FixYa.com
Tags:
iLO +R/RW DVD Recorder, DVDR05
Ilo dvd player/recorder (by 2 users)
posted by la verga on Sep 23, 2006
hey i was wondering if there was a way to control my ilo dvd player with another controler.The reason why is because my original controler doesnt work any more, only certain buttons work and i dont know why!So if their is a way to control the dvd player can you please let me know. Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nitab, posted on Mar 11, 2008
Some of the buttons on the remote that came with the ilo recorder do not work. Changed the battery and still no results
Best Solution
posted on Jul 03, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
OK I called the Philips and since mine is already programmed he walked me thru how to retreive code. He said 1906 on the VCR button. Hope it works for you KCGIRL.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 22, 2008
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
I too tried dozens of universal remotes over the years and none worked at all, TILL YESTERDAY. A guy at Walmart said use the Philips brand. Not sure, I tried. SRU3004, it doesn't do everything (like eject) but does let you into the Source (input button) and navigate to the record settings(sleep button), and power etc. The unit is worthless without a remote. Maybe there is another Philips product that has more I dunno. OH, and the code listed didn't work. I had to do the manual search and it was like the 300th push on the power button so don't give up too quick. I couldn't believe it worked!!!!!
Solution #3
Helpful (85)
Guest
Guest
Rating: 0%, 0 votes
my son knocked batteries out of Philips remote and I had to reprogram it. I wish I had the numeric code..I finally got it with the channel buttons. I think I may have used the code search by brand for ALL to reset it..Keep trying. I swear it works its just tough to get it programmed.
Solution #4
posted on Jan 30, 2007
Helpful (85)
Thunder Pig
Rating: 84%, 4 votes
I think you are out of luck, unless you can find someone else who owns one, and will let you use their controller to program a learnable remote.
I have purchased, and returned dozens of universal remotes...not one has worked.
Solution #5
posted on Jun 22, 2008
Not Rated (0)
kcgirl
Rating: 0%, 0 votes
in regard to best solution by "guest", what did you do after the 300th push? I finally got there too and the channel did change but that was it. It did not program the remote to work properly. It changed only one channel, then i push mute. then nothing. please help.
Solution #6
posted on Feb 05, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
change the battery
Can you Help with these DVD Players problems?
Non-working DVD Recorder/Player
This electronic device (ILO... Answer This...
DVD not reading but spinning
This dvd-R recognize the dvd... Answer This...
switching on my san0218-250gb
hi, it will not boot up if that... Answer This...
region free method for Sony...
Need codes to unlock region on... Answer This...
DVDR05 recorder and player
Front is flashing and cant do... Answer This...
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
