Question about Whirlpool Washing Machines
I have just purchased a whirlpool washing machine , first wash was very noisy on the spin, second wash spun the washing machine out of the housing and the top came off and the rubber feet also. I could not hold it it was so heavy and had to switch off, it has damaged the floor and the top flew off........help me I cant stand it 3 days old
  • pintski Nov 03, 2008
    I am blond so spose thats the reason, but ok now thanks as have removed all the fixings x
    Genius:
  • 1,028 Answers
If top load or front load DID YOU REMOVE ALL SHIPPING MATERIALS ??
Posted on Nov 02, 2008
My Whirlpool spins... It just does not do a very good job
It's very possible that the impeller in the drain pump is striping out and not allowing the pump to get up to high enough spin to completely drain.
Jan 16, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
It makes a loud whining noise when it is on the spin cycle. Functions ok, but sounds like it is a jet engine...
Hello there: Here is a extensive list of things to look at and hopefully this will be very helpful for you Washing machine is noisy It's very difficult to advise on a noisy washing machine because you often can't describe noises accurately enough. People can describe the same noises quite differently. Please visit the following link for a detailed list of ways to help with your noisy washing machine. http://www.washerhelp.co.uk/diy-repair-help_2.html#cl_q4
Dec 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Washing machine stops after final rinse cycle
    Your lid switch is bad. It must be replaced.
    Jun 26, 2009 | Whirlpool Washing Machines
    Addl Info: Our Whirlpool Ultimate Care II washing maching agitates fine, but will not spin.
    The spin tub mounting block is probably stripped on the basket drive. Remove agitator. Now put machine into spin do you see shaft spinning but the tub isnt moving???
    Dec 06, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    Dan Webster
    Dan Webster
    Sal De
