Question about Honeywell Programmable Thermostat Heater
PROBLEM WITH THE SLIDER
I TRIED TO TURN ON THE HOT WATER BY PUTTING THE SLIDER ON CONTINUOUS (THE SAME WITH HEATING) PUT NO HOT WATER OR HEATING SEEMS TO BE OCCURING. THERE IS ANOTHER SLIDER ON THE RIGHT BUT IM NOT EXACTLY SURE HOW TO WORK THAT.
    Sergeant:
  • 359 Answers
More information needed
Posted on Nov 08, 2008
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Inadequate interior heating
Maybe the thermostat is not opening up fully and restricting water flow. The heater core may have blockages - the heater valve is only opening partially. Gotta check out.
Aug 25, 2017 | 1992 Nissan Maxima
I just replace a hose on my jeep larado 4.0 and now its running hot, no water in oil, no sighs of any enteral damage, just getting hot, over heating
check that you do not have an air lock...while the engine is running check the hoses to see if one is cold, run the engine with the header bottle cap off and if one of the hoses has a bleed nozzle then open it until you have continuous water running and not spitting.
Do not put cold water in a hot engine though, it can blow the head gasket.
Jan 15, 2013 | 1996 Jeep Grand Cherokee
Install continuous flow hot water system
I dont know if any tankless that have that installed.
Because as soon as it detects water movement it starts heating and if you continuous movement it will heat all the time. If that happens then something is going give and it wont be pretty. With a tank type water heater it just recirculates back to the tank and get reheated as needed.
Jan 10, 2013 | Bradford White everhot outdoor tankless...
Hot water working but heating not coming on,wiring seems to be correct,is there reset button maybe?
There usually is a reset button that is red. If this is a electric hot water heater it could be your heating element is out. They are pretty easy to do your self. Normally just take off a side cover slide old one and replace with new one. make sure you turn power off, and if you put in new element, DO NOT turn power on until water is filled in water heater, otherwise you will burn out new one. They have to be always in water to avoid burn out.
May 08, 2011 | Heating & Cooling
User guide needed for old Honeywell programmable heating control
It depends on your system some will only work with hot water on and heating do you have two zone valves?
Jul 18, 2017 | Honeywell TH4210D1005 Heater
We had to replace our hot water tank, we did this
try opening the bleeders on your radiators,one at a time starting at the one closest to the pump until all air has been expelled then close bleeder and move on to the radiator next furthest from the pump and so on.if hot water doesn't come out from the first radiator within a short time, or if you cannot hear air being forced out thru bleeder you prolly have a defective pump; have it checked/replaced by a reputable pro..my guess is that the "buzzing noise" is because the pump is defective and the electricity has no place to go.an easy preliminary check for this is to feel the pump motor while buzzing to see if it is hot, if ti is it prolly is bad
Nov 14, 2009 | Plumbing
I have a Honeywell ST499A/ST699B "Central Heating Microelectronic Time Controller" managing the operation of my house boiler. The time controls are set properly. PROBLEM: If I want either hot water or...
I have an old Honeywell ST499A/ST699B thermostat. It still works OK but when we have a power cut I have to re-programme everything. Presumably this is because the battery needs replacing. I cannot find a way of opening the control box to get into the unit to replace the battery and in any case I’m not sure if the battery is renewable?
Oct 12, 2009 | Honeywell Programmable Thermostat Heater
Meile espresso maker does not expel air
Press Hot Water and Steam Button at same time.
Dec 24, 2006 | Miele CVA615 Espresso Machine
Heating & Cooling Logo
74 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
