Question about Canon ImageRunner 1600 Copier
Problem after switching on copier its comes up with an error message E-101
  • 318 Answers
I know with the error e100-the flag on the drum unit is broken.
Is the flag which open the shutter of the laser still on the drum unit?
Posted on Nov 03, 2008
I'm getting error E-1 on this old guy - Ricoh FT 4027 which makes itimpossible to function . it just halts in E1 position . based on myinvestigations this error is related to lamp , but what should I...
The E code tyo refer the exposure lamp malfunction.Turn ON the main switch,remove the rear cover and turn the DIP switch 101 01 ON and OFF,and turn tha main switch OFF and ON.
Aug 13, 2010 | Ricoh Aficio 1035 Copier
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
Removed the sorter from a ricoh FT5832 copier and replaced with copy tray. how do I bypass the sorter cover (C-5) error message? Will not operate without the sorter plugged in.
Enter the SP mode by hitting the CLEAR MODE key, 1 0 7 then hold the CLEAR STOP key. When SP mode is selected , "1" blinks. Then enter SP 6-101-0 by hitting 6 then the . (dot) key, the 101 then the . (dot) key then the 0 key then the . (dot) key. This will tell the copier that NO sorter is intsalled. Hit the CLEAR MODE key 3 times or turn the machine off/on.
Sep 26, 2009 | Office Equipment & Supplies
File error
Press Enter and 6 at the same time. It should reboot the system immediately and will stop the annoying beeping!
Oct 19, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
Error message
Start by calling the processor help desk and see if they can reload the application. If they can't, you will need a new unit.
May 02, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
DOWNLOADED ADVENTURE ROCK GAME FOR MY DAUGHTER FROM CBBC,BUT THERE`S A PROBLEM IN THE UPDATE PROCESS (ERROR:106) I CANT FIX IT AND I CANT GET THRU TO ADVENTURE ROCK SUPPORT. CAN YOU HELP.
If you get Error 101 after a long wait (this means an actual update is being downloaded) - then to fix it, you need use "Run as Administrator", this is probably because the updater wants to change the contents of an executable file, which is a security risk. So Vista, by default, forbids this action and blocks the program continuing - this shows up as Error 101
When you "Run as Administrator", then the updater is given permission to change the executable so it should work.
Apr 19, 2008 | Computers & Internet
Assembly of Ricoh color laser printer - error message
On the Ricoh 3713 you can do a hard reset by going on the main board toggling dip switch 101-1 on and then off, entering 97, pressing the "aps" key, and then power cycling the printer. Might work similarly on the CL3500N.
Apr 04, 2008 | Ricoh Aficio CL3500N Laser Printer
Englcdt.dat error message
Got the same VRR.2 ERROR message, but when I reset (hold 6 and enter and the same time for a few seconds) it went back to the main screen. Hopefully I didn't clear any important information!
Mar 24, 2008 | VeriFone OMNI 3200 (P092-101-10) Printer
63 people viewed this question
old marine
old marine
