Question about Tomtom GO 700 GPS Receiver
Tomtomgo730 bought yesterday, go through start up questions successfully until screen says No maps found ! What do i do next please?
  • ilioiu iulia Jan 17, 2009
    como se puede activar avizo sonido para radares tomtomGO730
Go to preferences map data,change map,if there is no maps to change you have a lemon!
Posted on Nov 07, 2008
My garmin nuvi 200 says no detailed maps found
From the Garmin web site:
Question: What should I do if my Garmin nuvi / zumo displays the message "No Detailed Maps That Support Autorouting."?
Answer: Please follow these steps to troubleshoot the error message:
Checking the unit:
  1. Hold your finger down on the screen until the message "No Detailed Maps That Support Autorouting" disappears.
  2. If you get a locked maps message following this error please remove any SD cards in the device and skip down to the instructions for "Getting your unlock codes".If you did not get a locked maps message then please select tools>settings>map>mapinfo button.
  3. Check the box next to the mapping product City Navigator and you should no longer get the "No Detailed Maps That Support Autorouting" message.
Aug 14, 2012 | Garmin Nuvi 200 Automotive Gps Receiver
Maps disapeared from my garmin for no reason!
go into settings, then map, then map info see if box is ticked if not tick it, then return to where to and see if countrys name appears the select country
Dec 04, 2009 | Garmin nuvi 205 GPS Receiver
I've had my Garmin Nuvi for 9 months and never had a problem until yesterday. I suddenly started getting the "maps not available" notice on my screen and it locks up. PLEASE HELP!!
The maps were deleted from your system. If you've only had your system for that amount of time, they will fix it for you for free. If you want to have someone do it for you, then I can fix it for you for $40. cfoster16@comcast.net
Aug 28, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
I just purchased the Map update 2009 dvd. I installed everything and the computer said everything was downloaded. I restarted my garlin and it doesnt appear that anything is different then when I...
The only way you can be assured that your map update was successful is to check the version.
1) On your main screen, you'll have a little wrench tool, click on it.
2) On the next screen, go to the "Map" icon.
3) Next screen, click on the "Map Info"
4) Last screen you'll see the maps isntalled and the year.
Best of Luck!
Apr 10, 2009 | Garmin StreetPilot C330 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
No maps found
I had the same problem how ever after downloading all the software updates and pretty well evey thing that was available on the tomtom home sight suddenly the map was there. It could be a soft ware bug.
Mar 19, 2008 | Tomtom One XL GPS Receiver
HELP!!! Cannot start VAIO ARG230G
do safe mode, and find out if your disk is clean or overly fragmented
Mar 12, 2008 | Computers & Internet
Can't find State or Province
The C550 does support USB 2.0 so data transfer of the Maps was most likely faster. The newer USB drivers from Garmin is most likely USB 2.0 compliant. Perhaps they didn't fully test it for USB 1.1 Anyway it's working for now. Usually I go to setting Map, Map info to verify that the upgrade was successful.
Jan 06, 2008 | Garmin StreetPilot c550 GPS Receiver
Tomtom GO 700 GPS Receiver Logo
49 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
