Question about Samsung Washing Machines
Samsung fault codes
Our Samsung H1245A 10kg washing machine stops at rinse cycle and displays error code AE before shutting down, it will then not come on again. If you hold on off button it will bring up error code for 12 secs and then shutdown. Sometimes it will reset over night but then fails again, can you offer any ideas before I go and buy a new washer.
SOURCE: washing machine fault
what does the rror code h6 mean on a daewoo washing machine
Posted on Jan 07, 2008
SOURCE: my lg intellowasher wd1290 error code OE
washer stops with soapy water, code displays OE. Help!!!!
Posted on Oct 19, 2008
SOURCE: F2 error code on my Kenmore Elite HE3 washer
Had this problem on our Kenmore machine.
This is what done.
1. Unplug the washer
2. Take of the toe panel in the front by removing the three screws.
3. Get a bunch of towels (I mean a bunch!!!)
4. The pump is in the center, and it has a plastic grip handle that one can unscrew to remove the filter. As you unscrew it, LOTS of water will come out. Be ready with the towels. A cookie sheet helps to collect the water too.
5. Clean the filter assembly.
6. If one wishes to check the inlet of the pump, remove the back panel, about 12 screws. (Note, the following works for replace the pump as well)
7. Remove the large bellow from the bottom of the tub that goets to inlet of the pump by removing the clamp
9. Lift up on the plastic cover that covers the wires that power the pump. There may be a small plastic catch that is lifted up as to allow the connector to become free.
8. Remove the Torx screw that holds that is the center just under the filter screen.
9. Pull the pump forward.
10. Unclamp the pump outlet hose.
11. Remove pump
12. Unclamp the large bellow on the pumps inlet and inspect for debris.
13. Clean pump and fitler w/o getting water on the pump.
14. Install in reverse order. Remember, it is much easire to put the inlet bellow and outlet hose on the pump before you put into the washer
Posted on Jan 11, 2009
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
localwonder
  • 6784 Answers
SOURCE: dE code on WM0642HW TROMM washing machine
HI, this is a Door Open Error.
Possible Causes are..-
* Door not all the way closed
* Loose electrical connections at door switch and pwb assembly(Control Board)
* Door switch assembly is out of order(Miss aligned)
* Gasket on door may be creased in
Most common issue here will be a defective door lock switch. check all causes before replacing the switch.
Posted on Jul 12, 2009
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
Error E1 for washing machine
Lots of info on E1 for different makes.
  • How to repair a Samsung washing machine with error code E1 ... https://www.quora.com/How-do-I-repair-a-Samsung-washing-machine... How do I repair a Samsung washing machine with error ... If your Samsung Washing Machine is showing error code E1 then ... How do I clear bosch washing machine error ...
  • E1 error in washing machine? ' Yahoo Answers https://in.answers.yahoo.com/question/index?qid=20131129013237AA7oiKP
    • RESOLVED
    • 7 POSTS
    • 6 TOTAL ANSWERS
    2013-11-29 · E1 error in washing machine? ... Haier washing machine error code E1? LG Wave Series Washer LE error message? Washing machine error code? ...
  • My washing machine is displaying an error code. What does ... www.samsung.com/my/support/skp/faq/1033803 My washing machine is displaying an error ... E1. Water supply error. ... · Check that the level of the drain hose is not lower than the base of the washing machine.
  • Related searches for Error E1 for washing machine
  • Samsung Washing Machine 4E and E1 Fault - Help & Advice https://www.northlondonappliancerepairs.co.uk/error-codes/samsung...
    • 4.3/5
    • 46 RATINGS
    Samsung Washing Machine 4E and E1 Fault. Samsung washing machine Not filling in allocated time error code 4E and E1 Fault.
  • Help & Troubleshootings - Haier ZA Products Website www.haier.com/za/help_and_troubleshootings/faq/washing_machine Help & Troubleshootings. ... Too much water in the washing machine ... Error Code-control panel display "E1" Question : Error Code-control panel display "Lock"
  • Samsung washing machine error code 4E and E1 Fault Not ... www.youtube.com/watch?v=cFlnxeB0P0g
    • BY HOW-2-REPAIR.COM
    • 9 MIN
    • 19K VIEWS
    2015-11-24 · Video embedded · ... machine-error-code-4e-and-e1-fault-not-filling-in-allocated-time/ Samsung washing ... Samsung washing machine error code 4E and E1 ...
  • Samsung washing machine error code 4E, E1, Fault Not filling www.how-to-repair.com/help/samsung-washing-machine-error-code-4e... Samsung washing machine Not filling in allocated time error code 4E and E1 Fault This is essentially a fill timeout error which will normally mean that either the ...
  • Hoover error code E1 - White Goods Help www.whitegoodshelp.co.uk > ... > Washing Machine Error Codes Hoover error code E1. ... You need to watch the washing machine to see when it aborts to get an idea which of the three areas to look at.
  • Jul 01, 2016 | Washing Machines
    Display has been playing up. A message reading 'EOS' was diplayed just now. The machine has stopped working ?
    Canon DLC: Article: Canon EOS Error Messages: An ...
    www.learn.usa.canon.com/resources/.../eos_error_msgs.shtml
    Canon Inc.Feb 6, 2012 - Canon has installed provision to display Error Codes in EOS SLRs for quite some time. Until fairly recently, the camera could basically display a single, or limited ... today's cameras do provide a wider range of possible read-outs, giving the ....Try removing the USB cable, and firing it normally to see if it now ...
    problems installing digital solution disk - Canon Community
    community.usa.canon.com/t5/PowerShot/problems-installing.../225
    How to Understand Hoover and Candy Washing Machine ...www.espares.co.uk > Advice CentreJul 1, 2014 - Home & Office ... If a fault is detected in your washing machine, an errorcode is likely to flash up. ... how to identify error codes in a Hoover or Candy washing machine. ... code if the machine has a problem and this will either be displayed ...Now what I'm going to do is disconnect the machine and take the ...Error message E03 - Hoover Advice Centre - Hoover Serviceservice.hoover.co.uk > Advice CentreShould the error code E3 appears it is warning that the machine is not draining. You can easily fix this problem by removing any blockages from the drain pump ...Hoover Optima Washing Machine ' OPH ' Fault Codes
    Dec 16, 2015 | Candy Domestic EVO14104L White 600 mm...
    Can anyone tell me what F06 error code means on the whirlpool 6th sense 10kg washer? and what to do about it as the screen is flashing but the door to the machine is locked. Thanks
    F06 Drive motor tachometer error This error occurs when the main control unit fails to detect the motor speed from the tachometeric generator fitted to the motor either through an incorrect resistance or the tacho is not correctly fitted into place. The machine will try to detect the reading several times before aborting the program ans shutting down with this error being displayed.
    When checking ensure that the drive belt and belt tension are okay as this can cause this error.
    • Check tacho resistance
    • check tacho placement
    • Check wiring for shorts
    • Check wiring harness connections between motor and main controller
    • Check drive belt for damage and tension
    http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
    May 26, 2015 | Whirlpool Washing Machines
    E8 front loader washing machines
    OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
    IPM: Integrated power module. The IPM controls the motor.
    If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
    If the motor stops working, in one direction ten times, "8E" Error is displayed.
    During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
    HOWEVER, the UK White goods website says:
    E8
    Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
    You can find more about your Samsung Washing Machine error codes at:
    http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
    or
    http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
    Jun 21, 2011 | Samsung Washing Machines
    Washer fault code 3E what does it mean
    during washing and rinsing when a motor restriction is sensed, the motor stops and then proceeds
    to the next waterflow action. if the motor stops working and this happens in one direction 10 times,
    the error code 3e will be displayed.you should be able to clear the error code by turning your washer
    off and on. or powering it down and then powering it back up. good luck!
    Feb 21, 2011 | Samsung Washing Machines
    Machine stopped mid cycle and green light flashing under green start button
    Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
    Hotpoint, Indesit, Zanussi error codes
    Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
    If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
    No Option lights?
    With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
    This information is vital, and needs mentioning when reporting a fault.
    Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
    Samsung error code 3E?
    3E - MOTOR RESTRICTION ERROR
    Hall Senior is sensed every 5OOms. 1 second after motor starts to work.
    If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once.
    During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed.
    During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error is displayed, When the motor Is told to stop because of an operating function. no error is shown.
    Power 81W OFF can clear the motor restriction error.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Aug 12, 2010 | Samsung WF328AAW Front Load Washer
    E8 error code
    8E - OVER CURRENT ERROR
    May 02, 2009 | Washing Machines
    OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
    The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
    LG themselves have some information on this error code..
    http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
    Jan 29, 2009 | Washing Machines
    Washing Machines Logo
    410 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
