Question about Admiral AAV7000A
Loud noise while agitating in wash cycle
Top loading Admiral Model # LNC6766A00 washer will fill properly and once the machine starts to agitate it makes a loud noise, washer will spin out and everything works, just the loud noise and grinding it makes, What should I try first?
  • 13 more comments
  • Anonymous Nov 01, 2007
    Loud grinding sound when agitation starts
  • Anonymous Dec 09, 2007
    So loud you can not watch tv in the other end of the house
  • the moth Dec 17, 2007
    my son (14) put his clothes in the washer after i used it and overloaded it. he put to much in it. now it waon't agitate. i can grab the center peice and hold it. if i let it go it moves slightly. this is the only probelm i see. checked bottom for a broke belt. belts fine, it spins on spin cycle. i have the admiral aav7000aww. 2 yrs old
  • michaeldk Feb 29, 2008
    i have the same problem,i have "some"mechanical know how,is this a diy fix?
  • Anonymous Mar 02, 2008
    I have the same problem with a 13 month old AAV7000AWW model. Thanks for the answer. Will try to see if the gears are destroyed. I probably did overload it at some point.
  • Anonymous Mar 20, 2008
    Once the wash starts, theres a loud banging noise and the machine moves, what can i do to stop it from banging around.
  • Anonymous Apr 25, 2008
    loud grinding noise while agitating.
  • Anonymous Apr 29, 2008
    Inglis...very loud grinding noise during the wash cycle.
    Sometimes OK after resetting it several times!
    looked at the belt etc seems ok!
  • Anonymous May 13, 2008
    same ... a banging, almost squeaking during the wash cycle
  • emsemtb911 Jul 22, 2008
    agitator spin slowly and grinds how do i fix the problem
  • gsufnp21 Aug 03, 2008
    We have a loud roaring once the agitator begins to move - LOUD!!. Where do I find a manual to dissassemble the machine? It's 3 yrs old - out of warranty and now this!! We can't find any info in the manual on troubleshooting this - any suggestions for a web link for this washer problem?
    Carl & Paula
  • Anonymous Mar 20, 2014
    doesn't agitate or spin
  • Anonymous Mar 23, 2014
    Machine making loud noise while running thru cycle
  • Anonymous Mar 26, 2014
    The top part of the agitator on my Admiral Ultima will not stay in place
  • Anonymous Mar 31, 2014
    2100 series washer top load
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Posted on Feb 11, 2008
I have the same problem, loud plastic squeak/grind when agitating only. I'd like to fix it, but have never taken apart a washing machine.
The advice below sounds good but where do you start with "begin dissassembly from the tub down"....etc. Anyone have a good internet resource with images for disassembling this machine?
Thanks.
Posted on Mar 16, 2008
    New Friend:
Hi everyone im expirancing the same problems. washer works good, just when in spin cycle it seems as if the barrel becomes so uneven that it knocks around. i have tried less clothes, making sure they are even and everything, still continues. the noise has gotten so bad that it sounds like a earthquake and that the washer will tip over from so much banging. i have never taken apart a washer either but am capable with a few instructions
Posted on Dec 06, 2013
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Admiral AW20N35V
its a good idea if u already hve som tecnical knowledge .otherwise dont try
Jun 15, 2008 | Admiral AW22 Top Load Washer
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Wont agitate
My washing machine fills up fine, but then when its time to start aggitating and spin's it makes like a metal on plastic grinding noise, We would like to try to fix it ourself but have no idea which part it is. Could you please HELP?
Nov 14, 2008 | Admiral AW22 Top Load Washer
Won't agitate
Ours did this and it was because the bearings had busted. I called a local repair guy and he told me over the phone just by listening to the sound. Maybe you could do the same. I do know this, if it is your bearings, buy a new washer. It's not worth the repair...trust me.
Jul 24, 2008 | Admiral AW22 Top Load Washer
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
Admiral AAV7000A Logo
3,864 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
