Question about Mitsubishi VS-50605 50" Rear Projection Television
Plug in tv and doesnt work
I took the tv apart and found that a small quarter size part on the signal board has burned up but it looks as if its only the components that are burned up. im looking for a replacment board or parts so that i can have my tv back. any ideas?
    President:
  • 3,130 Answers
If you have no Tv repair experience, how do you know what part this is?, as I dont have a clue as you didnt supply a schematic or a picture of what the part was. We techs have a trade we learned not by doing but by going to school to learn the theroy behind the circuits. If you know how to read a schematic diagram, i suggest that you get one and know what part it is that you think you found burnt out. If you go to http://www.servicemanuals.net, download a service manual or schematic diagram, i will assist you in this repair as long as you have the proper equipment such as a mutimeter and know how to trouble shoot solid state electronics. Its not a tube you can take out and test or a board that can be exchanged anymore my freind. Its down to the componet level these days.
Posted on Sep 24, 2006
Sony KDL flat screen tv broke during a ligtening storm. I'm certain it was caused by the storm because our satellite dish was also damaged. Unfortunately the tv was plugged directly into the wall--not...
The tv power supply board it is dead 100% it is dead that board where the tv power a/c plug into it.Sometimes u get a burn or a chart coal marks if the power surge have big enough charges to the board,not it still kills board too because electromagnatic charges of the storm kills every electronic parts in came in contact with.Take the tv aparts.The tv power supply board are alway the one these two boards are the causes alway and the first board to dies .Replaced the tv power supply board first.Tv should work now,if not the main tv Tuner signal board it is also dead too.That the board where the incomming broadcasting signal wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement first and also the main tv Tuner signal board too,if necessary.70-80% changes the power supply board and necessary the main tv Tuner signal boad too tv should work again.20% sometimes the whole tv it fries and a total lost.
Aug 31, 2011 | Sony KDL32L5000 32 in. LCD HDTV
I have a HP PL5060N My TV is going nuts. The channels change on their own no matter if I am watching TV, gaming or watching a movie. I just get booted out of where I am or the TV show to watch the new...
Take the tv aparts.Take the tv manual control board aparts.Reajusting the board and screws it back in.Should solved ur problems,if not than the whole tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal board plug into it,this board have intermittent problems and the causes.Try website like Ebay.com t buy a whole refurbish tv Tuner signal board for the replacement.
Dec 06, 2010 | HP PL5060N 50 in. Plasma HDTV
RCA d56w20 changes aspect size and picture appears jumpy
Thats caused by the small signal board, which is actually a board known to fail when the aspect changes on its own like that. You can get replacement small signal boards at www.tvrepairworld.com
Mar 30, 2010 | RCA D56W20 56" Rear Projection Television
Tv started to smoke took apart and found found the
I assume it was the power supply that you replaced? It is very likely that a fusible device on another board has gone open circuit to protect any damage due to the initial problem. Again I assume you have a plasma TV in which case there will probably be a problem on the Y or Z sustain boards which may also need to be replaced as this may have been the reason for the other board to burn up
Dec 20, 2009 | Televison & Video
My power cord fell off. Took off the back of the
there is a small board with a small transformer . the plug is located next to that small transformer. if the cord originally came from the right hand side if you are looking at tv from the back. the plug is on that right board. if the tv cord came from the left side, the plug is located on the main board in the front of tv. the plug in both situations are the same, it is white in color and has 2 or three pins sticking straight up.
Nov 15, 2009 | Sony KV-32FS13 TV
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue light goes to Orange blinking no sound no picture Screen on
Hi!
Okay, if the screen is white! First, take apart and check the ribbon like cable that goes from your signal board (where you inputs are plugged in) to the lcd controller (under a small metal plate feed the lcd screen), see if loose and or reset! Secondly you either have a bad signal board or lcd controller!
Feb 28, 2009 | Westinghouse LTV-30W2 Television
The motor from my reciprocating saw started emitting smoke.
That small black piece, was it somewhat flat? I am thinking that it could be part of the fan or baffle. As far as the smoking when you had it apart how did the windings look on the armature and field? It is possible that this piece of plastic opened up the windings and there is a short in the electrical components. If that is the case I would suggest taking to a repair center to get is looked at. Let me know what you find
Jan 03, 2009 | Porter Cable Variable Speed Quik Change...
Tv comes on goes off
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Feb 25, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Mitsubishi VS-50605 50" Rear Projection Television Logo
70 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
