Question about Danby DDR2504 Dehumidifier
Tank still fills when we are using direct drain feature
We have the Arcticaire ADR4066 and have installed a cut piece of garden hose to use the direct drain feature. We got the unit yesterday (Friday, Sep. 22/06) and have noticed that instead of draining through the hose, the tank still fills up. The hose is connected to the nipple, as per the directions, but the water is still coming out of the hole on the opposite side. Are we missing something? Have we overlooked something simple? Thanks!
Check to see that the hose isn't clogged, and that the hose runs down hill from the tank all the way to the drain. if it is higher than the tank at any point in its path it will not drain. you may put the dehumidifier on top of a small platform to aid drainage. also check that the knockout removed so there is a hole to let the water go from the tank to the hose?
Posted on Feb 22, 2008
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Please rate 4 stars if this is helpful. Thanks and good luck!
Aug 15, 2017 | DeLonghi 50-Pint Electronic Control...
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
Aug 18, 2011 | Danby DDR451 Dehumidifier
Where do i find the model number for an older model goldstar dehumidifier and where can i buy a hose to connect it directly to the sump pump?
Any garden hose will fit the drain connection on your dehumidifier. However, the hose can not be longer than 5 feet. As the drainage relies entirely on gravity to drain. Connecting it directly to a sump pump is not a good solution. Allowing the hose to drain into the sump pump's water collection tank is your only option.
Hope this helped you.
Jun 24, 2011 | Goldstar Dehumidifiers
I am thinking of buying the ADER50LP. Can a drain it directly to a floor drain, by-passing the bucket? If so, does it have an external spigot or will I need a hose? Are ADEW50LP and ADER50 LP identical?
You will need to use a drain hose that is no longer than 5 feet. Using a hose relies entirely on gravity. So, the hose must slope downward with no kinks. A short 5' section of Garden Hose works well. The female coupling end attaches to the dehumidifier. It's a very effective way, not to having to stop and drain the tank time it's full.
The ADEW50LP, is a low Temperature Unit, which designed for basement applications.
The ADER50LP, is a standard unit. Used for all applications, other than a basement.
Both have the external drain feature and the same water extraction capacity.
Hope this helped you. Please let me know.
Jun 21, 2011 | GE Ader50ln Dehumidifier
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
/my dehumidifier has a hose attachment on the back. how does that work?
The hose attachment is used in place of the water collection bucket, to drain the water directly into a floor drain or a sump pump holding tank. A garden hose is connected to the "hose attachment" and run to the floor drain or sump pump holding tank. However, it will not drain UP, only DOWN.
Hope this helped.
Mar 20, 2011 | Amana Dehumidifiers
I cannot find my manual for the Westpointe dehumidifier. I need to know how to fix it so that it uses a drain instead of the tank. It is set up with the hose which is directed to a drain. However, I...
Make sure the hose is clear. Did you put a hole in the attaching place for the hose? Most tanks come with no hole even though there is a hose place in the tank.
Jul 05, 2010 | Midea MDC-45AE Dehumidifier
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over....
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Sep 28, 2009 | DeLonghi Dehumidifiers
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
Water from LG 30 pt dehumidifier drains into reservoir instead of running through garden hose into floor drain like it is supposed to. Have checked...no obstructions to garden hose. Very frustrating...must...
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Jun 19, 2009 | LG DH30 GoldStar Dehumidifier
Danby DDR2504 Dehumidifier Logo
740 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Vincent_G
Vincent_G
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
