Question about Fuji FinePix S2 Pro Digital Camera
Battery problem S2 pro
I have Two S2 pro camera's and one has a problem with the battery. After taken one picture it always shut down. After pushing the "take picture knob" half down, he turn's back on. You can take pictures like this the whole day. So i replaced the battery's from one camera to the other and in the other camera is no problem. Can anyone give me a solution for this problem.
Thanks in advance.
Ivo
  • gcertain Apr 04, 2009
    Same problem ... if i turn the camera off and turn it back on again It will let me take another shot but then the battery will die again after then next shot.
  • daV749s May 19, 2009
    I got the same problem start from this year. I used rechargeable batteries (set of 4 NiMH 1.2V 2700mAh) since I own this camera, but it won't happen when with a set of fleshly charged one.
Check your battery tray and that it has clean contacts. I'm sure you will find that if you place some pressure on the tray to push the batterys in just that fraction more when you take a pic that it will work fine and wont do the annoying beep and shut off. Maybe it has become a little loose over time and isint quite as tight on the contacts as it used to be.
Posted on Apr 21, 2009
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
Was scrolling through pictures recently taken. camera suddenly froze - can't go forward , can't go back, can't turn off the power, can't take a picture -- the power light just stays on and none of the...
Taking out the battery would do no harm to your pictures. Also in some models of cameras you can force it to shut down by holding the power button for 10 seconds. Might be worth a try . If not you can always remove the battery.
Oct 27, 2010 | Kodak EasyShare M1033 Digital Camera
I am not getting an image either through the viewfinder or on the LCD monitor. The display is clear and bright and the batteries appear to be fine.
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 26, 2010 | Canon PowerShot S2 IS Digital Camera
I keep charging up the battery, but it only takes ...
Rechargeable batteries don't last forever and if yours are the originals then they're long overdue for replacement.
Fit new rechargeables, and always recharge the battery before storing the camera.
May 20, 2010 | Canon PowerShot S2 IS Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 - image records in black
Could be CCD Failure ... known as ' Black Screen of Death'.
Have CCD cleaned at a reputable camera (not chain) shop and they'll test it.
Fuji were replacing units suffering this problem at one stage.
May 05, 2008 | Fuji FinePix S2 Pro Digital Camera
S2 pro electronic malfunction?!?!
If your lithium batteries are depleted, having them in the camera will shut it down. A common cause of depleting the lithium batteries is leaving them in the camera while using the AC power adapter. For some odd reason, the Fuji engineers did not build in a disconnect circuit when on AC power. You should always remove the lithium batteries when using the AC adapter.
The Fuji S2 will run fine without the lithium batteries, except that you will not be able to use the built-in flash. Fuji recommends that as an "emergency" procedure, but I ran my S2 off NiMH AAs only for my heavy use over four years with no adverse effects.
If you buy the MB-16 battery pack or one of the modified versions for the S2, you would be able to use 8 AA batteries to power the camera, including the built-in flash, and never touch another lithium battery. The MB-16 itself does require some modification in filing off edges around the base and building up material around the post to firmly engage the switch you found.
Sep 29, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
333 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Tony
Are you a Fuji Camera Expert? Answer questions, earn points and help others
