Question about Sony DVP-C650D Multi-disc DVD Player
Sony DVP-D653D My sony DVP-C653D would not power-on. This is after lightning that damaged few electronics in our house. Is there a specific component inside that a lightning strike damages?
  • 859 Answers
SOURCE: unlocking Sony DVP-FX820 portable dvd
Sony has designed this player so it cannot have the region code changed, it is hard wired into the board as part of their copy protection scheme.
Most users have rated this player as 'junk' (sorry to be the bearer of bad news) and should be replaced.
Maybe you can sell it on Ebay.
My suggestion is that the less expensive the player the better off you will be in the long run as the cheaper brands and models use DVD drives meant for PCs and Macs. More expensive models have proprietary drives, such as Sony, and cannot be manipulated and are not very versatile in recording media and or playing copyright hacked copies of DVDs even if you own the original DVD but has been scratched.
The courts are still trying to figure out these protection measures as they are not fair use in terms of you the owner of a DVD and wanting to make your own backup copy for the kids to use.
Posted on Jun 15, 2008
I have not got a problem with the screen, it works fine, I just want to make it multi regional, so need the codes for it please?, and the player type is SONY DVP FX 720
Posted on Jun 24, 2008
  • 657 Answers
SOURCE: Sony DVP-FX810 Portable DVD Player, region code 4 to mutiregion code.
1. Switch on the player
2; open the CD compartment
3. Enter the following code (using the remote): 2812
4. Highlight the region
5. Change to 9 (for Multi-region) using the 'Enter' button
6. Hit 'Clear' to exit
check with different region DVD
Posted on Oct 03, 2008
  • 488 Answers
try this:
• Turn On the unit with the remote controller
• Wait until "no disc" appears in the unit's display
• Press Pause, 3, 1, 4, 1, 5, 9
• The word "CODE" should appear in the display
• Within five seconds, press the key that corresponds to the zone you want i.e. 0 for region free, 1 for region 1, 2 for region 2 and so on
• Again, within 5 seconds, press Pause and Power
hope it helps!
Posted on Oct 31, 2008
SOURCE: Sony DVP-FX820 Multi-Region/Zone hack/unlock
Any News About the Sony DVP-FX820" Region/Zone hack?
Posted on Nov 04, 2008
  • 10421 Answers
SOURCE: Sony DVP-SR200P US edition region free code
Hi there, please get the code here :
Best Regards, Jay_fv78
Posted on Feb 27, 2011
0 characters
1 Points
Having trouble connecting Panasonic TH46PZ80U TV with Sony DVP-SR320. Component Input No.1 and 2 will not recongize Sony DVP SR320 DVP Player. It will work when i connected to Video No. 1 Input. As i...
1) you must read the instr. manual and see the connection diagram, and test the cables if are ok
2) proceed after your are shure and test the connector for dirty, oxide, and clean it.
3) if the problem persist you must call to the sony customer service, in order to provide assistance from ONLINE via chat or phone.
God bless you
Jul 12, 2012 | DVD & Blu-Ray Players
Brand new sony portable dvd player dvp-fx820/p's motherboard got damaged according to sony people, it was an accident by my daughter she was drinking her apple juice and accidently a few drops just...
Liquid and Juice though incompatible with electronics (don't mix well) are
not always deadly. BUT you do need to gid rid of them completely. First
off, remove the unit battery and do not apply anymore power to it (via
the AC adapter). Because any liquid can easily find its way inside your unit,
(unseen to the naked eyes) you may have to have someone with electronics skills
taking it apart and using a soft tooth brush dipped in fresh water and removing
the sticky sugared liquid completely. Shake the board to get rid as much of water
from it and allow it to dry for a day. I have fixed many electronic devices
successfully this way.
Jul 15, 2011 | Sony DVP-FX820 DVD Player
How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try
May 15, 2010 | Sony DVP-NS330 DVD Player
Sorry, it's not possible. The DVP-FX810 is one of many Sony players where the region coding cannot be hacked without making internal hardware changes. To do so is not cost effective when you can buy perfectly good multi region (or at least hackable players) brand new for £30 including a few Sony models which can be hacked (e.g the excellent DVP5980 with progressive scan, USB input, DivX and HDMI upscaling, still widely available at clearance outlets for under £30).
If you want hackable players avoid Sony and Panasonic unless you have found a model specific hack prior to purchase as many of them have the same limitation.
Sorry there's no fix on this occasion, but I hope that you've found my reply to be of some use. All I ask in return is that you rate my answer.
Nov 01, 2009 | Sony DVP-FX810 Portable DVD Player
Sony DVP FX720 not playing DVD's - also no power lead
hi we had a similar problem as we lost our power lead but we found them on sale at Ebay, brand new for £12 free p& p.
Jun 23, 2009 | Sony DVP-FX720 Portable DVD Player
Sony DVP SMPS unit fault
You can get complete power supply as one part from Sony. You can't repair it on component level because components are not available.
Jul 18, 2008 | Sony DVP-NS575P DVD Player
DVP-NC665P power surge.
I would first check to see if it had a blown fuse..
even if sony doesnt have the parts electronic companys sell common electronic parts like mcm electronics.
Sep 16, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Sony DVP-C650D Multi-disc DVD Player Logo
19 people viewed this question
Top Sony DVD & Blu-Ray Players Experts
Mando Mojica
Mando Mojica
Are you a Sony DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
