Question about HP LaserJet 1200n Printer
Boots to "no bootable CD in Atapi CD-Rom", Thne press F1 when ready
Unable to set boot priority in setup cmos
  • dovidl2120 Nov 30, 2008
    when I start my toshiba notebook this message came up
    "No Bootable CD In ATAPI CD-ROM
    Intel UNDI, PXE-2.0 (build 082)
    For Realtek RTL8139(X)/8130/810XPCI Fast Ethernet Controller v2.13 (020326)
    PXE-E61: Media test faiure, check cable
    PXE-M0F: Exiting PXE ROM
  • 114 Answers
Sounds like dovidl2120, you have a non-bootable disc in the drive. Remove it and the problem should go away.
Posted on Jan 15, 2009
How do I unlock the Bios on an Acer ES-1 111M Laptop
To boot from a CD, DVD or USB device, make sure that the device has boot sequence priority over the hard drive.
BIOS Boot
BIOS (Basic Input Output Subsystem) is a programmable chip that controls how information is passed to various devices in the computer system. A typical method to access the BIOS settings screen is to press ESC, F1, F2, F8 or F10 during the boot sequence.
BIOS settings allow you to run a boot sequence from a floppy drive, a hard drive, a CD-ROM drive or an external device. You may configure the order that your computer searches these physical devices for the boot sequence.
The first device in the order list has the first boot priority. For example, to boot from a CD-ROM drive instead of a hard drive, place the CD-ROM drive ahead of the hard drive in priority.
Before you set boot priority for a USB device, plug the device into a USB port.
To specify the boot sequence:
  1. Start the computer and press ESC, F1, F2, F8 or F10 during the initial startup screen. Depending on the BIOS manufacturer, a menu may appear.
  2. Choose to enter BIOS setup. The BIOS setup utility page appears.
  3. Use the arrow keys to select the BOOT tab. System devices appear in order of priority.
  4. To give a CD or DVD drive boot sequence priority over the hard drive, move it to the first position in the list.
  5. To give a USB device boot sequence priority over the hard drive, do the following:
    • Move the hard drive device to the top of the boot sequence list.
    • Expand the hard drive device to display all hard drives.
    • Move the USB device to the top of the list of hard drives.
  6. Save and exit the BIOS setup utility.
  7. The computer will restart with the changed settings.
Boot Priority Options
Some computer manufacturers allow you to select the device that contains the boot sequence from a special device selection menu. The example below uses a Dell system board.
To set boot priority using a device selection menu:
  1. When the computer starts to boot up, after the manufacturer's ID screen, press F12 several times. The device selection menu appears.
  2. Use the up and down arrows to select CD-ROM or
May 04, 2015 | Acer Aspire Computers & Internet
How do i reformat my pc
Hi Good day!! Sir/Madam if you want to format your pc you will need and CD of a Operating system like WindowsXp/Vista/etc.(note you should have the product key after installing the OS)
here are the steps on reformating:
1. Open your Bios setup by Pressing del or f2 it depends on your board.
2. insert your bootable CD on your CD/DVD rom.
3. go to boot setup, set your boot priority 1st boot must be your CD/DVD rom, 2nd boot your harddisk after you set your boot priority press f10 and then save changes. it will restart your pc.
4. your computer will boot in CD and a message will appear "Press any key to boot from CD...." you should follow it. press any key!! if you boot from cd successfully you should be on windows setup it is a blue screen!! congrats!!
5. windows setup will load it's driver, when finish loading there will be a option on the bottom.
6. press f8 for terms and agreement (read carefully)
you can start formating just read the instruction.
REGARDS
JR
Oct 14, 2010 | Computers & Internet
My laptop does not want to boot, it ask a bootable disk, I created one with ISO image, when I insert that cd, it asked me to press any key, and if a press any key it will brought me to many option...
For that you need to set first bootable device as cd/dvd rom in bios. When you power up the computer press F1 or F2 or del or ALt+F2 key to enter in bios then go to boot menu and set first boot device priority as cd/dvd rom then save settings and exit from bios then it boot with bootable disk. Let me know if you need further assistance. Thanks for using FixYa.
Oct 10, 2010 | Acer Computers & Internet
How to reset the bios password for nec versa m350.. pls help!!! i want to reinstall my OS but i can't access the bios setup to change the settings to boot from cd rom upon startup. there is a bios...
Restart the computer, and read the first message (white text on a black background), hoping that it says something like "press F1 to enter BIOS setup, press F12 to select boot priority".
If it does, press F12, and then select the CD-ROM device as the "bootable" device.
Jun 15, 2010 | Computers & Internet
Cannot boot from cd and run setup
When booting, the writing on the black screen should give you a couple of options akin to
Press F2 to edit boot options or
Press "Del" to enter setup. (bios)
You can use either, but you need to set your CD/DVD disk drive as the first boot option.
May 04, 2010 | Microsoft Windows XP Professional SP2
I have a Gateway 507 GR Windows XP Home Edition. Windows does not load/Boot, Error message "Not found or corupt. I can hit I think it is F-2 or F-12 (I forget) and go to the BIOS settings, and try and...
to go to bios setting either u can hit F2 or F1 key. then u change the boot priority. set it to cd-rom device.
after that u can boot from any bootable cd.
for your operating system problem, boot from the xp bootable cd after setting boot priority, and then repair or reinstall your operating system. some files might have been corrupted.
Mar 01, 2010 | Gateway 507GR PC Desktop
Please help me i can't find my ''cmos'' to make cd-rom boot. please send to: ----> whiteking_94@yahoo.com
The CMOS cell is sited on motherbord.
Open your cpu cabinet then you find 1 square motherbord chipset .there is 1 round cell it is called cmos cell.
If you want to reset all settings of motherbord pull it for 10 minutes then all settings are defaults automatic.
Then if you wan't to boot your computer with cd rom .
Then when you power up the computer press F1 or F2 or "del" key to enter in bios.
Then go to boot option set first boot device as your cd- rom .Then save all settings and exit.
Make sure your cd rom is detected proeprly in bios .
Then put your bootable disk in cd rom so you can boot computer with cd rom.
Aug 26, 2009 | Computers & Internet
Willn't boot up frome the cd rom
You can do this by changing the BOOT Priority in your BIOS settings.
To get into BIOS:-
When you first turn the system on, you get what they call a POST screen (normally has the laptop logo or enegy star monitor rating), at the bottom of the screen, it should give you an option or two (i.e. F1-Boot Options, F2-Setup (also called BIOS). Different systems use different keys to enter the BIOS (or SETUP), this is usually F2 or Delete.
Once you are in the BIOS, just have a browse for BOOT OPTIONS or BOOT PRIORITY, and change the value of FIRST BOOT to CD-ROM.
Save these new settings to CMOS and exit. The system will now reboot, and this should solve the problem
Nov 28, 2008 | Computers & Internet
HP LaserJet 1200n Printer Logo
850 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
