Question about Amana NAV5805A Top Load Washer
Clorex spots on colors
After we wash white clothes and wash colors we get clorex stains on them we have amana modle no nav5808aww can you help
SOURCE: my amana isn't washing away all the bleach in 1 load
try and make sure your filters are not blocked ,therefor retaining some of the bleached water in you washer when you wash other times
Posted on Jul 20, 2012
0 characters
1 Points
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
White clothes come out stained
Jan 20, 2014 | Miele Washing Machines
How do I clean the washer to eliminate the dark spots of lint and dirt on laundry?
Prevent lint from clinging to clothes by adding 1/2 cup white distilled vinegar to the wash cycle.
To remove soap residue that makes black clothes look dull use white distilled vinegar in your final rinse.Get stained white socks and dingy dishcloths white again. Add 1 cup white distilled vinegar to a large pot of water, bring it to a rolling boil and drop in the articles. Let soak overnight. Some stains on clothing and linens can be soaked out using equal parts milk and white distilled vinegar.Before washing a mustard stain, dab with white distilled vinegar.ttack spaghetti, barbecue, or ketchup stains with a white distilled vinegar and water solution.Remove perspiration odor and stains on clothing, as well as those left by deodorants, by spraying full-strength white distilled vinegar on underarm and collar areas before tossing them into the washing machine.Forgot that you left wet laundry in the machine and it now smells moldy? Pour a few cups of white distilled vinegar in the machine and wash the clothes in hot water. Then run a normal cycle with detergent.Remove smoky odors from clothes by filling the bathtub with very hot water and 1 cup white distilled vinegar. Hang the garments above the steaming water and shut the door so the steam can penetrate the fibers.Keep the steam iron clean and in good working order by getting rid of mineral deposits in steam vents and spray nozzles. Fill the water chamber with a solution of equal parts white distilled vinegar and distilled water. Set it in an upright position and let it steam for about 5 minutes. When the iron is cool, rinse the tank with water, refill and shake water through the vents onto an old cloth. Test before using.Remove scorch marks from an iron by rubbing it with a warmed-up solution of equal parts white distilled vinegar and salt. If that doesn't work, use a cloth dampened with full-strength white distilled vinegar.Remove musky smells from cotton clothes by sprinkling them lightly with white distilled vinegar and then pressing them.Get water and salt stains off shoes and boots by wiping them down with a solution of equal parts white distilled vinegar and water.Give patent leather shoes and bags a better shine by wiping them down with white distilled vinegar.Get cleaner laundry! Add about 1/4 cup white distilled vinegar to the last rinse. The acid in white distilled vinegar is too mild to harm fabrics, yet strong enough to dissolve the alkalies in soaps and detergents. Besides removing soap, white distilled vinegar prevents yellowing, acts as a fabric softener and static cling reducer, and attacks mold and mildew.Eliminate manufacturing chemicals from new clothes by adding 1/2 cup white distilled vinegar to the water.Remove soap **** and clean the hoses of your washing machine with white distilled vinegar. Periodically run the machine with only a cup of white distilled vinegar in it-nothing else added to the wash cycle.Bring out bright colors by adding 1/2 cup white distilled vinegar to the rinse cycle.Fluff up wool or acrylic sweaters (hand- or machine-washed) and rid them of soap smell with 1/2 cup white distilled vinegar in the last rinse water.
Get rid of the tiny holes left along the hemline when you take out the hem of any garment by moistening a cloth with white distilled vinegar, placing it under the fabric and ironing.
Oct 31, 2011 | Whirlpool Washing Machines
What is thebest tepmerature for white garments
Set your water temperature to "cold" on your clothes washer. Unless your clothes have oil or grease stains, cold water is usually adequate to clean white and colored clothes. In fact, washing clothes in cold water allows fabrics to retain their color and strength longer.
Feb 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
Washer leaves stains on clothing
Many times when we cook in the kitchen, we get splattered with oils that aren't easily visible. Very often these oil spots pick up dirt from the wash water. These stains don't usually get noticed until after the clothes have been dried. The best thing to do is to rub detergent or stain remover right on these spots and let them sit about half an hour. Then rewash the clothes in as hot water as the material can take afterwards.
Aug 11, 2008 | Whirlpool Washing Machines
Rusty stains on all white clothes washed
I don't think the washer is at fault; the clue is 'Used very little.' I think the rust is originating in the water pipes serving the washer. The only help there is to run one machine with no clothes in it (wasting water) or putting splitters on the faucets and flushing the lines into a sink or other drain. To remove rust stains from WHITE (!) clothing and many synthetics, buy a product named 'Whink.' It is available in many drug stores, super markets, etc. in the area where one finds other laundry items.  It is fairly safe to use (with precautions) but keep out of reach of kids.
Jul 26, 2008 | Kenmore 24032\24036 Top Load Washer
Rust stains and bleach spots.
I'm sorry but the white spots will be due to bleach. It may be that there was undissolved bleach in the washer after the first load. Maybe some of it came out with the whites and lay in wait in the basket.
I doubt the makers would guarantee anything for 7 years, so no free basket or installation is likely. Seems there is a chip in the enamel and dampness / water from the previous wash days before sits there collecting iron as rust particles.
For the time being you could try rinsing the machine out before the first load. That might prevent the rust marks or reduce them.
May 01, 2008 | Kenmore 22422 Top Load Washer
Amana NAV5805A Top Load Washer Logo
32 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
