Question about Zanussi FS1455W Front Load Washer
ZANUSSI FS1555W AQUACYCLE - NOT STARTING|
Hi! I saw there were similar problems as mine noted for other earlier(?) models, but no response as yet. MACHINE CLICKS 4 TIMES, THEN REPEATS, WONT START. I'd be glad to receive advice on how to fix this problem as this is a good machine and I wouldnt like to have to replace rather than repair it if it's a simple enough fix. Thanks in anticipation of help. What a superb site! Can I link to you from my websites once they're fully developed?
  • 183 Answers
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Posted on Aug 30, 2007
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
Posted on Aug 13, 2008
canbruce75
  • 1776 Answers
SOURCE: zanussi Aquacycle F 1045W doesn't drain
Check the drain line for kinks or obstructions. You can take a flashlight, remove the hose from the pump and look into the suction port of the pump. Check for anything clogging the pump. (like the occasional stray sock). Also check the pump impellers for broken or missing blades and ensure that the pump impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective and will need replaced. Hopefully it is just a clogged pump or drain line. Hope this helped and best wishes.
Posted on Sep 10, 2009
beltronic205
  • 1474 Answers
SOURCE: Zanussi Aquacycle Washing Machine wont spin?
Assuming its pumping out ok, sounds like motor brushes..if not pump clear filter..
Posted on Oct 06, 2009
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
Why will my zanussi FS1555 not start it only beeps at me???
Might be a problem with the door latch which is either not shutting properly or the door switch which could be open.
Look at item 7 in this diagram.
Zanussi FS1555W 91479119100 Washing Machine Spare Parts Diagram
Sep 02, 2014 | Washing Machines
I need user instruction for zanussi aquacycle 850
I suggest check right model and try looking in this link: zanussi/washing_machine
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 09, 2012 | Washing Machines
Need a free download user manual for a zanussi aquacycle 1200
You will need the model number to get an exact match, but there are 10 different aquacycle 1200 manuals you can download from here:
http://www.manualshark.org/s/zanussi+aquacycle+1200+washing+machine+instruction++manual/
Jun 28, 2011 | Zanussi Washing Machines
Zanussi washing machine is making five beeps and not workign - what does this mean? It is not in the manual
My Zanussi Fs1555w is not finishing it's cycle and beeping 7 times. If I put on spin the cycle lasts less than a minute before the end button beeps, then it will beep repetitively 7 times until turned off. Please help
Feb 05, 2010 | Zanussi FS1455W Front Load Washer
I need the user manual for a Zanussi aquacycle 1050. Where is the cheapest place online?
If you live in the u/k, go to this site.
WWW.SERVICEFORCE.CO.UK
In the menu on the left, click on>
user instruction manuals and follow the instructions.
I cannot guarantee you will find your exact model, but you may find one similar.
hope this helps.
Jan 23, 2010 | Washing Machines
Zanussi Aquacycle F 1045W doesn't drain
Sep 10, 2009 | Zanussi IZ12 Front Load Washer
I HAVE A ZANUSSI XC AQUACYCLE 1000 FRONT DOOR
broken circuit in printed circuit board
Aug 11, 2009 | Zanussi Washing Machines
I need to know what the model no is for a zanussi aquacycle 1100 xc washing machine as I have a problem with the drain um and would like to urchase a new one but do not know the model no of the machine
if you look on the back of the machine there should be a label there with the model number. (Or inside the users manual)
http://www.zanussi.co.uk/ or go here and click on 'Contact Us' to find out directly fron Zanussi.
Nov 08, 2008 | Washing Machines
Zanussi FS1455W Front Load Washer Logo
Top Zanussi Washing Machines Experts
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
