extra channels :)
Happy to answer any questions that you may have about it. Cheers
regards
robotek
Jun 19, 2010 | Sanyo DS27590 TV
Radio Communications Logo
106 people viewed this question
Top Magnum Radio Communications Experts
AnyMHz.com
AnyMHz.com
John Porter
Are you a Magnum Radio Communication Expert? Answer questions, earn points and help others
