Question about Sony KV-27S42 27" TV
The picture is round
The picture is no longer correctly aligned with the edges of the TV. Leaving the sides of the picture kind of rounded. It also no longer lines up with the bottom edge so the ticker that runs on the bottom of certain programs is cut off, for example on espn the bottomline is cut off because the picture seems to be to far down. i'm sure the picture just needs to be lined up with the four edges of the T.V kind of like you used to have to with computer monitors when they didn't fit the screen, actually it is just like that. Any help would be great. The quality of the picture other then this problem is great.
    President:
  • 3,130 Answers
No my freind, im afraid that you have bad waveshaper capacitors in the vertical sweep circuit in your TV set. This is not an adjustment. you should have a pro assist you with the repair of this set as it is dangerous because of the high voltage inside these sets.
Posted on Sep 24, 2006
My tv will not show full screen on any HD channels
Sorry for such a rubbish answer but if it' just the two side edges(L&R) I had this issue before and was told they are all like this with HD and it' not something you can fix without losing some of the all round picture by zooming in??
Feb 05, 2018 | Televison & Video
Adjust the video height on MAG lt716s computer monitor
don't worry overly, the shapes of things will be altered as you change the resolution. The main preset resolution s have different
aspect ratios
1920 x 1080 is 1.77/1
1600 x 1200 is 1.33/1
you change aspect ration according to your selected resolution.
Your monitor will have a native resolution at which everything looks normal, .......If you vary from that resolution things will obviously change.
Jul 16, 2015 | Computers & Internet
Plastic bobbin gear rod unscrewed, how to align with bobbin round gear
Type into browser: http://fixsewingmachine.com for diagram and instructions. Hope this helps! Jimmy
Apr 06, 2012 | Brother LS-2125 Mechanical Sewing Machine
How do I properly align the thermostat on a 1999 Taurus? Chilton manual says it is not round. Sure looks round to me.
LOL,, It is,, just make sure the spring side is facing the motor not the housing and you'll be fine, make sure and scrape off the old gasket and replace it with a new one
Jun 10, 2011 | 1999 Ford Taurus
Hello i have a mildly used FR350 round head framing nailer. the problem is that it will shoot two or three nails then jam up? thanks todd
This gun is very reliable unless tip is broken or miss-shaped and or wrong nails are being used. Depending on model # could be clip head or full round. For best results do not use generic nails because they are not the exact angle required. Place a strip of nails on outside of rails with nail-heads aligned with edge of rails. The first nail should align with path of the driver (place a straight edge alighed with path of driver). Most generic nails do not align correctly. Good luck
Feb 28, 2011 | Porter Cable Air Tools & Compressors
Having trouble getting the kneading paddle on the post. Does not seem to fit. Is ther anything special I need to do other than push it on?
one side of the post is kind of flat and the other side is round. You need to line up the flat side of the hole in your paddle with the flat side of the post and then it should slip right on. You know that old saying " you put a square peg in a round hole" that is kind of what is going on with your paddle and post ....the 2 flat sides of the paddle and post have to be aligned.
Jan 28, 2011 | Oster 5838 ExpressBake Bread Maker
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Shadow round edge of my lcd tv
hi did u get a solution to this i got the same prob
Mar 08, 2010 | LG 32LG30 32 in. LCD HDTV
Sony bravia 50 in lcd rear projection tv picture dark most of the time
take out screws ob back side around the edges not bottom. the grill that covers the speakers comes off by taking out screws on back in the middle of round knobs after screw is removed unscrew knob. then remove screws next to speakers then remove front of tv clean mirror in back. if that dosent work replace bulb.
Nov 20, 2008 | Televison & Video
Poor picture quality
The problem is probably the convergence power supply.The switching power supply chip on the convergence board will burn out, producing a rounded picture with 3 separate colors. The chip is a long, heat-sinked SIP (single-in-line package) located on the convergence board. You can find replacements on ebay.
Apr 03, 2008 | RCA P61927 61" Rear Projection Television
Sony KV-27S42 27" TV Logo
108 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
