Question about Nokia 3110 Cellular Phone
Can any 1 give me some tips????...............
I have 1gb micro sd card( san disk).The problem i encounter is i could not paste any objects into my memory card.when i try 2 do the system is showing me a warning message which suggests that the disk is write protected or use another disk.
please tell me the solution for this problem which is very frequent for me .
hopefully expecting a reply with solution from someone.............
    Problem Solver:
  • 7 Answers
I think u r not using a data cable for the file transfer.... u r using thatcardreader right... these card reader dont work with the micro sd cards... use a data cable it costs 140 bucks....
Posted on Nov 04, 2008
I keep getting card cannot be used every time i put a memory card in my nikon coolpix s210 what can i do to fix this
If formatting does not work then most likely the memory card id faulty.
Memory cards such as SD and USB memory sticks do not last forever. they do fail eventually after many writes and file file deletes or damaged by not using Safely Remove Hardware on the computer.
Jun 11, 2012 | Nikon Coolpix S210 Digital Camera
I have a 2 g memory card which when full I uploaded to my PC and then deleated all photos from the memory card I tried to use this card again but the camera tells me the memory card is full also it tells...
Exactly the same problem occurred with my San Disk 1GB micro-SD Memory Card. And I solved this problem formatting my micro-SD Memory Card using a software which you can download by clicking here.
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the installed "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
That's all my friend. This solved my problem and I hope this helps you too.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
How shall i put in a kingston 1gb micro sd in a All in 1 card reader
You should have 2 components with your micro SD card. The card, a small adaptor and a large adaptor. All you need to do is see what size adaptor your read needs. You place the card in the tiny slot in the adaptor and slide it in the reader. The computer will find the micro SD and install the driver to read it. Then it will give you an option to open the files. That is how 99% of them work.
Sep 30, 2009 | Fuji xD MP3 Player
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
Jensen VM9512 - 4GB SD Card won't work
I use a scan disk 2 or 4 gb and both work just fine.
Mar 31, 2009 | Audiovox VM9512 Car DVD Player
8 gig micro sd unable to format
you should download memory retriever it fixes your memory card and retrieves your data. i had the same memory card and i thought it was from the memory card acting up so i got a new one. but it was kind of from both the phone and memory card but i downloaded the program and = ] my new memory card wasn't formatted so now am all good! both of them working because my san disk memory card wasn't working and it deleted all my data. so now it retrieved and now is working! give it a try! and tell me what happens
Mar 21, 2009 | Electronics - Others
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Memory card error
did you already formated your memort stick? try to remove your memory card from your camcorder and insert it again. look for the settings on your camcorder. it might cause the problem. hope that helps!
CHARCOIS
Aug 17, 2008 | Samsung SC-D103 Mini DV Digital Camcorder
Memory card problem
is it locked? have you tried using that card on another medium? if it has the same error, try to reformat it. and after reformatting it? if it still has that error, you may need to replace that card.
Mar 16, 2008 | Electronics - Others
Micro SD Not Reading
I have same problem with A1200 not recognize micro sd card.
some one help ,Please.
Thank - you.
Oct 07, 2007 | Motorola Mobility A1200
Nokia 3110 Cellular Phone Logo
18 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
