Question about Acer Aspire 5920-6727 Notebook
How to install audio drives in
Not connecting audios
  • 93 Answers
Go to Acer web and find audio driver for your module of laptop from driver download options.
Posted on Nov 18, 2008
I have installed Windows on a computer and I can not find the sound. I do not have it at all and everything I have connections. Please what can I do
first make sure your audio is enabled in the bios you motherboard manual will have instructions for this. then install the audio drive from your motherboard drive disc
Feb 01, 2011 | MSI RX480 NEO2 Motherboards
I can not get any sound.
Start your PC and press Dell/F2/F10 for setup BIOS.
Enable on board audio.
F10> hit .
When the problem will be same ,do another step.
Follow bellow.
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • OR
  • If the connection ok increase your volume and open the cable from the pc.
    Now you will touch the stereo jack, can you can listen a sound when touch the jack. If you will not get any sound, think there is the problem in your amplifier or audio system has not any voltage. To confirm the voltage check by multi miter or can go any local Technician .If the voltage is ok, think your sound system defected and should go to Technician.
  • If your sound system is ok
  • Speaker Cable connect to an audio port (Audio/Video port in system box).
  • Ensure Volume is not in MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
  • To confirm follow next step or ROLL BACK THE DRIVER
http://technet.microsoft.com/hi-in/library/bb457021%28en-us%29.aspx For another check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System PropertiesWindow)
• Select "Hardware" Tab>
• Select "Device Manager" Tab> (it shows the Device Manager Window)
• Select "Sound, video and game controllers">
• Expand "+" symbol> (check the audio Codec's, Legacy Audio Drivers andothers are not in Questioned Mark (?) symbol with yellow color. If there needto install the drivers). Hope it will help you.
Dec 31, 2010 | ASUS P5GC-MX/1333 Motherboard
When I try to play sound I get this message."There are no audio output devices currently installed on your machine"When I try to play sound I get this message."There are no audio output devices currently...
It is either that the device is bad or the driver not instal, first get the driver re-install. if this doest not solve the problem get a new sound Card
Sep 28, 2010 | Computers & Internet
My computer wont play the sound when im trying to listen to music or play a movie.i would like to know how to get the sound back on
Have u recently installed a new DVD Drive?
If so and even if so, you need to have an audio cable installed connecting the DVD drive to the Sound Card in order to get sound when playing a MUSIC CD or DVD player from that drive. So double check that inside of the PC.
Next, go into the Audio Settings in the Control Panel and make sure sound is not muted.
Mar 15, 2010 | Acer (54.AA806.001) Sound Card
No sound when i put in cd or dvd was working ok untill my computer crashed
check the following
Microsoft Volume Control or your mixer program mute options and volume sliders.
Connect headphones to the stereo phone jack on your CD-ROM drive’s front panel; adjust the volume control settings on the drive. If there is sound from your headphones, check the CD audio cable connection from the CD-ROM drive to the audio card.
Ensure the speakers are properly connected to the audio card’s output connector.
hope this can help
goodluck
JABEMS
Nov 13, 2009 | Hannspree 19" Widescreen LCD Flat Panel...
Thanks for the response. I installed the audio cable but still no sound. Any other suggestions?? Checked the device manager and it tells me that the dvd is functioning properly.
First guess, ensure the speakers are powered, double check all connections. Ensure that all audio drivers are installed in the device manager, or try installing the drivers for audio from Dell's website. You can search via your Dell service tag to provide drivers for your PC.
Ensure the volume control for Windows is turned up and not muted, and ensure the volume on the speakers.
Are you trying to play an audio CD from the DVD drive? If so, it may require a 4 pin analog cd audio cable which goes from the DVD drive to the sound card.
Oct 31, 2009 | Dell Dimension 8400 PC Desktop
dvd drives must be connected also by hardware, usually its from dvd to mainboard. First thing Check The Drivers. Original ones and Install them.
Nov 30, 2008 | Compaq Audio card Sound Card
Audio
hi HD audio driver not support in your mother board if you install
realtech audio drive you cancel your HD 1st. then setup auto.....
Feb 17, 2008 | Computers & Internet
Internal DVD Drive
if you,ve purchased a SATA drive.
Then you should have SATA Connectors On The Motherboard.
If you look carefully you should see SATA1 And SATA2 if applicable. they,ll look like a small black/white piece of plastic connector. shaped similar to a letter *L* this is the sata connector, you may already have a hard-drive on 1 of them. ( red Cable ) The 4 pin audio cable, goes from the rear of your DVD Drive, you should have 2. 1 for analogue 1 for digital. this connects Audio from your Drive to motherboard, slim grey cable ( usually ) look towards the rear of your motherboard for this, usually towards the audio out ( if you have onboard soundcard )
connect this to Audio/sound ( you,ll probably have 3 located close together.
Hope this helps.
Mike @ Compurepair.
Feb 11, 2008 | Computers & Internet
Nero cr-rw burner install
is your hard drive the master on the primary cable? You shouldn't need a digital audio cable unless you want digital audio. Are you using Nero software witht he drive? may have to re-install the software, or better, uninstall it, clear the registry with CCleaner (free download on the web) and then try a fresh install.
Dec 13, 2007 | LG CED 8120B CD-RW Burner
Acer Aspire 5920-6727 Notebook Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
