Question about Kitchen Ranges
The oven doesn't work ,the ignator doesn't light up. no gas coming
  • fran wilwol Feb 11, 2009
    oven doesnt work burners work fine. it wont ignite. there is no gas coming in.
  • 1,543 Answers
The technical jargon is,.....:
In order for your gas oven to work this is what has to happen: 1. when you turn on the oven, the range sends 120 volts to the glow bar igniter. 2. as the igniter heats up (and starts to glow) it starts using more electricity. 3. when the electric use reaches a set amount (say 3.2 amps) the range knows the glow bar igniter is hot enough to ignite the gas, so it then releases gas through the gas safety valve. 4. when the thermostat tells the oven controller that the temperature has been reached, the control cuts power to the igniter, cutting the amp draw down, causing the safety gas valve to close. 5. process repeats to hold oven temp until you turn off oven.
So,..........the solution is:
most likely your oven igniter burnt out. Find your model number, usually on the range frame just behind the lower drawer or broiler drawer (depending on if it is a self clean gas range or not) and order the correct igniter and replace it.
Posted on Nov 02, 2008
WE HAVE AN ELECTROLUX DD060GA DOUBLE OVEN THE TOP OVEN IS WORKING BUT THE BOTTOM OVEN DOESN`T EVEN COME ON WHEN YOU TURN THE KNOB THERES NO GAS AND NO SPARK AND THE LIGHT WONT COME ON EITHER, CAN YOU...
Good Morning Friend,
I understand that your Electrolux double oven, model# DD060GA, is having trouble with the bottom oven coming on. I also see that your top oven works just fine. This appears to be a UK Electrolux double oven. I suggest contacting the manufacturer directly. They will be able to better assist you in getting your bottom oven functioning correctly.
-Best Regards-
WP
May 21, 2014 | Electrolux EOG7330WN Gas Double Oven
The oven doesn.t go on, I see the ignighter turn on but the gas won't light.
Hello Jim,
Believe it not the igniter is the problem,yes indeed it is coming on yet it is not getting hot enough to allow the gas valve to open. By replacing the igniter with a fresh strong one, the oven will work just fine.
GENE
Nov 14, 2011 | Kitchen Ranges
My oven is not working. At the bottom of the stove the ignitor light comes on, but gas doesn't come on. I would like to fix the problem, can you instruct me on how to fix my oven. I want to bake...
The ignitor is probably weak. You have a good circuit because the oven control is trying to light burner. The gas valve is alo fine because it is allowing current to flow. The ignitor with age does not draw enough current to light off the stove.
Aug 23, 2011 | Tappan Ovens
I have an gas stove Hotpoint model RGB524PEA2WH and Im trying to use my oven but doesnt work.I can see the ignator working, but the gas does not come out. I check the parts and seems to be fine. What can I...
What do you mean "checked the parts?" If you are not a qualified tech DO NOT TOUCH ANYTHING! Check to see if there is a separate knob by the thermostat that turns on the gas.
Dec 28, 2009 | Hotpoint RGB745 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
I just cleaned by hand by magic chef wall oven and now I can't
Pilotless ignition means that a hot surface ignitor lights the oven burner. It does take a little bit of time to light the burner. Maybe 30 seconds. If you want to make sure it lights take the bottom panel out from the oven and observe the hot surface glow and the burners light. No real danger as the gas valve will only open after the hot surface ignitor has satisfied the gas valve. Let me know how it goes. ken
Jan 02, 2009 | Magic Chef 9122 Gas Single Oven
Oven won't heat
do you see a bright glow in the oven area when the oven is turned on it will take 20 secs or so..If not your ignator maybe bad no gas will flow into the oven unless the ignt. is good
Mar 03, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven Ignation would not Stop flickering after ignation
This is usually due to the "brain" of the stove going bad, better known as the control module... not an expensive fix if you can find the part and due it yourself... you can locate it iether in the back right corner when you lift the stove top or it's under an access panel below your broiler drawer depending on model.
Jan 15, 2008 | Brown Stove Works TM110-3 Gas Kitchen...
Maytag MGR4410ADW
You probably need to replace the the ignitor. Even though it glows red does not mean that it is working propery. If it does not draw at least 3.5 amps the gas valve will not open. This can be check with a amp meter.
Feb 20, 2007 | Maytag MGR5751AD Gas Kitchen Range
Kitchen Ranges Logo
357 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
