Question about JVC AV-48WP30 48" Rear Projection Television
Red and Blue shadowing (Where are my 3d glasses)
Can anyone help, JVC AV-48WP30 Rear Projection with a red (mostly) and a blue shadow on the picture. If I know the parts that have failed or the solution I might be able to fix at home. It happened while my son was watching, he heard a snap and the pic went to the (Bad 3D mode) red and blue shadow. Many thanks in advance for any help. TJ
    President:
  • 3,130 Answers
There are two convergence IC's that are bad and need to be replaced, as this happens to almost every rear projectionj set ever made. They are stand up IC's , on a heatsink and they start with STK. They are soldered into place and this set has no user replaceable parts inside of it. If you have no solid state repair experience, you really should call out a trained tech to assist you in this repair. A TV set is no place to be diggin and experimenting inside of.
Posted on Sep 24, 2006
My JVC wont converge the red lines so half my screen is good while the other has red lines. What should I do? Thanks A lot
The tv 100% have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors picture shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | JVC AV-48WP30 48" Rear Projection...
My jvc model # av-48wp30 tv has a blue shadow
Convergence needs repair. The AV48WP30 convergence repair kit from www.tvrepairworld.com has the parts and the CD with step by step repair instructions.
Aug 08, 2010 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
JVC 48 in rear
Probably the projection guns (my JVC had them fail on me). It started that way and eventually I had a triple image of what was on TV, one in red, one blue, one yellow, and all slightly offset from each other. The fix was new projection guns (thankfully it was under warranty as they were about $300 each).
Aug 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Red and green shadows
Your tv has a convergence board problem. Have a technician replace the convergence IC's.
Jul 08, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problems?
If you know how to solder on printed circuit boards Sure, easy repair.
Jun 02, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence
Then it is likely the pre-amp transistor that controls the red is shorted out.
hopefully you have extended warranty.
there is a trick to likely get them aligned anyway if this is a tube tv.
Jan 12, 2008 | JVC AV-48WP30 48" Rear Projection...
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
JVC AV-48WP30 48" Rear Projection Television Logo
77 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
