Question about JVC AV-27530 27" TV
Brighteness brightness cranked up. Still picture too dark. Can any one help? What is the g2?
In my case, the adjustment was available from outside the TV. Sortof. On the rear of the TVabout 2 inches to the right of the coax in, there are two vertical slits on a little protrusion. Inside the slits are the two adjustment screws. The lower screw adjusts brightness, the upper screw adjusts focus. I spend 30 minutes popping the case apart just to find that I could not access the adjustment screws from inside. Lo and behold, they made them easily accessible from the outside. On a side note, I have never seen a TV designed as poorly as this on the inside. You have to literally reach in and unplug things just to get the back off. All the electronics save the tube itself are mounted to the rear chassis. On all other TV's I've seen (taken apart, rather), all the electronics are in the FRONT part of the chassis so that they move WITH the tube.
Posted on Oct 05, 2006
    Novelist:
    Champion:
  • 275 Answers
G2? Grid 2. Also known as Screen Electrode. And to adjust G2, just open rear of set, and carefully adjust a control on the FBT (what is FBT? Fly Back Transformer. It is a Black Block with a couple of thick cables, one leading to the Picture tubeand another leading to the Picture Tube Circuit board.It also has two controls - Focus and Screen)) You should adjust G2 (or Screen) voltage as per the instructions given by Techman.
Posted on Sep 25, 2006
    President:
  • 3,130 Answers
You have a drive problem then or the G2 on the High voltage trasformer is set to low. if you really want to attemt to adjust the G2 then lower the brightness and contrast to middle of scale. remove back, and adjust the lower knob on the high voltage trasformer clock wish tilkl the picture gets bright and you see little white lines in the picyure, now turn back counter clockwise till those little white lines just disapears. now the G2 is adjusted right. If then you adjust your set and its still to dark, you have a video driver problem and are going to have to seek out a pro to assist you in this repair.
Posted on Sep 24, 2006
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
Model # 32A43 brightness problem
Check for about 100 to 500 volts on G2 pin (screen voltage) when screen control is adjusted,if less than 200 volts,remove the g2 capacitor(from G2 to ground) on crt board,if screen regains brightness,then replace capacitor,if ok ,troubleshoot the ABL circuit,look for an open or changed valued resistor,also check your heater voltage.Good luck.Cheers.
Nov 04, 2009 | Toshiba 32AF43 32" TV
How do I fix contrast and brightness on 36" toshiba tv?
you can bring more brightness by removing cover on your tv and then you will see ther 2 button ther in back of your tv one is FoCUs and other is G2 rotate the G2 button till you see more brightness on your screen put the cover back and that is if you dont know to do that go to one authorised service
Dec 10, 2008 | Toshiba 36AF41 36" TV
Dark colors
Increege LOT screen preset
check G2 voltage at neck board G2 cathode
remove Sg caps
replace G2 pf
Oct 26, 2008 | LG Studioworks 700S 17" CRT Monitor
Dark picture on toshiba tv 32af44
Sound like the back light has gone, its what gives the picture brightness. Sounds like a technician job. Sorry........
Apr 10, 2008 | Toshiba 32AF44 32" TV
TV picture is dark
the unit flyback has 2 adustments most likly one is focus the othercontrol on the unit g2 which if slightly adjusted will bump ur brightness up
Oct 27, 2007 | Toshiba 36HFX72 36" TV
Screen too dark even with all brightness settings set to max
The picture is very dark it is mostly due to 1 power supply output is low. 2 voltage on crt g2 pin is low. 3 video output supply is low. 4 some components in luminance section might be defective or loose. 5 finally crt getting weak is set is old. good luck
Sep 21, 2007 | JVC AV-27430 27" TV
Acer AL11511
To even things out you need to use the controls on the monitor to lower the brightrnes. to acceptable levels. When playing a DVD there are seperate controls in the software and your graphics driver to adjust the Video Overly settings. Look for settings called gamma and brightness in the video overlay settings in the windows display properties panel. This should help even things out some. Deal is to crank down the brightness on the monitor and crank it up in the video settings in windows. It will make the DVD's brighter and rest of the time the regular screen darker.
Jun 26, 2007 | Acer AL1511 15" LCD Monitor
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
JVC AV-27530 27" TV Logo
285 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
