Photoshop dont work on vista - Computers & Internet
  • 19 more comments
  • afarrellhome Nov 02, 2008
    I have elements 7 and havf tried re installing still same problem I beleive it is layer related
    Vista and photo shop elements 7,the clone stamp etc have no effect on the picture but shows in the history
    Elements 7 is vista based
    Elements 7/Vista there is a problem in the software
    vista home premium/photo shop elements 7
    the problem can be resolved it is layer relatedso I am lead to belive
    already tried with no luck
    some body at presto(dell software) said so.
    same problem
    have already tried this the problem seems to be a block by Vista
    every thing else is ok
    still trying
    no change
    yes every thing for elements 7
    I am running elements 7 the patch is for 5
    no luck yet
    is there an answer?
    made no difference
    the problem is a conflict between adobe & vista paintshop pro is fine
    the problem lies somewhere between my laptop? Vista?& adobe
    still the same
    Scholar:
  • 155 Answers
Have you tried reinstalling it by right-clicking the setup file and clicking 'run as administrator'. This solves some compatibility issues with Vista. May not really be your case but you can give it a try.
Posted on Nov 02, 2008
  • 90 Answers
Who says that Photshop did not work for vista?? I am using it quite often
  • 19,396 Answers
Photoshop does work on Vista , you just need to have the right version.
Sure, if you are trying to install Element 7 for Windows +XP on Vista, that does not work.
Try downloading a newer version from here and installing , so to test the system.l
Download from : Free Adobe Photoshop Download
Also remind that you need to run the software as administrator.
To run as administrator you can click the right button of mouse on the installer file, and chose from the drop down menu "run as administrator".
  • Ginko
    Ginko Nov 02, 2008
    Hey there, I did not read your following comment!.
    If you can use the Clone stamp option Photoshop is working, that means that you are doing somethiong wrong.
    Photoshop (even elements) is a quite complicate software, if you do not follow the instructions, a determined command as clone stamp may have no effect.
    First remember that you have touse the alt key when you use clone stamp. See the following:
    YouTube - You **** at Photoshop #3: Clone Stamp and ...
    Then remember that if you are working on a layered image, the stamp , select and more tools will work on current layer, if current layer is blank you get no effect.
    Go to the LAYER MENU and chose FLATTEN IMAGE before using the tool.
    Some tools also work only on RGB picture, go to properties on the IMAGE menu and ensure that picture is in rgb mode.
    Genius:
  • 1,269 Answers
Try to download the Adobe Photoshop Elements HERE. Re-do your installation.
    Scholar:
  • 155 Answers
Does  your system have this  Adobe Photoshop Elements 7
  • 2GHz or faster processor
  • Microsoft® Windows® XP with Service Pack 2 or 3 or Windows Vista®
  • 1GB of RAM
  • 1.5GB of available hard-disk space
  • Color monitor with 16-bit color video card
  • 1,024x768 monitor resolution at 96dpi or less
  • Microsoft DirectX 9 compatible display driver
  • CD-ROM drive
  • Web features require Microsoft Internet Explorer 6 or 7 or Mozilla Firefox 1.5 through 3.x
  • for
  • Adobe Premiere Elements 7
    • 1.8GHz processor with SSE2 support; 3GHz processor required for HDV or Blu-ray; dual-core processor required for AVCHD
    • Microsoft Windows XP with Service Pack 2, Windows Media Center, or Windows Vista
    • For Windows XP: 512MB of RAM (2GB required for HDV, AVCHD, or Blu-ray)
    • For Windows Vista: 1GB of RAM (2GB required for HDV, AVCHD, or Blu-ray)
    • 4.5GB of available hard-disk space
    • Microsoft DirectX 9 or 10 compatible sound and display driver
    • DVD-ROM drive (compatible DVD burner required to burn DVDs; compatible Blu-ray burner required to burn Blu-ray Discs)
    • DV/i.LINK/FireWire/IEEE 1394 interface to connect a Digital 8 DV or HDV camcorder, or a USB2 interface to connect a DV-via-USB compatible DV camcorder (other video devices supported via the Media Downloader)
    • QuickTime 7 software
  • 89 Answers
Hey man, please right click the photoshop icon and then select properties
and then select compatibility tab and then chek 'run this program in compatibility mode'photoshop dont work on vista - 5dd2abb.jpg
and run the program.
  • 2 more comments
  • Pritish Singh Nov 02, 2008
    if this doesnt solve your problem let me know.
    what happens when you run photoshop?
    Do you have DirectX 9 installed?
    please install it first.
    If you have any plug-ins installed, especially ones from
    Alien Skin, such as Snap Art, or Essentials 2 from onOne Software,
    remove them and see what happens.
  • 4,889 Answers
Ok.. how do you kow its layer related..? Whats the error message that is being displayed..
  • 1 more comment
  • eagle338
    eagle338 Nov 02, 2008
    Sorry about that didnt read your comment about the problem..
    Re-check Preferences......... Edit > Preferences > Display and Cursors....
    check "Painting Cursors" is to 'Normal Brush Tip' (You can still have
    "Show Crosshair in Brush Tip" at the same time, but try it with and
    without);
    check "Other Cursors" is to 'Standard'
  • eagle338
    Ok.. Thats wierd.. Did you read the post by Fonehacker. Sounds like its worth a try.. Run it in compatibility mode for Windows XP
  • eagle338
    Well what you can do now is complete removal.. Including manual removal of any registry entries and then re-installing.. To manually remove the reg entries open registry editor(Click start->Run->type "regedit")Then search for the elements photoshop and elements seperatesly. This will Ensure total clean up. Then re-install and see if it works..
  • 94 Answers
Hello, as said before, it seems that the version might not be compatible with Vista.
Which version are you using, it would be more helpful to accommodate a solution to your problem knowing that.
I would suggest uninstalling, restarting the computer, and trying to install again, if the version is indeed compatible.
  • 3 more comments
  • Tamir Meiri
    Tamir Meiri Nov 02, 2008
    I'd also suggest going to the website:http://www.microsoft.com/windows/compati...
    And check if the software is indeed compatible with Vista.
  • Tamir Meiri
    Do you have the most updated drivers for your Graphics card?
    Also, try checking if your DirectX is the latest version. If not, try and update it and see if there's any results.
  • Tamir Meiri
    Also, try the Adobe website:http://kb.adobe.com/selfservice/microsit...
    Search the knowledge base, choosing Photoshop Elements on the right, for anything relevant to your issue.
  • Tamir Meiri
    it seems as though one of the brushes/filters hasn't been installed properly.
    Do other things work properly for you in the application?
  • Tamir Meiri
    If everything else is okay, it seems as though some of the preferences of the filters may be corrupt - try checking that under file-preferences.
    If nothing there implies anything, then perhaps, as I said, the brushes/filters were installed badly.
    Try taking the installation CD and see if you can find the Brushes/Filters directories there, and copy them to the installed location on your hard drive.
    Brigadier General:
  • 3,614 Answers
What ver. of photoshop do u have. could be the version you have does not supported by your OS. check and inspect if the product support.
  • 535 Answers
Ya due to software problem photoshop besd on windows xp in futher this facilty avlible photoshop is disined for only xp & windwos 98 for that y its not suppot in vista compny is not davloped for vista in futher that will be devlop till then we will wait 4 it
  • sandip panchal
    sandip panchal Nov 02, 2008
    i m studio man i tryed everyting my brother so u have to wait for it for the futher devlopment
    Genius:
  • 3,422 Answers
HI,
Please make sure that the photoshop version you are using supports vista.If your version supports vista then please reinstall the photoshop once again.
This will fix your problem.
If you need anymore help let me know.
Samsung scx-4521f will not scan. Smar Thru will not download vista computer
Do u have windows vista driver for your machine if u dont have you can use any other scanner driver like photoshop
Jan 26, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I can't install my Adobe Photoshop 5.0 Limited Edition, mine is Windows Vista..
Adobe Photoshop 5.0 is not, Vista compatible.
Get a newer version say CS4, compatible to Vista & Win 7.
Jul 23, 2010 | Adobe Photoshop Limited Edition 5.5 Full...
Won't work with Vista 64 bit
Hello
I am running Windows Vista 64 bit also and finding out that there are a lot of programs that won't run on a 64 bit machine due to the fact they are not supported for 64 bit, listed below is info to your problem,
Photoshop Elements compatibility with Windows Vista This TechNote lists which versions of Adobe Photoshop Elements are compatible with Microsoft Windows Vista.
Photoshop Elements Version Compatible with Windows Vista (32-bit)? 6.0 Yes 5.0 Yes
Note: You must download the Photoshop Elements 5.0.2 update to ensure compatibility with Windows Vista.
4.0 No 3.0 No 2.0 No 1.0 No
Note: For the versions of Photoshop Elements that are compatible with Windows Vista, the 64-bit editions of Vista are not supported. Adobe Technical Support can assist you with the features of Photoshop Elements and with issues that also occur in supported operating systems. Technical Support cannot, however, assist you with issues that occur only on the 64-bit editions of Windows Vista. Instead, you can use the following support options on the Adobe website:
  • The User to User Forums, on which you can enter your problem or concern to see if another Adobe user can offer advice. Access this resource at www.adobeforums.com.
  • The Support Knowledgebase, which contains solutions for issues that occur on supported operating systems. Access this resource at www.adobe.com/support/photoshopelements.
dmg49
Apr 15, 2009 | Adobe Premiere® Elements 3.0 Full Version...
Will Adobe photoshop 6 or 7 work with Vista?
Adobe has patches for photoshop to work with Vista machine. check with adobe and see if there are download to patchup the software.
the attached link is adobe comparable porduct for Windows Vista
http://www.adobe.com/support/products/pdfs/adobe_products_and_windows_vista.pdf
Jan 27, 2009 | Adobe Photoshop 7.0 for PC
Hi, there's a problem when i download free photoshop 7 ? My Windows is Vista.
The windows vista doesnot support all the features of photoshop 7
Try to use a latest version in vista
Jan 05, 2009 | Adobe Photoshop 7.0 for PC
Photoshop does not work on vista
When Adobe began shipping Photoshop® Elements 5.0 and Adobe Premiere® Elements 3.0 software in September, final versions of Microsoft® Windows® Vista were not available to complete the testing required to ensure compatibility.
Shortly after Windows Vista becomes available to consumers, Adobe plans to release updates for Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 to provide compatibility with Windows Vista.
Updates for existing Photoshop Elements 5.0 and Adobe Premiere Elements 3.0 owners will be available as a free download from adobe.com, and updated Vista-compatible versions of Photoshop Elements 5.0 and Premiere Elements 3.0 will become available in the same timeframe.
tnx 4 using fixya!!!
Nov 02, 2008 | Computers & Internet
Roxio creator basic v9
Roxio is now version in 10
I am NOT sure but perhaps the v9 would not work with Vista.
http://www.roxio.com/enu/products/creator/suite/overview.html?rtrack=homeFlash
Aug 15, 2008 | Adobe Photoshop 7.0 for PC
Why adobe?
because you only asked for it.. " The printer is working but I need PhotoShop software that will work withe Vista."
you need photoshop software what works with vista or photomart software that works with vista??
please let me know
Aug 13, 2008 | Office Equipment & Supplies
PhotoShop Elements 3.0
I already found a solution. I am not home at the money so I cannot tell you exactly what I did, but there was something under the system portion of Vista that I had to add PrintMaster to so that it would work. I am able to now use the program.
Thanks!
Apr 21, 2008 | Adobe Photoshop 7.0 for PC
How to edit photo in photoshop...
the best i can tell u that u abobe is useless. i think that u have installed which operating syestem.plze verify ur os and the best of ur busineess is u shuld installed vista othervise co to intel or microsoft website or toshiba acmea.com
Jan 14, 2008 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
David Payne
David Payne
