Was running fine then I stopped to get gas and went to start it and nothing. Battery post were loose...I tightened them . a man came over tried to boost it and nothing...then someone clunked it underneath a couple of times with it hooked up to another battery and voila it started. went home it was ok started barley next morning and throughout day ...was told to get new battery...got one...installed it and it started ok but it dragged a little each time i tried and then NOTHING??? Is it my alternator or what?? please help me!
SOURCE: 2004 mazda mpv
also have a 04 MPV with the same problem. Happened last year also. it's one of the ignition coils. Must be a design flaw from the factory as somehow moisture get into the coil and causes missfiring. Coil costs about $77 from Mazda (CAN).
SOURCE: BATTERY LIGHT STAYS ON.
i believe your over charging ie; voltage regulator bad. should only have between 12-14.5 volts max when testing at bat with volt meter
SOURCE: Mazda mx3 wont start
VSS or vehicle speed sensor aka cam sensor or crank position sensor. Test the battery and alternator. You should also check for blown fuses, bad wires and grounds on a car as old as yours. If you find it's getting spark and fuel after further testing, check the timing belt. It could have slipped or broke even if it was changed recently so either pull off the cover or at least do a compression test.
SOURCE: 2002 mazda protege5 auto battery light coming on
I'm guessing that you've tested the actual current output of the alternator then. I'm assuming that the output is between 13-14Volts at the battery when the car is running... If it's too low, then it's not charging your battery at all, too high, and it's frying your battery.... Another thing that can cause this is if you have a short in your electrical system.. that, however, will be difficult to narrow down...
SOURCE: Mazda 6 '06 won't start
2003 mazda 6 /3.0L[ford engine]5 spd automatic.I replaced both engine & trans. due to motor being blown,with low milage salvage motor [under 50,000 miles] /IF YOU CRANK ENGINE IT WILL TEMPORARY START ONLY IF YOU HOLD HAND OVER THROTTLE BODY INCLUDING REMOVING HAND.NOTE :IT HAS FUEL PREASURE DO NOT KNOW PSI./IT HAS STRONG VACCUM AT THROTTLE BODY[AS IN UNCOFORTABLE DRAW ON YOUR HAND]----DOSE ANYBODY HAVE ANY GOOD TECHNICAL ADVISE???
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
