Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony Trinitron has solid green screen
I turned tv on this morning and the screen is solid green. I have sound but only see green. I have a dvd player hooked to my directv box and i can watch a dvd perfectly but when i stop the movie, the screen goes back to solid green.
  • Anonymous Dec 02, 2008
    it is a solid green color nothings hooked up to it
CompuGuy44
  • 432 Answers
SOURCE: Trinitron KV-36FS13
The problem is in the standby power section. Check the fuse, R607, or burnt IC601, fuse R612 and VD relay 601 should show open. Its possible it could be the high voltage area of the power supply. You can try unplugging the set and cable and let it sit 4 to 6 hours. This is a hard reset. If it still doesn't turn on after the hard reset and the fuses and relays are fine, and you don't smell anything or see anything burnt. Then you'll need to call a TV repair man. They normal start around $150-$200 to fix the set. I hope this helps.
Posted on Jul 10, 2007
SOURCE: Sony Trinitron 36" TV
reset television by holding reset an your remote press the power button an tv panel after it turns itself on and off release reset
Posted on Jan 13, 2008
BMW Rider
  • 232 Answers
SOURCE: Sony Trinitron - Picture Disappears
Hi, IK circuit is engaging which basically means the picture tube is getting tired, the only "fix" is temporary (may get another year out of it). You have to increase the "screen control clockwise".
Remove back of set, follow large black or red wire attatched to picture tube down to the flyback transformer, mounted on flyback are two black controls, one is focus (leave it alone) the other is "screen", adjust it clockwise approx. 1/4 inch, remember that this is a high voltage circuit so use one hand in the set the other hand out of the set at all times,any questions ? e-mail me back, good luck, BMW Rider
Posted on Feb 27, 2008
welcomejee
  • 10594 Answers
SOURCE: Green symbol AV2 won't go away! Sony Trinitron KD-28DL11U
You need to have original Sony TV remote and press Display button on it, on-screen display will disappear.
Posted on Nov 25, 2008
projdoc
  • 2237 Answers
SOURCE: I have a UK sony trinitron kv-32wf1u with Black Screen
it could be one of the closed-caption settings. make sure the cc is off. if the problem remains, you may have tuner issues.
Posted on Jul 31, 2009
Sony Trinitron screen turned pink
Hello
Absence of green is the problem. You see mixing of red and blue, which will look like pink.
the fault must be of its video output card. This card can be located at the neck of the picture tube. Check this card, for any loose solder. This is a common problem seen in most CRt based Sony TVs.
Just resolder all the suspected solder points on this board, by applying a little more solder, without making any solder bridge short in between adjecent solder terminals.
images of two models of sony trinitorn TVs, [back cover opend] has been attached here. you can see the boar under suspection, along with the picture tube neck. [See the rectangulat printed circuit board attached to CRT base]3_9_2012_2_12_06_pm.jpg3_9_2012_2_12_38_pm.jpg
Mar 08, 2012 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Blue colors are now green.
It sounds connections are not matched yet. Make sure connections are green to green, red to red and blue to blue in dvd player and tv are correct.
Try another component video cable.
If problem still exist, test dvd player to any other tv, found ok then component input of this TV is bad, need to get it repaired.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Dvd's are playing black & white via sound surround system
Check first your dvd player settings if it is in PAL or NTSC.
Mar 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 25, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
No image onscreen Sony Trinitron model# KV-27S25
Hi
try to connect the Antenna then hearing the sound what comes on..
Thanks!
Oct 24, 2008 | Televison & Video
Sony trinitron TV KV-27TS27 screen remains dark
how do i adjust the brightness if i dont have the controler?
Jul 24, 2008 | Sony FD Trinitron WEGA KV-27FS200 27" TV
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Sony Trinitron Flat Screen 15" TV - Sound not working, image pauses every 5 seconds
Sounds like a DVD player issue. The TV is all analog and can't replicate issues like that.
Jan 28, 2007 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Solid green screen
Is the green really bright with small white lines in the screen?? If it is its probably a shorted picture tube. That is if you still have sound. If you have no sound its probably a power supply problem in the sweep section of the set. This is not a repair for a consumer to do as its a solid state set and there are no user serviceable parts inside these sets. Get a service person to assit you with this repair. Good Luck
Jul 01, 2006 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
290 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
