Rubber drive belts wanted for Aiwa AD-F810 cassette tape recorder
  • Anonymous Apr 22, 2009
    I have an AIWA AD-F810 that simply will not play, ff and rw are good--is it a belt?
My aiwa brand cassete recorder model : TP-VS485 drive belt is broken, how replaced and where I can find spare parts
Posted on Jul 29, 2010
Aiwa AD F660 cassette deck. Having changed the drive belts, the eject button does not now work. Hook holding the cassette door shut does not drop enough to release. How can I fix this? Thanks, Brian
Have you trapped wire or something near the hook mechanism stopping it from getting full travel when the button's pressed?
The nice people at HiFiengine have a service manual for the deck, free you just need to join.
HTH
Aiwa AD F660 Manual 3 Head Stereo Cassette Deck HiFi Engine
Jan 19, 2018 | Aiwa Audio Players & Recorders
Are aiwa cassette belts available?
Belts are universal. You only need the size (diameter) in mm to find the right belt.
Apr 29, 2014 | Audio Players & Recorders
Drive belts for Aiwa AD-R40
you must go to some store electronics parts, like radio shack or other stores look for yellow pages in your internet or phone guides.
God bless you
Oct 02, 2012 | Computers & Internet
AIWA AD-F810 reel torque
If you have a service manual, go to exploded view 3 and look at 31.
This is the FR idler sub assembly. Check the rubber tyre or tire, see if it has hardened. This is driven by the reel motor and flip-flops between the table reel assemblies to drive fast forward,reverse, and play take up.
Also check the reel assemblies for oil that's gone to gunge.
I'm using brass valve oil with PTFE by Denis Wick, That's musical !
Feb 11, 2012 | Audio Players & Recorders
Aiwa AD-F810 when a tape is place and I try to close the door it won't but it will close and open with out any tape ? the deck is mint
i had the same type deck years ago, some decks have a two part door, make sure the outer door is clipped on to the inner mechanism correctly, may just have to be popped off. then re pop back on to inner door. jim d
Apr 26, 2011 | Samson Audio Players & Recorders
Aiwa AD-1250 When a cassette tape is inserted the spools do not turn; there is a whirring noise when ''forward'' button is pressed. Is it possible for me to repair this fault by opening up the machine ?
You need to replace the belts from the motor. From memory I think there are two. You will probably find that all the rubber parts need to be replaced, including the pinch roller.
Nov 04, 2010 | Aiwa Audio Players & Recorders
Problem with AIWA TP-M130 micro cassette recorder can't get tape out
Following 2 pics of exploded view will help you to solve problem with Aiwa tape.
Need further help. let me know.
Oct 22, 2008 | Audio Players & Recorders
Aiwa cassette deck won't eject
I had this problem on an AD-S40. Turned out to be the drive belts, which had stretched, resulting in the fact that the motors couldn't drive the mechanism through it's various load cycles of opening/closing the captain roller, etc. as required to operate the mechanism. Stuck in mid-cycle, the doors would not open.
After removing the case cover, you can turn the belt driven wheels by hand to complete the cycle, so that you can eject. Then get new belts (several outfits sell belts based on length, on line). You don't need to do much to replace the belts -- after unlocking and getting the tape out, it was only a couple of screws to remove the mechanism, as a unit, and there is no need to fuse with the circuit boards and such. Easier than I expected.
Apr 20, 2008 | Audio Players & Recorders
Cassette door stuck closed
Firstly: do not think about forcing the cassette door! Look inside the unit. You need to hand rotate the capstan flywheel a bit,( a large-ish metal disc attached to the motor via a rubber drive belt.)That should release the powered deck mechanism and allow ejection. Then buy a new drive belt , so that problem does not recurr. Good Luck
Nov 02, 2005 | Aiwa NSX-A115 Shelf System
282 people viewed this question
 Grubhead
Grubhead
