My Worcester Bosch Greenstar Combi boiler digital display has started flashing the temperature then two half-rectangles alternately ... it is not heating the radiators to full capacity - any ideas?
Just had same problem.  this apprently happens if the power supply has been interrupted or you switch the power on and off.
• The boiler runs for 15 minutes at minimum heat output to fill the condensate trap, the display (K) alternates between -II-” and the boiler flow temperature. This occurs every time the mains supply has been interrupted.
Posted on Jan 07, 2009
How do you work the heating on a Worcester bosch 35cdi boiler
search for worcester bosch 35 cdi manual choose Greenstar CDI & download the pdf instructions
Dec 31, 2014 | Bosch Water Heaters
Worcester Boiler Greenstar 15Ri - The blue neon light is flashing - what does this mean?
http://www.worcester-bosch.co.uk/homeowner/literature/gas-boiler-literature/greenstar-15ri-literature. Hope this helps :)
Sep 19, 2014 | Water Heaters
Combi -boiler tripped out by shower use
Look for a red reset button to press, maybe on top of casing or inside front panel
Mar 04, 2014 | Home
Lighting the pilot light on a Worcester 24CDi combi boiler.
Most of these boilers don"t have a permenant pilot light they have electronic ignition that lights the burner when you are calling for heat or hot water, is there enough water pressure in the boiler ( there is a small gauge on the bottom r/h side of the boiler the needle should be sitting at between 1 - 2 if not enough pressure the boiler won"t light )
Apr 23, 2010 | Heating & Cooling
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
My Worcester Bosch Greenstar 25CD1 is flashing 5E
the code is SE saying it needs a service it can be reset go to this link for a pdf file showing how to http://www.worcester-bosch.co.uk/cache/file/239/guide-to-re-setting-the--se--code-on-greenstar-cdi-boilers.pdf
Jan 24, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch boiler System
it means that the boiler wants to be serviced, the boiler will still work fine. Once the boiler has been servcied, there are a succession of buttons, that need to be pressed, to tell the boiler that it nhas been serviced. then 365days after it will do it again. Its there to prompt you, to get the boiler serviced
Dec 11, 2008 | Water Heaters
Repressurizing my boiler
take your pick from video or text
How to Repressurise a Heating System with an Internal Filling Key ...
? 3:30
https://www.youtube.com/watch?v=zUsBw1ZpiKY
Oct 27, 2010 - Uploaded by Worcester, Bosch Group
This video shows you how to repressurise your heating system using your Greenstar gas boiler's internal ...
Repressurise Worcester boiler - YouTube
? 4:12
https://www.youtube.com/watch?v=K6fH4XfGgxo Nov 10, 2012 - Uploaded by Rory Macfarlane
This video demonstrates how to repressurise a Worcester combi boiler on the.
Product Troubleshooting Videos ' Worcester, Bosch Group
https://www.worcester-bosch.co.uk > Support > Troubleshooting > Videos How to repressurise a heating system with an internal filling key ... how to repressurise your heating system using your Greenstar gas boiler's internal filling key.
How to top your Worcester combi boiler up - Gas Care.
www.gascare-heating.co.uk/topping-pressure-worcester-bosch-combination-boiler/ Aug 4, 2014 - If the needle on the pressure gauge on your boiler has gone into the red or down to zero it means there is little or no pressure left in the heating system and it needs to be topped up ASAP. So here's Gas Care Swansea's guide to refilling your Worcester Bosch combination boiler through the internal filling link.
How do I re-pressurise my Worcester Bosch boiler? - My Plumber
www.my-plumber.co.uk/blog/how-do-i-re-pressurise-my-worcester-bosch-boiler/ Sep 1, 2015 - 6) Check the pressure on the pressure gauge. When it reaches between 1 and 1.5 bar, it is time to turn the white knob back to the right to close the valve. Be very careful not to over-tighten. 7) Turn the filling key to the left until the arrow lines up with the open padlock and remove the key.
May 12, 2017 | Heating & Cooling
Heating & Cooling Logo
868 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
