Vokera boiler hot water runs hot and cold intermitantly loses pressure
3 Suggested Answers
  • 30 Answers
SOURCE: Loss of hot water
usually with a loss of hot water on a boiler and the heating still works ok means the heat exchanger is blocked and needs replacing or cleaning. it could also be a faulty sensor.
Posted on Mar 26, 2009
PSITECHNICAL
  • 71 Answers
SOURCE: No heating and no hot water, my boiler won't fire up
If there is a hi-limit switch, maybe it's open, reset the switch, and monitor the temperature, if the temp. increases over the set temp. replace stat, and clean lime off from the tank, if does not have a filtering system
Posted on Apr 21, 2009
Vokera aav leaking
Robert, i'm sorry to say but the AAV's are machined parts and the seal should not have been broken by removing the cap. The floats are set perfectly and you would have been easier replacing the whole vent. You could have isolated all the pipes under the boiler and just drained the boiler down by releasing any pressure by the pressure release valve. You may need to buy another AAV and start again.
Apr 06, 2014 | Water Heaters
Hi All, I have a Vokera Linea 735 boiler, 6 years old. when the heating is on, water is dripping out of the over flow to out-side.This results in the boiler losing pressure and having to be topped up...
Kind of need clarification on a couple things. First, what is the PSI operating pressure. Now, onto more questions. You say that when the boiler is operation, it has water coming out of the overflow correct? Then you say that a couple times a day you have to "top it out". Water coming out of the overflow means that either there is to much water in the vessel and it is leaking out when it gets hot due to expansion, or you have a leaking or faulty inlet water valve or sensor allowing cold water to come into they vessel, making it leak out the overflow, thereby reducing the capacity of your heating. You say you have to "top off" the system. How much are you adding and how are you adding it? A pressure vessel normally doesn't have a place to open up and add water because of the nature of the beast. How are you adding water?
Jan 14, 2018 | Heating & Cooling
MY VOKERA BOILER IS NOT WORKING I HAVE NO HOT WATER AND NO HEATING
try check in the water pressure on the boiler should be on 1.5 bar
Jun 01, 2010 | Heating & Cooling
Low pressure on recently serviced Vokera 14/48se.
Identify the cold feed to the boiler, then look for a tap/service valve which when turned lets water into the boiler via a fill loop to pressurise it. 1-1.5 bar is ok
ju
Nov 05, 2009 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Fan runs continuously
the air pressure which does not controll the fan it is a safe guard for the gas/oil burner to ignite nowing that the fan is running ( air switch normaly negative /positive prssure n/o,n/c circuits. it could be that your boiler is designed for a cant think of techinacal name but when in centre of house/factory and has 1 or more boilers connected to flue etc the fans run when only power to boiler is on , non vented system ? it could be a simple link to remove in controll panel i would phone technical help for manufacture ?
Jan 31, 2009 | Water Heaters
Loss of hot water
Jan 25, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
