Question about Dryers
Whirlpool dryer not starting
When the drying setting is chosen I press the on button and I can hear the timer but nothing doesn't turn on.
  • lmac555 Nov 02, 2008
    Thank you Mike!
    I would like to try and tackle can I check the door swithch and or the main blower box fuse? This seems to narrow it down. I look forward to your response.
  • lmac555 Nov 04, 2008
    Mike~ It is a top lint filter and I tried the door switch its fine and not broken.
  • 1,122 Answers
Ok if you don't hear a load sound like the motor trying to start it's not the start switch or motor,more then likely it's the door switch or the main blower box fuse,let me know if you want to try to tackle this let me know-mike
Posted on Nov 02, 2008
  • MIKE major Nov 03, 2008
    i need to know if the dryer was a top lint filter or inside lint filter,the door switch if you don't have a meter you can check it just by pushing it to see if you hear it click on and off,make sure the lever that clicks it is not broken also-mike
  • MIKE major Nov 04, 2008
    so it must be the main fuse on the blower box,you must pull out the dreyr,remove the back panel,you will see a long white fuse on the blower box,if you have a meter you can remove both wires and omh it to make sure,so can also remove wires on the heater box and check top fuse middle thermostat and bottom heat element,but since nothing works it's one of 2 thing door switch or main blower box fuse-mike
I have an electric Estate Dryer made by Whirlpool TEDS840PQO. It has "Timed Dry", "No Heat Fluff" and "Auto Sense Drying" settings. On the Auto Sense Drying it has...
Verify that the wrinkle prevent switch is good. If so, the timer is likely the problem. Sometimes the switch contacts inside the timer can be cleaned to restore operation, bit it is a tricky item to disassemble and reassemble.
Mar 07, 2017 | Dryers
Whirlpool estate teds840jq2 dryer just stopped working. I can hear a clicking sound from the timer when the timer is turned to a setting but when I press the start button, nothing happens
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 16, 2010 | Estate TEDS840JQ Electric Dryer
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Apr 07, 2010 | Hotpoint Ultima WD72 Front Load...
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
Dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Jun 20, 2009 | Whirlpool LER5636P Electric Dryer
LER8858EQ2 electric dryer will not come on.
Thermal fuse on the blower housing is open. Take back off and the thermal fuse is near the blower outlet. It is white and about 2 inches long. Part number is 3392519
Dec 12, 2008 | Whirlpool LGV4634JQ Gas Dryer
either door switch or thermal fuse on rear of unit Exhust duct check those and let me know..(Fuse is white with 2 wires)
Feb 18, 2008 | Dryers
Dryers Logo
121 people viewed this question
Top Dryers Experts
