I have a Samsung j1045 frontloader washer and it turns on but would not move to any wash cycle or turn off.
  • julienb Nov 03, 2008
    I have exactly the same probleme. Can you please help me?
  • lorraine_pet
    lorraine_pet Aug 12, 2012
    I have a frontloader, it is flashing 5E. I have cleared debris from it. It is still flashing and not finishing cycle. Can you advise please?
I have a Samsung j1045 front load washer and once turned on, it wouldnt move to any washing cycle or turn off. I would have to unplug the cord from the jack to prevent any danger. Please help me and give me a solution as I have a mountain load of washing to do.
Posted on Nov 18, 2008
Samsung j1045 washing machine
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Oct 14, 2012 | Samsung Front Load Washer Control Board...
My samsung frontload washer stopped steaming at the end of cycle
Is your hot water valve open all the way? If you run the washer on a hot cycle only, does it fill up?
Nov 17, 2011 | Washing Machines
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
I had stored my ge frontloader washer and dryers for about 4 months and reinstalled them i turn the washer on and it runs threw its cycle and does not spin so the close are soaked in the washer the model...
I would remove the back and investigate for mouse/rat damage. If you had them in storage a rodent may have made himself a home. They like to chew thru wires and plastic components. Or a wire connection may have come loose when you moved them into storage or back from storage.
Sep 25, 2009 | GE WSXH208A Front Load Washer
I have samsung j1045 frontloader and door will not open have waited 3min and let it turn off but still will not open
hi
in this machine if door is not opening after 3 minute after 3min.switch off the set,the handle might be broken.please check handle feels loose if yes,it has to be replaced
If you want open the door in emergency open the down cover for filter,pull the yellow strip for door opening
please give me reply
Nov 10, 2008 | Washing Machines
I can not seem to balace the washer- it dances around the room on spin. front loader j1045 6mths old
Has anything changed? have you moved it? is it level? Check the level of it and if it is infact NOT level make it so.. If it IS level I would not play with it.. get a warranty repair tech out..
Hope this helps
May 30, 2008 | Samsung Washing Machines
Washing Machines Logo
494 people viewed this question
Top Washing Machines Experts
