Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
The adjustment screw fell off
As i was adjusting the screw for the beater to bowl clearance of my bowl lift kitchen aid stand mixer (KSM50), the screw fell off. How do I return it inside? Please help!
  • stethacp Jan 03, 2009
    Thanks for the comments. I already fixed it already. What I did was, I opened the kitchenaid by unscrewing the top portion, where the motor is located. And then I screwed it again from the inside. :-)
  • Anonymous Mar 22, 2014
    Does anyone have any ideas on where my mixer should be adjusted to fix the height - the beater is hitting the bowl so it's too tight.
  • 118 Answers
There is no adjustment screw. That should be all the way up so that it will compress the spring and lock the lift lever un the up position. You will need to put the spring, washer and then the Nylock nut back on, I use a standard socket with some paper wadded in the bottom and over one side to hold the nut it it while I screw it back on.
Posted on Nov 30, 2008
I know what you are talking about. That tiny screw in the KSM50 model to raise the beaters... there is one. I know what you mean, but I don't know how to tell you to fix it if it doesn't go back in easily. Find someone handy?
Posted on Jan 03, 2009
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen aid K5SS 300 w with NO beater to bowl adjustment screw. Is there anything else that can be done to adjust this?
There is an adjustment screw there. If you supply an email address I have the Kitchen Aid PDF on bowl adjustment for K5SS. My email address is screaming_skull@hotmail.com
May 02, 2014 | KitchenAid Food Mixers
Beater is hitting bowl
You can find the User's Manual (which shows how to adjust beater-bowl clearance) for your model at:
https://www.kitchenaid.com/customer-service/manuals/
Apr 22, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Mixing blade gets hung up at same spot on each turn
Hi SUSAN. From the symptoms you describe, it sounds like your mixer has a ‘Bowl to Beater Clearance’ issue. That should be pretty simple to fix. But even before we go there, check to make sure your mixing bowl is seating properly in the Bowl Support yolk and ‘snaps’ into place against the Bowl Spring Latch. My wife’s had that happen to her a few times. She thought the bowl was seated tightly, but it wasn’t and she experienced the same problem as you.
If your bowl is seating properly, the next thing to look at is your Beater to Bowl Clearance. The instructions are located in your Owners Instructions manual that came with your mixer. If your lacking one, you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KT2651 )and select the last file listed that appear under Owners Manuals (44): KT2651XWW3.pdf (2974.69 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 10 and you will find the instructions for adjusting the mixer head height.
Your mixer is adjusted at the factory so that the flat beater just clears the bottom of the bowl. If for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, clearance.
Beater to Bowl Clearance:
Your Stand Mixer is adjusted at the factory so the flat beater just clears the bottom of the bowl. If, for any reason, the flat beater hits the bottom of the bowl or is too far away from the bowl, you can correct the clearance easily.
1. Unplug Stand Mixer.
2. Place bowl lift handle in down position.
3. Attach flat beater.
4. Adjust so flat beater just clears bottom surface of bowl when in lifted position by turning screw (A) clockwise to raise the bowl and counterclockwise to lower the bowl. Just a slight turn is all that is required: the screw will not rotate more than 14 turn (90 degrees) in either direction. (The full range of adjustment is 12 turn, or 180 degrees.)
5. Place bowl lift handle in up position to check clearance.
6. Repeat steps 4 and 5 if necessary.
NOTE: When properly adjusted, the flat beater will not strike on the bottom or side of the bowl. If the flat beater or the wire whip is so close that it strikes the bottom of the bowl, coating may wear off the beater or wires on whip may wear.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Dec 19, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Can you lengthen the beater by loosing a screw?
Hi, KLOEHR, your beater will not lengthen by losing a screw. However, if you lost your Beater to Bowl Clearance adjustment screw, then it might appear that your beater had ‘grown’ because now the beater may be touching the bottom of your mixing bowl, where previously it had not. Simply said, the beater didn’t grow the mixer head drooped.
You don’t say if you have a ‘tilt-head’ or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM5PS)and select the last file listed that appear under Owners Manuals: KSM5PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height. I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
If you find the adjustment screw missing, you’ll need to replace it. But now you’ll need
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 10, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Mixer component vibrates; seems to sit too low; beaters rub against bowl; alignment seems wrong
Hi, LAHR, by the symptoms you describe it appears that it’s time to adjust your mixer’s "Beater to Bowl Clearance" adjustment screw, which should be a pretty easy to do by yourself.
The instructions for adjusting your beater to bowl clearance are located in your Owners Manual. If you don’t have the original manual you can easily download a PDF version of it from the KA website: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150 and select the file listed for your model that appears under Owners Manuals (66) KSM150PSER1.pdf (732.33 KB) and save that file to your PC. Turn to Page 14 and you will find the instructions for adjusting the mixer head height.
But to save you some time, I have extracted the instructions below:
Tilt-Head models
• Unplug mixer.
• Lift motor head.
I hope this helps! – Howard, Burke, VA
Dec 09, 2009 | KitchenAid KSM150PS Artisan Series Stand...
What screw do i turn on the standkitchenaid to lower the beaters?
Hi. You can adjust the clearance by turning the adjustment screw counterclockwise. This screw will only turn 90 degrees either way so dont try to force it any further than that. This adjustment dosen't lower the beater, it raises the bowl a bit.
With the bowl-lift in the low position, you'll see a screw on the column of the mixer facing toward the front. This is the adjustment screw. Use the flat beater to check the clearance.
If this solution has assisted you, please rate it. Good luck! ricardok45
Apr 01, 2009 | KitchenAid KP2671 Professional 6 Series...
Beaters don't reach the bottom of the bowl
There is an adjuster on the model I own - the KSM50... It is a tiny little silver screw at the base of the motor between the screws that mount the bowl mover to the stand. Screwing to the left makes the bowl lower and turning to the right makes the bowl higher. I just adjusted mine. Note - just a slight turn can make a difference, but my screw was SO TIGHT- I had to ask my husband to do it. Plus, it is located in a difficult area for some screwdrivers to fit into. He got mine to budge and now my clearance of beater to bowl ratio is perfect.
:) Hope it works for ya,
Nov 05, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
343 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
