Question about Refrigerators
I need a circulating fan motor for my Neff K3965XO Fridge Freezer. Can anyone help me locate on, needed urgently as a temporary repair will not last long. Alan
    Genius:
  • 1,122 Answers
Sears .com click on parts put your model number in and get your part,also repair clinic ,com-mike
Posted on Nov 02, 2008
Neff Fridge Freezer K3965 Freezer is working but the fridge is not
This is either a defrost problem or the evaporator fan is not running. The way to check is to open the freezer and do two things. Listen to see if the fan is running, if not and you hear the compressor in the back going then the fan is the problem. If the fan is running then look at the freezer wall and see if it is covered in frost. If so, you have a defrost system failure and either the timer, bi-metal or the defrost heater has gone bad.
Sep 05, 2012 | Neff K3965XO Side by Side Refrigerator
My Neff fridge freezer model K3965 is leaking - Puddles of water are appearing underneath and ice is accumilating at bottom off freezer. I have looked inside and can't see a leak but ocasionly can...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? it overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 08, 2011 | Neff K3965XO Side by Side Refrigerator
The fridge freezer has stopped working. The light is on and the front shows that the fridge and freezer are at the right temperature but neither the fridge / freezer are cold. Is it likely to be the...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2011 | Neff K3965XO Side by Side Refrigerator
Fridge/freezer Samsung3116NW very noisy from left fridge wall Ithink
if the left side of your fridge is the freezer compartment , chances are you have a bad circulation fan . I would suggest replacing the fan motor assembly . The circulation fan is located at the rear of the freezer mounted to the evaporator cover .
Feb 19, 2011 | Samsung Refrigerators
Freezer and frige not that cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 30, 2009 | Neff K3965XO Side by Side Refrigerator
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Neff american fridge freezer, ice dispenser
Are your ice cubes to big or in the dispenser door not opening all the way both can be fixed adjust the flow timer on the ice maker or replace the door dispenser
Jul 27, 2008 | Neff K3965XO Side by Side Refrigerator
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Gere knutson
