Question about Sanyo DS27820 27" TV
Sound cuts out periodically
Sound comes through normally when TV is turned on. However, it starts cutting in and out periodically, for longer and longer times. Sound comes back briefly (a word or a sentence) then goes away again. Tapping the set sometimes brings the sound back for a short while.
    President:
  • 3,130 Answers
Sounds like a poor or cold solder connection in the sound circuit. If your not a tech, this repair really should not cost an arm and a leg to repair , but maybe your first born??LOLOL No really if you have no solid state repair experience please seek out a local repair person to assist you in this repair.
Posted on Sep 24, 2006
SOURCE:
Celcus tv sound cutting out
Gate7, your main board in the TV may be bad and may need to be replaced. Try this RE SET procedure first, turn the TV on so you have a picture,then
while it is on unplug it. Wait 5 mins and plug it back in.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 26, 2016 | Celcus Televison & Video
Viore tv sound cuts out
Could be a failing power supply
Mar 12, 2014 | Televison & Video
Red power lights blinks and tv will cut off. sometimes after you unplug it it will come on after about 10 min. now it will not come on unless you unplug it and then it will work about 5 min and cut off...
depending on the age of your tv, this appears to be a common issue. Blame it on the ballast board. your ballast might not be able to provide the lamp w/ enough voltage to keep the image on for longer period of times. or it could simply be that you need a new tv lamp.
Apr 13, 2010 | Toshiba 55HX70 55" Rear Projection...
Tv cuts off and on no picture or sound
Most TV shut downs like this are HEAT related.Try increased cooling with a fan blowing into it to test this on yours.If it works leave the fan running or repair with a nice little but strong computer fan placed behind the unit..
Aug 17, 2009 | LG 32LG30 32 in. LCD HDTV
No picture but has sound
The problem can be caused by a bad sustain board (Ysus Zsus) , the popping sound is often caused by a capacitor blowing up.
The TV must be taken apart and tested before eventually replacing sustain boards.
Apr 27, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
have a 42 inch rca 42PA30RQ NO PICTURE OR SOUND WHAT CAN I DO MY SELF BEFORE SPENDING A LOT OF MONEY TAKING TO A REPAIR SHOP
Dec 14, 2007 | Panasonic TC-26LX20 26 in. HD-Ready LCD...
hello .this does sound like bad solder joints .all printed circuit boards do this after a while due to heating and cooling .is not advisable to try to repair yourself .possible electric shock and spiking .will do a lot of damage .take to a shop to have repaired
Oct 30, 2007 | Sony KV-36XBR450 36" TV
You need to have service on the set, the audio portion on the main board is going out
Feb 17, 2007 | Sceptre X37sv-Naga 37 in. LCD Television
Sanyo DS27820 27" TV Logo
493 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
