Question about Refrigerators
Hotpoint fridge Hi Ginko, Reference my Hotpoint/Ariston/Zanussi fridge. MSAA44. There is no removable plate inside the fridge to get at the thermistor but what I did notice is that where the ice was forming on the back panel the inside lining is raised away from the insulation like a large flat bubble. Could this be a cause? Thanks for all your help John
  • Refrigerators Master
  • 19,396 Answers
That is probably caused by heath at the back of the fridge, check if the coil at the back is getting too hot.
Check if defrost system fan at the back of the fridge is working.
Posted on Nov 02, 2008
My washer door will not open its a wd645 model i cant find the lever when i took lid off
Hi.
The door latch is probably broken. Emergency opening can be done accessing the door latch from the inside of the washer assembly.
Before attempting an emergency opening, disconnect power cord and empty water inside the machine through the filter located at the bottom front side of the machine.
After removing water connect back the machine and try opening again.
If that does not work, then the machine must be disassembled. Most models have an emergency cable located on the inside of the door latch. Pulling the cable will release the latch.
The inside of the door latch is reached either from filter housing or from top of the machine. Either the filter (usually held by screws) or the top panel must be removed to access the inside of the lock mechanism.
Power must be kept off while doing maintenance. Due to the safety issues involved the door latch emergency opening and repair must be done by a trained technician.
Regards.
Ginko
Dec 15, 2011 | Hotpoint -Ariston Aquarius WD645 Front...
Tip
List of codes for Hotpoint, Creda, Ariston, Indesit, Cannon
Appliance tagged Hotpoint, Creda, Ariston, Indesit, Cannon are all distributed by the Indesit appliances group.
All this brands share parts, they share the same error code list, and the service is provided by same centres.
I will publish a list of error codes for Hotpoint, Creda, Ariston, Indesit, Cannon.
Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more.
  • F17 - Door not closed properly. Close door firmly at 3 o'clock position
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book service
  • F40 - Water below protection level during a heat step
  • F41 - Water level detect sequence incorrect
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language).
Fault codes for LCD EVO1 Washers
  • F01 - Short circuit motor triac
  • F02 - Motor jammed tacho detached
  • F03 - Wash thermistor open/short circuit
  • F04 - Pressure switch jammed on empty
  • F05 - Pressure switch jammed on full
  • F06 - Program selector error
  • F07 - Heater relay stuck
  • F08 - Heater relay cannot be activated
  • F09 - Incompatible eeprom
  • F10 - Pressure switch not sensing correctly
  • F11 - Pump cannot be activated
  • F12 - Communication error
  • F13 - Dryer fan or dryer thermisotor fault
  • F14 - Dryer element fault
  • F15 - Dryer element relay fault
  • H20 - Not fillings. Check tap, hose and inlet valves
  • LOCKED - Check interlock
Fault codes for LCD EVO2 and V4 Washers
  • F01 - Motor traic short circuit
  • F02 - Motor jammed or tacho detached
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • F08 - Heater relay stuck
  • F09 - Setup error
  • F12 - No communication between cards
  • F13 - Drying thermistor open/short circuit
  • F14 - Drying element faulty
  • F17 - Interlock error
  • F18 - Communication error
  • H20 - Not filling. Check tap, hose and inlet valves
Fridges and Freezers
  • F1 - Freezer thermistor open circuit
  • F2 - Freezer thermistor short circuit
  • F3 - Fridge thermistor open circuit
  • F4 - Fridge thermistor short circuit
  • F7 - Evaporator thermistor open circuit
  • F8 - Evaporator thermistor short circuit
  • F9 - Temperature set switch open circuit
  • FA - No feedback from Baffle
  • FB - Fridge Baffle motor operating continuously
  • FE - Defrost time out
Dishwashers
  • F10 - Fill or empty time out. Check that the hoses are not kinked, that the taps are on or whether the drain pump or hose is blocked.
  • F11 - Heater timed out. The heater has not reached the required level.
  • F20 - Temperature under range
  • F21 - Temperature over range
LCD Dishwasher Models
  • A01 - Float switch
  • A02 - Open/Short circuit heater relay
  • A03 - Short circuit on thermistor or Time-out drain- Check filter for blockages then book a repairif the problem persists.
  • A04 - Unable to reach or sense temperature within 70 minutes
  • A05 - Pressure switch has not been reset
  • A07 - Open/Short circuit wash motor triac
  • A08 - Open/Short circuit auxiliary wash motor triac
  • A09 - Open/Short circuit with main wash traic
  • A10 - Open/Short circuit fill valve traic
  • A11 - Half load valve traic or alternating motor action
  • A12 - Open circuit heater rely
  • A13 - Open/Short circuit dispenser traic
  • A14 - Drain hose too low causing syphoning. Check drain hose.
  • H20 - Check tap and pressure of incoming water.
Hotpoint Tumble Dryers
  • F1 - The level of required dryness has not been reached within the time period. Check that the correct programme has been selected
  • F2 - Thermistor or sensing circuit failure
  • F3 - Heater plate over temperature. Check the filter and vent hose for a possible blockage
...Follows--->
on Jan 10, 2010 | Hotpoint Ultima WF860 Front Load Washer
I keep getting error code F-14 on Hotpoint condenser dryer model CTD85
Hi.
F14 means that control board does not sense that machine is heating:
When you get F14 the fault is usually either the thermistor or the heating element (electric dryer). Both parts are tested removing the part from the dryer and reading impedance at the part contact. If the part returns infinity, then the part is defective. If you need to contact a qualified technician use the phone number listed on your owners manual or check Hotpoint website.
Regards.
Ginko
Sep 20, 2011 | Dryers
I purchased this machine last year now after ending the programme i.e.washing door is not opening and it is showing error 14. Could u please help me out. Regards
Hi.
The fault E14 on Hoover washers indicate a problem with the heating circuit. Element, Thermistor and Central Control unit must be tested.
About error codes and troubleshooting Hoover appliances see the links below:
Hoover After Sales Service - Online Fault Finder
(Hotpoint/Creda/Indesit/Ariston Error Codes)
If you need parts or diagrams see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
The sellers apply to USA market. Elsewhere see your local hoover distributor.
If you need to call a technician ring the customer service number listed on the owner manual or check your local Hoover website.
Regards.
Ginko
Sep 15, 2011 | Hoover Washing Machines
Heater has been tested but does not heat
Hi.
Check the thermistor, it is connected in line with the heater. If thermistor reads open at the multimeter set on impedance, there will be no power to heater. Depending on model there may be more than one thermostat (thermistor and cut-off). If the problem is not a thermostat, check wiring and test the control module.
Regards.
Ginko
Aug 06, 2011 | Zanussi Dishwashers
Errorcode EE in display. Whats wrong?
E1 - Freezer thermistor open circuit.
E2 - Freezer thermistor short circuit.
E3 - Fridge thermistor open circuit.
E4 - Fridge thermistor short circuit.
E7 - Evaporator thermistor open circuit.
E8 - Evaporator thermistor short circuit.
E9 - Temperature set switch open circuit
EA - No feedback from Baffle
EB - Fridge Baffle motor operating continuously
EE - Defrost time out
This was the only code listing with an EE error code - which is a Hotpoint - so if your's isn't a Hotpoint it is probably incorrect.
If you do have a Hotpoint Refrigerator then either the defrost timer is not functioning correctly or your heater element is malfunctioning.
Jun 20, 2011 | Refrigerators
I have a hotpoint fridge freezer model ff92ys the freezer is running ok but the fridge isnt cold enough i try to set it at +4 but it just sets itself back to +20 please help
The thermistor has probably failed. I had the same problem with my FF92s fridge/freezer. I replaced the thermistor and hey presto it works again.
The thermistor is loacted behind a removable panel inside the freezer section of the fridge/freezer. You also have to remove a polystyrene cover and a further metal cover to get tp the thermistor. Pull the metal cover from the left as it has wires attached to it on the right hand side. The thermistor is available to buy online, just google it.
Feb 05, 2010 | Amana ABB2227DE Bottom Freezer...
Zanussi refrigerator/freezer model ZX99/5
I had the same problem...it was a defrost problem in the freezer....mad i know...fridge doesnt work but freezer does...so its the freezer problem right!!!
This is how i solved it....there is fan behind the freezer compartment....you need to remove all the freezer draws then the plate at the back of the freezer compartment(everything is accessible from inside the freezer only) once removed you can put your hand up inside the gap(make sure power is off and unplugged) just in reach is the fan which you should be able to rotate with your fingers...mine was covered in ice and not able to move as a result the cold air couldnt be blown up into the fridge(the only thing controlling the air into the fridge is a flap and depending upon what fridge setting you have this determines how much cold air its letting in.)
If the fan has been frosted up you need to defrost the freezer....and source a new defrost sensor.
hope it helps.
Feb 24, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Hotpoint fridge too cold!!
Hi John,
There had been changes in the system recently, and not all answers are being displayed.
Now I do not know where to find your original problem.
If you find any link to the thread in your old emails, copy and paste it here , so that I can track back the problem.
When fridge is freezing inside that can be caused by:
Bad temperature settings.(temp too high)
Bad climate conditions (very hot outside and fridge set to lowest temp)
Problem with evaporator system at the back of the fridge.
Faulty thermistor, not detecting when temp. is too low.
Compressor problems.
Try moving the fridge from the wall, this sort out many problems with condenser/compressor and evaporator.
If there is Ice inside also remove ice to get back to normal.
If that does not work, it is either the compressor coming to the end of its life, or a faulty thermistor.
I will try to find the original thread, I suggest to complain with fixya, we have had serious disruptins since the new Fixya system started to work.
Nov 01, 2008 | Refrigerators
Hotpoint Fridge freezing the food.
If you give me the model number I can find an exploded view, alternatively enter model number here to get the schematics.
Oct 26, 2008 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
