Question about Samsung RS2630SH Side by Side Refrigerator
Noisey fan When the fan starts up it wirls and is getting worse but i cant seen to see how tou get to it to it out. any advise.
  • Anonymous Nov 14, 2008
    We have the same problem with our fan in this model of fridge. We pull it from the wall and take the back bottom panel off and take out the fan. Clean it and spray it with lithum grease and petrolum oil. It runs nice and quiet for about 6 months then we have to do it all over again. Since it is a plastic POS fan we seem to think when it gets hot it warps a little from it's own weight. Hope this helps.
    Scholar:
  • 68 Answers
It is probably the sleeve bearings in the fan of which there may be several fans, I need make and model to help you find the fan, and if it is sleeve bearings in the fan, soon it will lock up completely.
Will
Posted on Nov 05, 2008
Heatsink fan noisey running at 4000rpm
Order a fan for your machine. No idea make and model as you didn't specify.
Mar 01, 2014 | Computers & Internet
Engine knock
Usually a sign of bad bearings or connecting rods.
Jun 28, 2012 | Mazda B4000 Cars & Trucks
Vent fan makes noise at end of cycle
A noise at the end of a vent cycle, as the fan is slowing down, may also be caused by the bearings on the fan shaft starting to go bad. As they get worse, you will begin to hear the oise as the fan is runing, not just as it slows. Solution: replace fan.
Feb 11, 2012 | Miele Dishwashers
My HP DC7600 - get noisey when starting to plau games
http://almico.com/speedfan452.exe
Download and install and run this. You may want to go to the settings tab in the program and change it from metric. Then you can see the temperatures of everything in your computer. You can then launch the game and see what the temps do. It is common for fans to speed up when the computer senses large demand on the processor and graphics cards.
Dec 11, 2017 | HP dc7600 Convertible Minitower PC Desktop
I have a 1999 Sable and the ABS motors seem to come on and off randomly. I cant aford to fix the problem. Perhaps pulling the fuse and disconnecting the ABS system would be an easy solution?
yes you can do this then car will revert to conventional braking system ,but the ABS motors do run randomly to maintain pressure so its nothing to worry about perhaps motors are a bit noisey which is why you can hear them ,I would advise you to leave well alone to be honest as i think teh system is working ok abeit a bit noisey
Mar 12, 2011 | 1999 Mercury Sable
My Nissan max 1996 interior ac fan is very noisey. Ac works great. Pl help & advise
More then likely, the bearing on your blower motor (fan) are bad, replacement is the only repair.
Aug 19, 2010 | 1996 Nissan Maxima
How do I use my non-descript Whistler electronic remote starter FCC: HSXASDAF Bought a used car and can't figure out what the buttons do!
it looks like a one wire self ground system.could be wrong.if you can buy a better remote starter.not a known brand.tend to be trouble.a bulldog is good and easy to hook up.must know you electrics of car.sugestion take to alarm place to install.i seen people com in with home hook ups and get starter probs.if not worse no starts in care.
Aug 17, 2010 | WIRLES REMOTECONTRL SWTCH
Making noise but working good
Either you have a noisey bearing, or the fan on top is rubbimg against the cover. My neighbor's pump has been making noise for several years now, and the pump seems to do fine. If the noise gets worse, I'd look at changing the bearings.
Best regards, --W/D--
Aug 21, 2009 | Jet Plumbing
Squeaking noise front drivers side of engine
Loosen the belts [ you do not need to remove] so they are free of tension to all pulleys.Start engine , if noise goes away either belts were too loose [ common on lx 450] or you have a worn & noisey pulley /bearing.have seen idler pulley below alternator have dry / noisey bearing.Otherwise if idler is ok it has to be another belt driven assessory , ac clutch,water pump & or fan clutch.Good Luck.
Jan 17, 2009 | 1997 Lexus LX 450
Samsung RS2630SH Side by Side Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
